    OrangePi Zero 2 installation issues
    41 Posts 2 Posters 13.5k Views 2 Watching
      michelw
      hi,
      Since the rp4 is hard to get atm, I got a orangpi zero 2 in stead and followed installation instructions here https://www.instructables.com/Orange-Pi-Magic-Mirror/ and here: https://docs.magicmirror.builders/getting-started/installation.html#manual-installation
      When starting mm I get:
        ___  ____  _   _____             ____
       / _ \|  _ \(_) |__  /___ _ __ ___|___ \
      | | | | |_) | |   / // _ \ '__/ _ \ __) |
      | |_| |  __/| |  / /|  __/ | | (_) / __/
       \___/|_|   |_| /____\___|_|  \___/_____|
      Welcome to Armbian 21.08.6 Focal with Linux 4.9.255-sun50iw9
      System load:   24%           	Up time:       2 min
      Memory usage:  11% of 964M   	IP:	       192.168.207.243
      CPU temp:      56°C           	Usage of /:    4% of 58G
      [ General system configuration (beta): armbian-config ]
      Last login: Fri Dec 10 17:27:44 2021 from 192.168.207.6
      michel@orangepizero2:~/MagicMirror$ npm run start
      > magicmirror@2.17.1 start /home/michel/MagicMirror
      sh: 1: ./node_modules/.bin/electron: not found
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.17.1 start script.
      npm ERR!     /home/michel/.npm/_logs/2021-12-10T16_46_30_202Z-debug.log
      I tried:
      ~/MagicMirror$ sudo npm install electron
      > electron@13.6.3 postinstall /home/michel/MagicMirror/node_modules/electron
      > node install.js
      Error: EACCES: permission denied, mkdtemp '/home/michel/MagicMirror/node_modules/electron/electron-download-oEbSjl'
      npm WARN tsutils@3.21.0 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
      npm ERR! errno 1
      npm ERR! electron@13.6.3 postinstall: `node install.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the electron@13.6.3 postinstall script.
      npm ERR!     /root/.npm/_logs/2021-12-10T16_54_08_006Z-debug.log
      My linux knowledge is not good enough to figure this one out. :(
      Anyone who could help?
      Cheers,
      Michel
        sdetweil @michelw
        @michelw you used sudo on some command, in error ( do not use sudo for any mm related thing)
        to get out of that
        cd ~
        sudo chown -R michel MagicMirror
        also, use my script, it does everything
        see
        u have to delete or rename the existing folder to use my script as it assumes start from scratch
          sdetweil @michelw
          @michelw also can u show the results of
          uname -a
            michelw @sdetweil
            @sdetweil said in OrangePi Zero 2 installation issues:
            uname -a
            sure:
            michel@orangepizero2:~$ uname -a
            Linux orangepizero2 4.9.255-sun50iw9 #2 SMP PREEMPT Thu Nov 18 08:53:39 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
            Install log:
            install starting  - Fri Dec 10 19:02:14 CET 2021
            installing on aarch64 processor system
            the os is Distributor ID: Ubuntu Description: Ubuntu 20.04.3 LTS Release: 20.04 Codename: focal
            Installing helper tools ...
            Reading package lists...
            Building dependency tree...
            Reading state information...
            pv is already the newest version (1.6.6-1).
            unzip is already the newest version (6.0-25ubuntu1).
            curl is already the newest version (7.68.0-1ubuntu2.7).
            git is already the newest version (1:2.25.1-1ubuntu3.2).
            build-essential is already the newest version (12.8ubuntu1.1).
            wget is already the newest version (1.20.3-1ubuntu2).
            Updating packages ...
            Hit:1 https://deb.nodesource.com/node_14.x focal InRelease Hit:3 http://ports.ubuntu.com focal InRelease Hit:4 http://ports.ubuntu.com focal-security InRelease Hit:5 http://ports.ubuntu.com focal-updates InRelease Hit:6 http://ports.ubuntu.com focal-backports InRelease Hit:2 http://mirror.armbian.de/apt focal InRelease Reading package lists...
            apt-get update  completed ok
            apt-get upgrade  started
            apt upgrade result =rc=0 Reading package lists...
            Calculating upgrade...
            Minimum Node version: v14.0.0
            Installed Node version: v14.18.2
            No Node.js upgrade necessary.
            Minimum npm version: V6.0.0
            Installed npm version: V6.14.15
            No npm upgrade necessary.
            Cloning MagicMirror ...
            Cloning MagicMirror Done!
            Installing dependencies ...
            > electron@13.6.3 postinstall /home/michel/MagicMirror/node_modules/electron > node install.js > magicmirror@2.17.1 install /home/michel/MagicMirror > echo "Installing vendor files ... " && cd vendor && npm install --loglevel=error Installing vendor files ... > @fortawesome/fontawesome-free@5.15.4 postinstall /home/michel/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free > node attribution.js Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License) added 9 packages from 17 contributors and audited 9 packages in 11.215s found 0 vulnerabilities > magicmirror@2.17.1 postinstall /home/michel/MagicMirror > npm run install-fonts && echo "MagicMirror installation finished successfully! " > magicmirror@2.17.1 install-fonts /home/michel/MagicMirror > echo "Installing fonts ... " && cd fonts && npm install --loglevel=error Installing fonts ... added 1 package from 1 contributor and audited 1 package in 3.224s found 0 vulnerabilities MagicMirror installation finished successfully! added 292 packages from 243 contributors and audited 923 packages in 219.336s 19 packages are looking for funding run `npm fund` for details found 0 vulnerabilities
            Dependencies installation Done!
            fixing sandbox permissions
            setting up initial config.js
            Check plymouth installation ...
            plymouth is not installed.
            install and setup pm2
            get the pm2 platform specific startup command
            startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u michel --hp /home/michel
            __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
             _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
              _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
               _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                 _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                  _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                   _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                    _\///______________\///______________\///__\///////////////__
                                      Runtime Edition
                    PM2 is a Production Process Manager for Node.js applications
                                 with a built-in Load Balancer.
                            Start and Daemonize any application:
                            $ pm2 start app.js
                            Load Balance 4 instances of api.js:
                            $ pm2 start api.js -i 4
                            Monitor in production:
                            $ pm2 monitor
                            Make pm2 auto-boot at server restart:
                            $ pm2 startup
                            To go further checkout:
                            http://pm2.io/
            [PM2] Init System found: systemd
            Platform systemd
            Template
            [Unit]
            Description=PM2 process manager
            Documentation=https://pm2.keymetrics.io/
            After=network.target
            [Service]
            Type=forking
            User=michel
            LimitNOFILE=infinity
            LimitNPROC=infinity
            LimitCORE=infinity
            Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
            Environment=PM2_HOME=/home/michel/.pm2
            PIDFile=/home/michel/.pm2/pm2.pid
            Restart=on-failure
            ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
            ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
            ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
            [Install]
            WantedBy=multi-user.target
            Target path
            /etc/systemd/system/pm2-michel.service
            Command list
            [ 'systemctl enable pm2-michel' ]
            [PM2] Writing init configuration in /etc/systemd/system/pm2-michel.service
            [PM2] Making script booting at startup...
            [PM2] [-] Executing: systemctl enable pm2-michel...
            [PM2] [v] Command successfully executed.
            [PM2] Freeze a process list on reboot via:
            $ pm2 save
            [PM2] Remove init script via:
            $ pm2 unstartup systemd
            pm2 startup command done
            configure the pm2 config file for MagicMirror
            the user is not pi
            change mm.sh
            save copy of mm.sh
            change relative home path to hard coded path
            change pm2_MagicMirror.json
            now using this config file pm2_MagicMirror_new.json
            start MagicMirror via pm2 now
            save MagicMirror pm2 config now
            stop MagicMirror via pm2 now
            disable screensaver via gsettings was true and uint32 300
            We're ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
            install completed - Fri Dec 10 19:06:47 CET 2021
              michelw
              I forgot half of my post:
              michel@orangepizero2:~$ cd MagicMirror/
              michel@orangepizero2:~/MagicMirror$ pm2 start MagicMirror
              [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
              [PM2] [MagicMirror](0) ✓
              [PM2] Process successfully started
              │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
              │ 0   │ MagicMirror    │ default     │ 2.17.1  │ fork    │ 4924     │ 0s     │ 30   │ online    │ 0%       │ 2.8mb    │ michel   │ disabled │
              Nothing on the monitor (just cli) and nothing on: http://192.168.207.243:8080/ (the IP of the mirror)
                michelw @michelw
                When I run it manually:
                [10.12.2021 19:23.11.092] [LOG]   Starting MagicMirror: v2.17.1
                [10.12.2021 19:23.11.110] [LOG]   Loading config ...
                [10.12.2021 19:23.11.124] [LOG]   Loading module helpers ...
                [10.12.2021 19:23.11.129] [LOG]   No helper found for module: alert.
                [10.12.2021 19:23.11.166] [LOG]   Initializing new module helper ...
                [10.12.2021 19:23.11.170] [LOG]   Module helper loaded: updatenotification
                [10.12.2021 19:23.11.172] [LOG]   No helper found for module: clock.
                [10.12.2021 19:23.11.507] [LOG]   Initializing new module helper ...
                [10.12.2021 19:23.11.510] [LOG]   Module helper loaded: calendar
                [10.12.2021 19:23.11.513] [LOG]   No helper found for module: compliments.
                [10.12.2021 19:23.11.515] [LOG]   No helper found for module: weather.
                [10.12.2021 19:23.11.562] [LOG]   Initializing new module helper ...
                [10.12.2021 19:23.11.564] [LOG]   Module helper loaded: newsfeed
                [10.12.2021 19:23.11.566] [LOG]   All module helpers loaded.
                [10.12.2021 19:23.11.788] [LOG]   Starting server on port 8080 ...
                [10.12.2021 19:23.11.821] [LOG]   Server started ...
                [10.12.2021 19:23.11.824] [LOG]   Connecting socket for: updatenotification
                [10.12.2021 19:23.11.827] [LOG]   Connecting socket for: calendar
                [10.12.2021 19:23.11.829] [LOG]   Starting node helper for: calendar
                [10.12.2021 19:23.11.831] [LOG]   Connecting socket for: newsfeed
                [10.12.2021 19:23.11.833] [LOG]   Starting node helper for: newsfeed
                [10.12.2021 19:23.11.835] [LOG]   Sockets connected & modules started ...
                /home/michel/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
                npm ERR! errno 1
                npm ERR!
                npm ERR!     /home/michel/.npm/_logs/2021-12-10T18_23_11_988Z-debug.log
                michel@orangepizero2:~/MagicMirror$ cat /home/michel/.npm/_logs/2021-12-10T18_23_11_988Z-debug.log
                1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'start' ]
                2 info using npm@6.14.15
                3 info using node@v14.18.2
                5 info lifecycle magicmirror@2.17.1~prestart: magicmirror@2.17.1
                6 info lifecycle magicmirror@2.17.1~start: magicmirror@2.17.1
                7 verbose lifecycle magicmirror@2.17.1~start: unsafe-perm in lifecycle true
                8 verbose lifecycle magicmirror@2.17.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/michel/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
                9 verbose lifecycle magicmirror@2.17.1~start: CWD: /home/michel/MagicMirror
                10 silly lifecycle magicmirror@2.17.1~start: Args: [
                10 silly lifecycle   '-c',
                10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js'
                10 silly lifecycle ]
                11 silly lifecycle magicmirror@2.17.1~start: Returned: code: 1  signal: null
                12 info lifecycle magicmirror@2.17.1~start: Failed to exec start script
                13 verbose stack Error: magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                13 verbose stack Exit status 1
                13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
                13 verbose stack     at EventEmitter.emit (events.js:400:28)
                13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                13 verbose stack     at ChildProcess.emit (events.js:400:28)
                13 verbose stack     at maybeClose (internal/child_process.js:1058:16)
                13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
                14 verbose pkgid magicmirror@2.17.1
                15 verbose cwd /home/michel/MagicMirror
                16 verbose Linux 4.9.255-sun50iw9
                17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "start"
                18 verbose node v14.18.2
                19 verbose npm  v6.14.15
                20 error code ELIFECYCLE
                21 error errno 1
                22 error magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                22 error Exit status 1
                23 error Failed at the magicmirror@2.17.1 start script.
                23 error This is probably not a problem with npm. There is likely additional logging output above.
                24 verbose exit [ 1, true ]
                  sdetweil @michelw
                  @michelw ok, you are running the desktop graphical version of the OS, right? you must , browser draws in graphics mode.
                  the number next to uptim ein the pm2 status is the restart count…
                  so, pm2 stop all
                  pm2 flush
                  pm2 start 0
                  wait 15 seconds
                  then pm2 logs --lines=100
                    sdetweil @michelw
                    @michelw mm installs and runs on other aarch64 systems… , ubuntu 64 on arm, Jetson Nano and Raspi with the 64bit beta OS…
                      michelw
                      Dang, that might be the issue…
                      I’ve installed this image now: https://redirect.armbian.com/orangepizero2/Buster_legacy then. That one should have desktop. https://www.armbian.com/orange-pi-zero-2/
                      Ran your script again, but now it has issues with the missing chromium browser…
                      touch: cannot touch '/etc/chromium-browser/customizations/01-disable-update-check': No such file or directory
                      tee: /etc/chromium-browser/customizations/01-disable-update-check: No such file or directory
                      install starting  - Fri Dec 10 21:09:23 CET 2021
                      the os is Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster
                      build-essential is already the newest version (12.6).
                      curl is already the newest version (7.64.0-4+deb10u2).
                      git is already the newest version (1:2.20.1-2+deb10u3).
                      unzip is already the newest version (6.0-23+deb10u2).
                      wget is already the newest version (1.20.1-1.1).
                      Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://deb.debian.org/debian buster InRelease Hit:3 http://deb.debian.org/debian buster-updates InRelease Hit:4 http://deb.debian.org/debian buster-backports InRelease Hit:5 http://armbian.12z.eu/apt buster InRelease Reading package lists...
                      Node.js is not installed.
                      Installing Node.js ...
                      Node release info = ## Installing the NodeSource Node.js 14.x repo... ## Populating apt-get cache... + apt-get update Hit:1 http://deb.debian.org/debian buster InRelease Hit:2 http://deb.debian.org/debian buster-updates InRelease Hit:3 http://security.debian.org buster/updates InRelease Hit:4 http://deb.debian.org/debian buster-backports InRelease Hit:5 http://armbian.12z.eu/apt buster InRelease Reading package lists... ## Confirming "buster" is supported... + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/buster/Release' ## Adding the NodeSource signing key to your keyring... + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 14.x repo... + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' > /etc/apt/sources.list.d/nodesource.list + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' >> /etc/apt/sources.list.d/nodesource.list ## Running `apt-get update` for you... + apt-get update Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://deb.debian.org/debian buster InRelease Hit:3 http://deb.debian.org/debian buster-updates InRelease Hit:4 http://deb.debian.org/debian buster-backports InRelease Get:5 https://deb.nodesource.com/node_14.x buster InRelease [4,584 B] Hit:6 http://xogium.performanceservers.nl/apt buster InRelease Get:7 https://deb.nodesource.com/node_14.x buster/main armhf Packages [779 B] Get:8 https://deb.nodesource.com/node_14.x buster/main arm64 Packages [770 B] Fetched 6,133 B in 3s (1,867 B/s) Reading package lists... ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
                      v14.18.2
                      Node.js installation Done! version=v14.18.2
                      > electron@13.6.3 postinstall /home/michel/MagicMirror/node_modules/electron > node install.js > magicmirror@2.17.1 install /home/michel/MagicMirror > echo "Installing vendor files ... " && cd vendor && npm install --loglevel=error Installing vendor files ... > @fortawesome/fontawesome-free@5.15.4 postinstall /home/michel/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free > node attribution.js Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License) added 9 packages from 17 contributors and audited 9 packages in 10.954s found 0 vulnerabilities > magicmirror@2.17.1 postinstall /home/michel/MagicMirror > npm run install-fonts && echo "MagicMirror installation finished successfully! " > magicmirror@2.17.1 install-fonts /home/michel/MagicMirror > echo "Installing fonts ... " && cd fonts && npm install --loglevel=error Installing fonts ... added 1 package from 1 contributor and audited 1 package in 2.736s found 0 vulnerabilities MagicMirror installation finished successfully! added 292 packages from 243 contributors and audited 923 packages in 174.077s 19 packages are looking for funding run `npm fund` for details found 0 vulnerabilities
                      pm2 not installed, installing
                      pm2 install result npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. /usr/bin/pm2 -> /usr/lib/node_modules/pm2/bin/pm2 /usr/bin/pm2-docker -> /usr/lib/node_modules/pm2/bin/pm2-docker /usr/bin/pm2-dev -> /usr/lib/node_modules/pm2/bin/pm2-dev /usr/bin/pm2-runtime -> /usr/lib/node_modules/pm2/bin/pm2-runtime npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/pm2/node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"}) + pm2@5.1.2 added 180 packages from 200 contributors in 48.379s
                                                Runtime Edition
                                      $ pm2 start app.js
                                      $ pm2 monitor
                                      $ pm2 startup
                                      http://pm2.io/
                      Platform systemd
                      Template
                      [Unit]
                      [Service]
                      Type=forking
                      User=michel
                      LimitNPROC=infinity
                      LimitCORE=infinity
                      Restart=on-failure
                      [Install]
                      Target path
                      Command list
                      $ pm2 save
                      the user is not pi
                      change mm.sh
                      save copy of mm.sh
                      install completed - Fri Dec 10 21:15:14 CET 2021
                      I really need this to run on the orange pi zero 2 as I have no other option available. :(
                        sdetweil @michelw
                        @michelw that chrome issue is nothing. try to disable the click to update, if u have no mouse! duh.
                        but won’t affect you
                          sdetweil @michelw
                          @michelw show the pm2 logs --lines=50 output
                          should have been ok…
                            michelw
                            michel@magicmirror:~/MagicMirror$ pm2 logs --lines=50
                            [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
                            /home/michel/.pm2/pm2.log last 50 lines:
                            PM2        | 2021-12-10T21:25:51: PM2 log: Stopping app:MagicMirror id:0
                            PM2        | 2021-12-10T21:25:51: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                            PM2        | 2021-12-10T21:25:51: PM2 log: pid=19681 msg=process killed
                            PM2        | 2021-12-10T21:25:51: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:25:51: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:25:56: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:25:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:25:56: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:00: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:05: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:05: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:05: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:09: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:09: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:09: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:14: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:14: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:14: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:18: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:18: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:18: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:23: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:23: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:23: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:27: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:27: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:27: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:32: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:32: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:32: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:36: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:36: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:36: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:41: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:41: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:41: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:46: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:46: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:46: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:50: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:50: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:50: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:55: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:55: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:55: PM2 log: App [MagicMirror:0] online
                            PM2        | 2021-12-10T21:26:59: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2        | 2021-12-10T21:26:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
                            PM2        | 2021-12-10T21:26:59: PM2 log: App [MagicMirror:0] online
                            /home/michel/.pm2/logs/MagicMirror-error.log last 50 lines:
                            0|MagicMir | npm ERR! A complete log of this run can be found in:
                            0|MagicMir | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_26_41_486Z-debug.log
                            0|MagicMir | The futex facility returned an unexpected error code.
                            0|MagicMir | /home/michel/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                            0|MagicMir | npm ERR! code ELIFECYCLE
                            0|MagicMir | npm ERR! errno 1
                            0|MagicMir | npm ERR! magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                            0|MagicMir | npm ERR! Exit status 1
                            0|MagicMir | npm ERR! Failed at the magicmirror@2.17.1 start script.
                            0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                            0|MagicMir |
                            0|MagicMir | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_26_46_011Z-debug.log
                            0|MagicMir |
                            0|MagicMir | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_26_50_521Z-debug.log
                            0|MagicMir |
                            0|MagicMir | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_26_54_958Z-debug.log
                            0|MagicMir |
                            0|MagicMir | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_26_59_382Z-debug.log
                            /home/michel/.pm2/logs/MagicMirror-out.log last 50 lines:
                            0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                            0|MagicMir |
                            0|MagicMir | [10.12.2021 21:26.58.491] [LOG]   Starting MagicMirror: v2.17.1
                            0|MagicMir | [10.12.2021 21:26.58.507] [LOG]   Loading config ...
                            0|MagicMir | [10.12.2021 21:26.58.521] [LOG]   Loading module helpers ...
                            0|MagicMir | [10.12.2021 21:26.58.526] [LOG]   No helper found for module: alert.
                            0|MagicMir | [10.12.2021 21:26.58.564] [LOG]   Initializing new module helper ...
                            0|MagicMir | [10.12.2021 21:26.58.567] [LOG]   Module helper loaded: updatenotification
                            0|MagicMir | [10.12.2021 21:26.58.570] [LOG]   No helper found for module: clock.
                            0|MagicMir | [10.12.2021 21:26.58.905] [LOG]   Initializing new module helper ...
                            0|MagicMir | [10.12.2021 21:26.58.907] [LOG]   Module helper loaded: calendar
                            0|MagicMir | [10.12.2021 21:26.58.910] [LOG]   No helper found for module: compliments.
                            0|MagicMir | [10.12.2021 21:26.58.912] [LOG]   No helper found for module: weather.
                            0|MagicMir | [10.12.2021 21:26.58.960] [LOG]   Initializing new module helper ...
                            0|MagicMir | [10.12.2021 21:26.58.962] [LOG]   Module helper loaded: newsfeed
                            0|MagicMir | [10.12.2021 21:26.58.963] [LOG]   All module helpers loaded.
                            0|MagicMir | [10.12.2021 21:26.59.187] [LOG]   Starting server on port 8080 ...
                            0|MagicMir | [10.12.2021 21:26.59.221] [LOG]   Server started ...
                            0|MagicMir | [10.12.2021 21:26.59.224] [LOG]   Connecting socket for: updatenotification
                            0|MagicMir | [10.12.2021 21:26.59.227] [LOG]   Connecting socket for: calendar
                            0|MagicMir | [10.12.2021 21:26.59.229] [LOG]   Starting node helper for: calendar
                            0|MagicMir | [10.12.2021 21:26.59.231] [LOG]   Connecting socket for: newsfeed
                            0|MagicMir | [10.12.2021 21:26.59.233] [LOG]   Starting node helper for: newsfeed
                            0|MagicMir | [10.12.2021 21:26.59.234] [LOG]   Sockets connected & modules started ...
                            0|MagicMir |
                            0|MagicMir | > magicmirror@2.17.1 start /home/michel/MagicMirror
                            0|MagicMir |
                            0|MagicMir | [10.12.2021 21:27.03.032] [LOG]   Starting MagicMirror: v2.17.1
                            0|MagicMir | [10.12.2021 21:27.03.053] [LOG]   Loading config ...
                            0|MagicMir | [10.12.2021 21:27.03.070] [LOG]   Loading module helpers ...
                            0|MagicMir | [10.12.2021 21:27.03.076] [LOG]   No helper found for module: alert.
                            0|MagicMir | [10.12.2021 21:27.03.121] [LOG]   Initializing new module helper ...
                            0|MagicMir | [10.12.2021 21:27.03.125] [LOG]   Module helper loaded: updatenotification
                            0|MagicMir | [10.12.2021 21:27.03.129] [LOG]   No helper found for module: clock.
                            0|MagicMir | [10.12.2021 21:27.03.543] [LOG]   Initializing new module helper ...
                            0|MagicMir | [10.12.2021 21:27.03.546] [LOG]   Module helper loaded: calendar
                            0|MagicMir | [10.12.2021 21:27.03.549] [LOG]   No helper found for module: compliments.
                            0|MagicMir | [10.12.2021 21:27.03.552] [LOG]   No helper found for module: weather.
                            0|MagicMir | [10.12.2021 21:27.03.609] [LOG]   Initializing new module helper ...
                            0|MagicMir | [10.12.2021 21:27.03.611] [LOG]   Module helper loaded: newsfeed
                            0|MagicMir | [10.12.2021 21:27.03.613] [LOG]   All module helpers loaded.
                            0|MagicMir | [10.12.2021 21:27.03.893] [LOG]   Starting server on port 8080 ...
                            0|MagicMir | [10.12.2021 21:27.03.939] [LOG]   Server started ...
                            0|MagicMir | [10.12.2021 21:27.03.943] [LOG]   Connecting socket for: updatenotification
                            0|MagicMir | [10.12.2021 21:27.03.947] [LOG]   Connecting socket for: calendar
                            0|MagicMir | [10.12.2021 21:27.03.950] [LOG]   Starting node helper for: calendar
                            0|MagicMir | [10.12.2021 21:27.03.953] [LOG]   Connecting socket for: newsfeed
                            0|MagicMir | [10.12.2021 21:27.03.955] [LOG]   Starting node helper for: newsfeed
                            0|MagicMir | [10.12.2021 21:27.03.958] [LOG]   Sockets connected & modules started ...
                            0|MagicMirror  | The futex facility returned an unexpected error code.
                            0|MagicMirror  | /home/michel/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                            0|MagicMirror  | npm
                            0|MagicMirror  |  ERR! code ELIFECYCLE
                            0|MagicMirror  | npm ERR!
                            0|MagicMirror  | errno 1
                            0|MagicMirror  |  magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                            0|MagicMirror  | npm ERR! Exit status 1
                            0|MagicMirror  | npm ERR! Failed at the magicmirror@2.17.1 start script.
                            0|MagicMirror  | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                            0|MagicMirror  | npm ERR! A complete log of this run can be found in:
                            0|MagicMirror  | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_27_04_227Z-debug.log
                            PM2            | App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                            PM2            | App [MagicMirror:0] starting in -fork mode-
                            PM2            | App [MagicMirror:0] online
                            0|MagicMirror  | > magicmirror@2.17.1 start /home/michel/MagicMirror
                            0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                            0|MagicMirror  | [10.12.2021 21:27.07.756] [LOG]
                            0|MagicMirror  | Starting MagicMirror: v2.17.1
                            0|MagicMirror  | [10.12.2021 21:27.07.774] [LOG]
                            0|MagicMirror  | Loading config ...
                            0|MagicMirror  | [10.12.2021 21:27.07.790] [LOG]
                            0|MagicMirror  | Loading module helpers ...
                            0|MagicMirror  | [10.12.2021 21:27.07.796] [LOG]
                            0|MagicMirror  | No helper found for module: alert.
                            0|MagicMirror  | [10.12.2021 21:27.07.835] [LOG]
                            0|MagicMirror  | Initializing new module helper ...
                            0|MagicMirror  | [10.12.2021 21:27.07.839] [LOG]
                            0|MagicMirror  | Module helper loaded: updatenotification
                            0|MagicMirror  | [10.12.2021 21:27.07.843] [LOG]   No helper found for module: clock.
                            0|MagicMirror  | [10.12.2021 21:27.08.182] [LOG]
                            0|MagicMirror  | [10.12.2021 21:27.08.184] [LOG]
                            0|MagicMirror  | Module helper loaded: calendar
                            0|MagicMirror  | [10.12.2021 21:27.08.188] [LOG]   No helper found for module: compliments.
                            0|MagicMirror  | [10.12.2021 21:27.08.191] [LOG]
                            0|MagicMirror  | No helper found for module: weather.
                            0|MagicMirror  | [10.12.2021 21:27.08.241] [LOG]
                            0|MagicMirror  | [10.12.2021 21:27.08.243] [LOG]
                            0|MagicMirror  | Module helper loaded: newsfeed
                            0|MagicMirror  | [10.12.2021 21:27.08.245] [LOG]   All module helpers loaded.
                            0|MagicMirror  | [10.12.2021 21:27.08.471] [LOG]
                            0|MagicMirror  | Starting server on port 8080 ...
                            0|MagicMirror  | [10.12.2021 21:27.08.505] [LOG]
                            0|MagicMirror  | Server started ...
                            0|MagicMirror  | [10.12.2021 21:27.08.508] [LOG]   Connecting socket for: updatenotification
                            0|MagicMirror  | [10.12.2021 21:27.08.512] [LOG]
                            0|MagicMirror  | Connecting socket for: calendar
                            0|MagicMirror  | [10.12.2021 21:27.08.515] [LOG]   Starting node helper for: calendar
                            0|MagicMirror  | [10.12.2021 21:27.08.518] [LOG]   Connecting socket for: newsfeed
                            0|MagicMirror  | [10.12.2021 21:27.08.520] [LOG]   Starting node helper for: newsfeed
                            0|MagicMirror  | [10.12.2021 21:27.08.522] [LOG]   Sockets connected & modules started ...
                            0|MagicMirror  | npm
                            0|MagicMirror  | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_27_08_775Z-debug.log
                              sdetweil @michelw
                              @michelw do
                              pm2 stop all
                              export DISPLAY=:0
                              npm start
                                sdetweil @michelw
                                @michelw your xwindows might have a different numbering, so use that
                                  michelw @sdetweil
                                  Not sure what you mean. I am not a linux expert ;)
                                  michel@magicmirror:~$ pm2 stop all
                                  [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                                  │ 0   │ MagicMirror    │ default     │ 2.17.1  │ fork    │ 0        │ 0      │ 396  │ stopped   │ 0%       │ 0b       │ michel   │ disabled │
                                  michel@magicmirror:~$ export DISPLAY=:0
                                  michel@magicmirror:~$ cd ~/MagicMirror
                                  michel@magicmirror:~/MagicMirror$ npm start
                                  [10.12.2021 22:32.33.528] [LOG]   Starting MagicMirror: v2.17.1
                                  [10.12.2021 22:32.33.544] [LOG]   Loading config ...
                                  [10.12.2021 22:32.33.558] [LOG]   Loading module helpers ...
                                  [10.12.2021 22:32.33.563] [LOG]   No helper found for module: alert.
                                  [10.12.2021 22:32.33.600] [LOG]   Initializing new module helper ...
                                  [10.12.2021 22:32.33.603] [LOG]   Module helper loaded: updatenotification
                                  [10.12.2021 22:32.33.606] [LOG]   No helper found for module: clock.
                                  [10.12.2021 22:32.33.953] [LOG]   Initializing new module helper ...
                                  [10.12.2021 22:32.33.955] [LOG]   Module helper loaded: calendar
                                  [10.12.2021 22:32.33.958] [LOG]   No helper found for module: compliments.
                                  [10.12.2021 22:32.33.960] [LOG]   No helper found for module: weather.
                                  [10.12.2021 22:32.33.997] [LOG]   Initializing new module helper ...
                                  [10.12.2021 22:32.33.999] [LOG]   Module helper loaded: newsfeed
                                  [10.12.2021 22:32.34.001] [LOG]   All module helpers loaded.
                                  [10.12.2021 22:32.34.223] [LOG]   Starting server on port 8080 ...
                                  [10.12.2021 22:32.34.255] [LOG]   Server started ...
                                  [10.12.2021 22:32.34.258] [LOG]   Connecting socket for: updatenotification
                                  [10.12.2021 22:32.34.260] [LOG]   Connecting socket for: calendar
                                  [10.12.2021 22:32.34.262] [LOG]   Starting node helper for: calendar
                                  [10.12.2021 22:32.34.264] [LOG]   Connecting socket for: newsfeed
                                  [10.12.2021 22:32.34.266] [LOG]   Starting node helper for: newsfeed
                                  [10.12.2021 22:32.34.268] [LOG]   Sockets connected & modules started ...
                                  npm ERR! errno 1
                                  npm ERR!
                                  npm ERR!     /home/michel/.npm/_logs/2021-12-10T21_32_34_516Z-debug.log
                                  Found this somewhere:
                                  michel@magicmirror:~/MagicMirror$ ps -u $(id -u) -o pid= \
                                  >     | xargs -I PID -r cat /proc/PID/environ 2> /dev/null \
                                  >     | tr '\0' '\n' \
                                  >     | grep ^DISPLAY=: \
                                  >     | sort -u
                                  DISPLAY=:0
                                    sdetweil @michelw
                                    @michelw xwindows has logical displays, using numbers for the ‘identifiet’
                                    :0
                                    etc…
                                    some systems use different numbering
                                    my zorin system uses :10
                                    electron expects that I’d to be in the DISPLAY environment variable
                                    so, open a terminal window and do
                                    env
                                    show the result
                                      michelw @sdetweil
                                      env
                                      michel@orangepizero2:~$ env
                                      SHELL=/bin/bash
                                      LANGUAGE=en_US.UTF-8
                                      PWD=/home/michel
                                      LOGNAME=michel
                                      XDG_SESSION_TYPE=tty
                                      HOME=/home/michel
                                      LANG=en_US.UTF-8
                                      LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
                                      SSH_CONNECTION=192.168.207.6 61754 192.168.207.243 22
                                      XDG_SESSION_CLASS=user
                                      TERM=xterm-256color
                                      USER=michel
                                      SHLVL=1
                                      LC_MESSAGES=en_US.UTF-8
                                      XDG_SESSION_ID=4
                                      LC_CTYPE=UTF-8
                                      XDG_RUNTIME_DIR=/run/user/1001
                                      SSH_CLIENT=192.168.207.6 61754 22
                                      LC_ALL=en_US.UTF-8
                                      PATH=/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
                                      MAIL=/var/mail/michel
                                      SSH_TTY=/dev/pts/0
                                      _=/usr/bin/env
                                        sdetweil @michelw
                                        @michelw that was a window opened via the desktop right?
                                          michelw @sdetweil
                                          Not sure I understand what you mean. I’m doing all of this using ssh.
                                            michelw @michelw
