    Clock format
    41 Posts 2 Posters 25.2k Views 2 Watching
      sdetweil @louise
      @louise said in Clock format:
      module: “clock”,
      position: “top_left”
      still didnt’ get the select all
      and this is the only part we needed
      module: “clock”,
      it has no config:{} section, so all the module defaults are used
      to change some setting here do
      module: “clock”,
      position: “top_left”,     // <-  add a comma (more stuff follows this line)
      config : {
           timeFormat:24,
      in the setting above clock will use 24 hour format, even if the base is set to 12 hour format
      • L Offline
        louise @sdetweil
        @sdetweil Given a choice I would rather just have this figured out. Did I do right this time?
          sdetweil @louise
          @louise no
          • L Offline
            louise @sdetweil
            @sdetweil frustrated yet?
            It is my config.js
            I know it says sample on top but it didn’t mess with any of that. I added in the disabled the compliment and newsfeed like u said so that worked.
            I don’t understand apparently.
              sdetweil @louise
              @louise here
              https://forum.magicmirror.builders/topic/15954/clock-format/18?_=1638300432581
              the part of config.js is right, but the code block is wrong… and its doubled for some reason
              when we ask for a module config, we don’t want the WHOLE config.js…
              (also, there are private things in there, api keys, maybe passwords, … )
              so we want as small as possible focused on A module usually
              • L Offline
                louise @sdetweil
                @sdetweil So you are saying I should I this under the the area it says clock module?
                config : {
                timeFormat:24,
                  sdetweil @louise
                  @louise ONLY IF you want to control it separately from (and have it different then ) the base MagicMirror setting
                  • L Offline
                    louise @sdetweil
                    @sdetweil I tried to put the code you had in my config but still 24 hr clock.
                      sdetweil @louise
                      @louise the config setting I had above said 24 hour format, not 12
                      • L Offline
                        louise @sdetweil
                        @sdetweil Actually tried it both ways, but neither worked.
                        Did you say I had something duplicated?
                          sdetweil @louise
                          @louise in the post I linked u had 2 copies of the config.js content
                            @sdetweil I wonder
                            are u using pm2 to launch mm?
                            do
                            pm2 status
                            if so do pm2 stop all
                            I think u are getting the default cause there was an error
                            • L Offline
                              louise @sdetweil
                              @sdetweil ok, did that. Just restart now?
                                sdetweil @louise
                                @louise lets check to make sure nothing is stuck
                                do
                                ps -ef | grep MagicMirror
                                should return 1 line of output
                                • L Offline
                                  louise @sdetweil
                                  @sdetweil pi 1390 1361 0 18:33 pets/0. 00:00:00 grep — color=auto MagicMirror
                                    sdetweil @louise
                                    @louise ok, NOW we can
                                    pm2 start 0
                                    • L Offline
                                      louise @sdetweil
                                      @sdetweil restarted, still 24 clock
                                      • 2 / 3
