    Clock format
    41 Posts 2 Posters 26.2k Views 2 Watching
      sdetweil @louise
      @louise here
      https://forum.magicmirror.builders/topic/15954/clock-format/18?_=1638300432581
      the part of config.js is right, but the code block is wrong… and its doubled for some reason
      when we ask for a module config, we don’t want the WHOLE config.js…
      (also, there are private things in there, api keys, maybe passwords, … )
      so we want as small as possible focused on A module usually
      L 1 Reply Last reply
      • L
        louise @sdetweil
        @sdetweil So you are saying I should I this under the the area it says clock module?
        config : {
        timeFormat:24,
          sdetweil @louise
          @louise ONLY IF you want to control it separately from (and have it different then ) the base MagicMirror setting
          • L
            louise @sdetweil
            @sdetweil I tried to put the code you had in my config but still 24 hr clock.
              sdetweil @louise
              @louise the config setting I had above said 24 hour format, not 12
              • L
                louise @sdetweil
                @sdetweil Actually tried it both ways, but neither worked.
                Did you say I had something duplicated?
                  sdetweil @louise
                  @louise in the post I linked u had 2 copies of the config.js content
                    @sdetweil I wonder
                    are u using pm2 to launch mm?
                    do
                    pm2 status
                    if so do pm2 stop all
                    I think u are getting the default cause there was an error
                    • L
                      louise @sdetweil
                      @sdetweil ok, did that. Just restart now?
                        sdetweil @louise
                        @louise lets check to make sure nothing is stuck
                        do
                        ps -ef | grep MagicMirror
                        should return 1 line of output
                        • L
                          louise @sdetweil
                          @sdetweil pi 1390 1361 0 18:33 pets/0. 00:00:00 grep — color=auto MagicMirror
                            sdetweil @louise
                            @louise ok, NOW we can
                            pm2 start 0
                            • L
                              louise @sdetweil
                              @sdetweil restarted, still 24 clock
                              • 2 / 3
