    OrangePi Zero 2 installation issues
    41 Posts 2 Posters 11.2k Views 2 Watching
      michelw @sdetweil
      @sdetweil said in OrangePi Zero 2 installation issues:
      uname -a
      sure:
      michel@orangepizero2:~$ uname -a
      Linux orangepizero2 4.9.255-sun50iw9 #2 SMP PREEMPT Thu Nov 18 08:53:39 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
      Install log:
      install starting  - Fri Dec 10 19:02:14 CET 2021
      installing on aarch64 processor system
      the os is Distributor ID: Ubuntu Description: Ubuntu 20.04.3 LTS Release: 20.04 Codename: focal
      Installing helper tools ...
      Reading package lists...
      Building dependency tree...
      Reading state information...
      pv is already the newest version (1.6.6-1).
      unzip is already the newest version (6.0-25ubuntu1).
      curl is already the newest version (7.68.0-1ubuntu2.7).
      git is already the newest version (1:2.25.1-1ubuntu3.2).
      build-essential is already the newest version (12.8ubuntu1.1).
      wget is already the newest version (1.20.3-1ubuntu2).
      Updating packages ...
      Hit:1 https://deb.nodesource.com/node_14.x focal InRelease Hit:3 http://ports.ubuntu.com focal InRelease Hit:4 http://ports.ubuntu.com focal-security InRelease Hit:5 http://ports.ubuntu.com focal-updates InRelease Hit:6 http://ports.ubuntu.com focal-backports InRelease Hit:2 http://mirror.armbian.de/apt focal InRelease Reading package lists...
      apt-get update  completed ok
      apt-get upgrade  started
      apt upgrade result =rc=0 Reading package lists...
      Calculating upgrade...
      Minimum Node version: v14.0.0
      Installed Node version: v14.18.2
      No Node.js upgrade necessary.
      Minimum npm version: V6.0.0
      Installed npm version: V6.14.15
      No npm upgrade necessary.
      Cloning MagicMirror ...
      Cloning MagicMirror Done!
      Installing dependencies ...
      > electron@13.6.3 postinstall /home/michel/MagicMirror/node_modules/electron > node install.js > magicmirror@2.17.1 install /home/michel/MagicMirror > echo "Installing vendor files ... " && cd vendor && npm install --loglevel=error Installing vendor files ... > @fortawesome/fontawesome-free@5.15.4 postinstall /home/michel/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free > node attribution.js Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License) added 9 packages from 17 contributors and audited 9 packages in 11.215s found 0 vulnerabilities > magicmirror@2.17.1 postinstall /home/michel/MagicMirror > npm run install-fonts && echo "MagicMirror installation finished successfully! " > magicmirror@2.17.1 install-fonts /home/michel/MagicMirror > echo "Installing fonts ... " && cd fonts && npm install --loglevel=error Installing fonts ... added 1 package from 1 contributor and audited 1 package in 3.224s found 0 vulnerabilities MagicMirror installation finished successfully! added 292 packages from 243 contributors and audited 923 packages in 219.336s 19 packages are looking for funding run `npm fund` for details found 0 vulnerabilities
      Dependencies installation Done!
      fixing sandbox permissions
      setting up initial config.js
      Check plymouth installation ...
      plymouth is not installed.
      install and setup pm2
      get the pm2 platform specific startup command
      startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u michel --hp /home/michel
      __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
       _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
        _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
         _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
          _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
           _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
            _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
             _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
              _\///______________\///______________\///__\///////////////__
                                Runtime Edition
              PM2 is a Production Process Manager for Node.js applications
                           with a built-in Load Balancer.
                      Start and Daemonize any application:
                      $ pm2 start app.js
                      Load Balance 4 instances of api.js:
                      $ pm2 start api.js -i 4
                      Monitor in production:
                      $ pm2 monitor
                      Make pm2 auto-boot at server restart:
                      $ pm2 startup
                      To go further checkout:
                      http://pm2.io/
      [PM2] Init System found: systemd
      Platform systemd
      Template
      [Unit]
      Description=PM2 process manager
      Documentation=https://pm2.keymetrics.io/
      After=network.target
      [Service]
      Type=forking
      User=michel
      LimitNOFILE=infinity
      LimitNPROC=infinity
      LimitCORE=infinity
      Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
      Environment=PM2_HOME=/home/michel/.pm2
      PIDFile=/home/michel/.pm2/pm2.pid
      Restart=on-failure
      ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
      ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
      ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
      [Install]
      WantedBy=multi-user.target
      Target path
      /etc/systemd/system/pm2-michel.service
      Command list
      [ 'systemctl enable pm2-michel' ]
      [PM2] Writing init configuration in /etc/systemd/system/pm2-michel.service
      [PM2] Making script booting at startup...
      [PM2] [-] Executing: systemctl enable pm2-michel...
      [PM2] [v] Command successfully executed.
      [PM2] Freeze a process list on reboot via:
      $ pm2 save
      [PM2] Remove init script via:
      $ pm2 unstartup systemd
      pm2 startup command done
      configure the pm2 config file for MagicMirror
      the user is not pi
      change mm.sh
      save copy of mm.sh
      change relative home path to hard coded path
      change pm2_MagicMirror.json
      now using this config file pm2_MagicMirror_new.json
      start MagicMirror via pm2 now
      save MagicMirror pm2 config now
      stop MagicMirror via pm2 now
      disable screensaver via gsettings was true and uint32 300
      We're ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
      install completed - Fri Dec 10 19:06:47 CET 2021
        michelw
        I forgot half of my post:
        michel@orangepizero2:~$ cd MagicMirror/
        michel@orangepizero2:~/MagicMirror$ pm2 start MagicMirror
        [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
        [PM2] [MagicMirror](0) ✓
        [PM2] Process successfully started
        │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
        │ 0   │ MagicMirror    │ default     │ 2.17.1  │ fork    │ 4924     │ 0s     │ 30   │ online    │ 0%       │ 2.8mb    │ michel   │ disabled │
        Nothing on the monitor (just cli) and nothing on: http://192.168.207.243:8080/ (the IP of the mirror)
          michelw @michelw
          When I run it manually:
          michel@orangepizero2:~/MagicMirror$ npm run start
          > magicmirror@2.17.1 start /home/michel/MagicMirror
          [10.12.2021 19:23.11.092] [LOG]   Starting MagicMirror: v2.17.1
          [10.12.2021 19:23.11.110] [LOG]   Loading config ...
          [10.12.2021 19:23.11.124] [LOG]   Loading module helpers ...
          [10.12.2021 19:23.11.129] [LOG]   No helper found for module: alert.
          [10.12.2021 19:23.11.166] [LOG]   Initializing new module helper ...
          [10.12.2021 19:23.11.170] [LOG]   Module helper loaded: updatenotification
          [10.12.2021 19:23.11.172] [LOG]   No helper found for module: clock.
          [10.12.2021 19:23.11.507] [LOG]   Initializing new module helper ...
          [10.12.2021 19:23.11.510] [LOG]   Module helper loaded: calendar
          [10.12.2021 19:23.11.513] [LOG]   No helper found for module: compliments.
          [10.12.2021 19:23.11.515] [LOG]   No helper found for module: weather.
          [10.12.2021 19:23.11.562] [LOG]   Initializing new module helper ...
          [10.12.2021 19:23.11.564] [LOG]   Module helper loaded: newsfeed
          [10.12.2021 19:23.11.566] [LOG]   All module helpers loaded.
          [10.12.2021 19:23.11.788] [LOG]   Starting server on port 8080 ...
          [10.12.2021 19:23.11.821] [LOG]   Server started ...
          [10.12.2021 19:23.11.824] [LOG]   Connecting socket for: updatenotification
          [10.12.2021 19:23.11.827] [LOG]   Connecting socket for: calendar
          [10.12.2021 19:23.11.829] [LOG]   Starting node helper for: calendar
          [10.12.2021 19:23.11.831] [LOG]   Connecting socket for: newsfeed
          [10.12.2021 19:23.11.833] [LOG]   Starting node helper for: newsfeed
          [10.12.2021 19:23.11.835] [LOG]   Sockets connected & modules started ...
          /home/michel/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.17.1 start script.
          npm ERR!     /home/michel/.npm/_logs/2021-12-10T18_23_11_988Z-debug.log
          michel@orangepizero2:~/MagicMirror$ cat /home/michel/.npm/_logs/2021-12-10T18_23_11_988Z-debug.log
          1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'run', 'start' ]
          2 info using npm@6.14.15
          3 info using node@v14.18.2
          5 info lifecycle magicmirror@2.17.1~prestart: magicmirror@2.17.1
          6 info lifecycle magicmirror@2.17.1~start: magicmirror@2.17.1
          7 verbose lifecycle magicmirror@2.17.1~start: unsafe-perm in lifecycle true
          8 verbose lifecycle magicmirror@2.17.1~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/michel/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
          9 verbose lifecycle magicmirror@2.17.1~start: CWD: /home/michel/MagicMirror
          10 silly lifecycle magicmirror@2.17.1~start: Args: [
          10 silly lifecycle   '-c',
          10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js'
          10 silly lifecycle ]
          11 silly lifecycle magicmirror@2.17.1~start: Returned: code: 1  signal: null
          12 info lifecycle magicmirror@2.17.1~start: Failed to exec start script
          13 verbose stack Error: magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
          13 verbose stack Exit status 1
          13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
          13 verbose stack     at EventEmitter.emit (events.js:400:28)
          13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
          13 verbose stack     at ChildProcess.emit (events.js:400:28)
          13 verbose stack     at maybeClose (internal/child_process.js:1058:16)
          13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:293:5)
          14 verbose pkgid magicmirror@2.17.1
          15 verbose cwd /home/michel/MagicMirror
          16 verbose Linux 4.9.255-sun50iw9
          17 verbose argv "/usr/bin/node" "/usr/bin/npm" "run" "start"
          18 verbose node v14.18.2
          19 verbose npm  v6.14.15
          20 error code ELIFECYCLE
          21 error errno 1
          22 error magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
          22 error Exit status 1
          23 error Failed at the magicmirror@2.17.1 start script.
          23 error This is probably not a problem with npm. There is likely additional logging output above.
          24 verbose exit [ 1, true ]
            sdetweil @michelw
            @michelw ok, you are running the desktop graphical version of the OS, right? you must , browser draws in graphics mode.
            the number next to uptim ein the pm2 status is the restart count…
            so, pm2 stop all
            pm2 flush
            pm2 start 0
            wait 15 seconds
            then pm2 logs --lines=100
              sdetweil @michelw
              @michelw mm installs and runs on other aarch64 systems… , ubuntu 64 on arm, Jetson Nano and Raspi with the 64bit beta OS…
                michelw
                Dang, that might be the issue…
                I’ve installed this image now: https://redirect.armbian.com/orangepizero2/Buster_legacy then. That one should have desktop. https://www.armbian.com/orange-pi-zero-2/
                Ran your script again, but now it has issues with the missing chromium browser…
                touch: cannot touch '/etc/chromium-browser/customizations/01-disable-update-check': No such file or directory
                tee: /etc/chromium-browser/customizations/01-disable-update-check: No such file or directory
                install starting  - Fri Dec 10 21:09:23 CET 2021
                the os is Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster
                build-essential is already the newest version (12.6).
                curl is already the newest version (7.64.0-4+deb10u2).
                git is already the newest version (1:2.20.1-2+deb10u3).
                unzip is already the newest version (6.0-23+deb10u2).
                wget is already the newest version (1.20.1-1.1).
                Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://deb.debian.org/debian buster InRelease Hit:3 http://deb.debian.org/debian buster-updates InRelease Hit:4 http://deb.debian.org/debian buster-backports InRelease Hit:5 http://armbian.12z.eu/apt buster InRelease Reading package lists...
                Node.js is not installed.
                Installing Node.js ...
                Node release info = ## Installing the NodeSource Node.js 14.x repo... ## Populating apt-get cache... + apt-get update Hit:1 http://deb.debian.org/debian buster InRelease Hit:2 http://deb.debian.org/debian buster-updates InRelease Hit:3 http://security.debian.org buster/updates InRelease Hit:4 http://deb.debian.org/debian buster-backports InRelease Hit:5 http://armbian.12z.eu/apt buster InRelease Reading package lists... ## Confirming "buster" is supported... + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/buster/Release' ## Adding the NodeSource signing key to your keyring... + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null ## Creating apt sources list file for the NodeSource Node.js 14.x repo... + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' > /etc/apt/sources.list.d/nodesource.list + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' >> /etc/apt/sources.list.d/nodesource.list ## Running `apt-get update` for you... + apt-get update Hit:1 http://security.debian.org buster/updates InRelease Hit:2 http://deb.debian.org/debian buster InRelease Hit:3 http://deb.debian.org/debian buster-updates InRelease Hit:4 http://deb.debian.org/debian buster-backports InRelease Get:5 https://deb.nodesource.com/node_14.x buster InRelease [4,584 B] Hit:6 http://xogium.performanceservers.nl/apt buster InRelease Get:7 https://deb.nodesource.com/node_14.x buster/main armhf Packages [779 B] Get:8 https://deb.nodesource.com/node_14.x buster/main arm64 Packages [770 B] Fetched 6,133 B in 3s (1,867 B/s) Reading package lists... ## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
                v14.18.2
                Node.js installation Done! version=v14.18.2
                > electron@13.6.3 postinstall /home/michel/MagicMirror/node_modules/electron > node install.js > magicmirror@2.17.1 install /home/michel/MagicMirror > echo "Installing vendor files ... " && cd vendor && npm install --loglevel=error Installing vendor files ... > @fortawesome/fontawesome-free@5.15.4 postinstall /home/michel/MagicMirror/vendor/node_modules/@fortawesome/fontawesome-free > node attribution.js Font Awesome Free 5.15.4 by @fontawesome - https://fontawesome.com License - https://fontawesome.com/license/free (Icons: CC BY 4.0, Fonts: SIL OFL 1.1, Code: MIT License) added 9 packages from 17 contributors and audited 9 packages in 10.954s found 0 vulnerabilities > magicmirror@2.17.1 postinstall /home/michel/MagicMirror > npm run install-fonts && echo "MagicMirror installation finished successfully! " > magicmirror@2.17.1 install-fonts /home/michel/MagicMirror > echo "Installing fonts ... " && cd fonts && npm install --loglevel=error Installing fonts ... added 1 package from 1 contributor and audited 1 package in 2.736s found 0 vulnerabilities MagicMirror installation finished successfully! added 292 packages from 243 contributors and audited 923 packages in 174.077s 19 packages are looking for funding run `npm fund` for details found 0 vulnerabilities
                pm2 not installed, installing
                pm2 install result npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details. /usr/bin/pm2 -> /usr/lib/node_modules/pm2/bin/pm2 /usr/bin/pm2-docker -> /usr/lib/node_modules/pm2/bin/pm2-docker /usr/bin/pm2-dev -> /usr/lib/node_modules/pm2/bin/pm2-dev /usr/bin/pm2-runtime -> /usr/lib/node_modules/pm2/bin/pm2-runtime npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/pm2/node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"}) + pm2@5.1.2 added 180 packages from 200 contributors in 48.379s
                                          Runtime Edition
                                $ pm2 start app.js
                                $ pm2 monitor
                                $ pm2 startup
                                http://pm2.io/
                Platform systemd
                Template
                [Unit]
                [Service]
                Type=forking
                User=michel
                LimitNPROC=infinity
                LimitCORE=infinity
                Restart=on-failure
                [Install]
                Target path
                Command list
                $ pm2 save
                the user is not pi
                change mm.sh
                save copy of mm.sh
                install completed - Fri Dec 10 21:15:14 CET 2021
                I really need this to run on the orange pi zero 2 as I have no other option available. :(
                  sdetweil @michelw
                  @michelw that chrome issue is nothing. try to disable the click to update, if u have no mouse! duh.
                  but won’t affect you
                    sdetweil @michelw
                    @michelw show the pm2 logs --lines=50 output
                    should have been ok…
                      michelw
                      michel@magicmirror:~/MagicMirror$ pm2 logs --lines=50
                      [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
                      /home/michel/.pm2/pm2.log last 50 lines:
                      PM2        | 2021-12-10T21:25:51: PM2 log: Stopping app:MagicMirror id:0
                      PM2        | 2021-12-10T21:25:51: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                      PM2        | 2021-12-10T21:25:51: PM2 log: pid=19681 msg=process killed
                      PM2        | 2021-12-10T21:25:51: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:25:51: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:25:56: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:25:56: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:25:56: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:00: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:00: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:00: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:05: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:05: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:05: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:09: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:09: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:09: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:14: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:14: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:14: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:18: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:18: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:18: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:23: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:23: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:23: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:27: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:27: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:27: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:32: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:32: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:32: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:36: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:36: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:36: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:41: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:41: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:41: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:46: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:46: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:46: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:50: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:50: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:50: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:55: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:55: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:55: PM2 log: App [MagicMirror:0] online
                      PM2        | 2021-12-10T21:26:59: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2        | 2021-12-10T21:26:59: PM2 log: App [MagicMirror:0] starting in -fork mode-
                      PM2        | 2021-12-10T21:26:59: PM2 log: App [MagicMirror:0] online
                      /home/michel/.pm2/logs/MagicMirror-error.log last 50 lines:
                      0|MagicMir | npm ERR! A complete log of this run can be found in:
                      0|MagicMir | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_26_41_486Z-debug.log
                      0|MagicMir | The futex facility returned an unexpected error code.
                      0|MagicMir | /home/michel/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                      0|MagicMir | npm ERR! code ELIFECYCLE
                      0|MagicMir | npm ERR! errno 1
                      0|MagicMir | npm ERR! magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                      0|MagicMir | npm ERR! Exit status 1
                      0|MagicMir | npm ERR! Failed at the magicmirror@2.17.1 start script.
                      0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                      0|MagicMir |
                      0|MagicMir | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_26_46_011Z-debug.log
                      0|MagicMir |
                      0|MagicMir | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_26_50_521Z-debug.log
                      0|MagicMir |
                      0|MagicMir | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_26_54_958Z-debug.log
                      0|MagicMir |
                      0|MagicMir | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_26_59_382Z-debug.log
                      /home/michel/.pm2/logs/MagicMirror-out.log last 50 lines:
                      0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      0|MagicMir |
                      0|MagicMir | [10.12.2021 21:26.58.491] [LOG]   Starting MagicMirror: v2.17.1
                      0|MagicMir | [10.12.2021 21:26.58.507] [LOG]   Loading config ...
                      0|MagicMir | [10.12.2021 21:26.58.521] [LOG]   Loading module helpers ...
                      0|MagicMir | [10.12.2021 21:26.58.526] [LOG]   No helper found for module: alert.
                      0|MagicMir | [10.12.2021 21:26.58.564] [LOG]   Initializing new module helper ...
                      0|MagicMir | [10.12.2021 21:26.58.567] [LOG]   Module helper loaded: updatenotification
                      0|MagicMir | [10.12.2021 21:26.58.570] [LOG]   No helper found for module: clock.
                      0|MagicMir | [10.12.2021 21:26.58.905] [LOG]   Initializing new module helper ...
                      0|MagicMir | [10.12.2021 21:26.58.907] [LOG]   Module helper loaded: calendar
                      0|MagicMir | [10.12.2021 21:26.58.910] [LOG]   No helper found for module: compliments.
                      0|MagicMir | [10.12.2021 21:26.58.912] [LOG]   No helper found for module: weather.
                      0|MagicMir | [10.12.2021 21:26.58.960] [LOG]   Initializing new module helper ...
                      0|MagicMir | [10.12.2021 21:26.58.962] [LOG]   Module helper loaded: newsfeed
                      0|MagicMir | [10.12.2021 21:26.58.963] [LOG]   All module helpers loaded.
                      0|MagicMir | [10.12.2021 21:26.59.187] [LOG]   Starting server on port 8080 ...
                      0|MagicMir | [10.12.2021 21:26.59.221] [LOG]   Server started ...
                      0|MagicMir | [10.12.2021 21:26.59.224] [LOG]   Connecting socket for: updatenotification
                      0|MagicMir | [10.12.2021 21:26.59.227] [LOG]   Connecting socket for: calendar
                      0|MagicMir | [10.12.2021 21:26.59.229] [LOG]   Starting node helper for: calendar
                      0|MagicMir | [10.12.2021 21:26.59.231] [LOG]   Connecting socket for: newsfeed
                      0|MagicMir | [10.12.2021 21:26.59.233] [LOG]   Starting node helper for: newsfeed
                      0|MagicMir | [10.12.2021 21:26.59.234] [LOG]   Sockets connected & modules started ...
                      0|MagicMir |
                      0|MagicMir | > magicmirror@2.17.1 start /home/michel/MagicMirror
                      0|MagicMir |
                      0|MagicMir | [10.12.2021 21:27.03.032] [LOG]   Starting MagicMirror: v2.17.1
                      0|MagicMir | [10.12.2021 21:27.03.053] [LOG]   Loading config ...
                      0|MagicMir | [10.12.2021 21:27.03.070] [LOG]   Loading module helpers ...
                      0|MagicMir | [10.12.2021 21:27.03.076] [LOG]   No helper found for module: alert.
                      0|MagicMir | [10.12.2021 21:27.03.121] [LOG]   Initializing new module helper ...
                      0|MagicMir | [10.12.2021 21:27.03.125] [LOG]   Module helper loaded: updatenotification
                      0|MagicMir | [10.12.2021 21:27.03.129] [LOG]   No helper found for module: clock.
                      0|MagicMir | [10.12.2021 21:27.03.543] [LOG]   Initializing new module helper ...
                      0|MagicMir | [10.12.2021 21:27.03.546] [LOG]   Module helper loaded: calendar
                      0|MagicMir | [10.12.2021 21:27.03.549] [LOG]   No helper found for module: compliments.
                      0|MagicMir | [10.12.2021 21:27.03.552] [LOG]   No helper found for module: weather.
                      0|MagicMir | [10.12.2021 21:27.03.609] [LOG]   Initializing new module helper ...
                      0|MagicMir | [10.12.2021 21:27.03.611] [LOG]   Module helper loaded: newsfeed
                      0|MagicMir | [10.12.2021 21:27.03.613] [LOG]   All module helpers loaded.
                      0|MagicMir | [10.12.2021 21:27.03.893] [LOG]   Starting server on port 8080 ...
                      0|MagicMir | [10.12.2021 21:27.03.939] [LOG]   Server started ...
                      0|MagicMir | [10.12.2021 21:27.03.943] [LOG]   Connecting socket for: updatenotification
                      0|MagicMir | [10.12.2021 21:27.03.947] [LOG]   Connecting socket for: calendar
                      0|MagicMir | [10.12.2021 21:27.03.950] [LOG]   Starting node helper for: calendar
                      0|MagicMir | [10.12.2021 21:27.03.953] [LOG]   Connecting socket for: newsfeed
                      0|MagicMir | [10.12.2021 21:27.03.955] [LOG]   Starting node helper for: newsfeed
                      0|MagicMir | [10.12.2021 21:27.03.958] [LOG]   Sockets connected & modules started ...
                      0|MagicMirror  | The futex facility returned an unexpected error code.
                      0|MagicMirror  | /home/michel/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT
                      0|MagicMirror  | npm
                      0|MagicMirror  |  ERR! code ELIFECYCLE
                      0|MagicMirror  | npm ERR!
                      0|MagicMirror  | errno 1
                      0|MagicMirror  |  magicmirror@2.17.1 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
                      0|MagicMirror  | npm ERR! Exit status 1
                      0|MagicMirror  | npm ERR! Failed at the magicmirror@2.17.1 start script.
                      0|MagicMirror  | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                      0|MagicMirror  | npm ERR! A complete log of this run can be found in:
                      0|MagicMirror  | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_27_04_227Z-debug.log
                      PM2            | App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      PM2            | App [MagicMirror:0] starting in -fork mode-
                      PM2            | App [MagicMirror:0] online
                      0|MagicMirror  | > magicmirror@2.17.1 start /home/michel/MagicMirror
                      0|MagicMirror  | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
                      0|MagicMirror  | [10.12.2021 21:27.07.756] [LOG]
                      0|MagicMirror  | Starting MagicMirror: v2.17.1
                      0|MagicMirror  | [10.12.2021 21:27.07.774] [LOG]
                      0|MagicMirror  | Loading config ...
                      0|MagicMirror  | [10.12.2021 21:27.07.790] [LOG]
                      0|MagicMirror  | Loading module helpers ...
                      0|MagicMirror  | [10.12.2021 21:27.07.796] [LOG]
                      0|MagicMirror  | No helper found for module: alert.
                      0|MagicMirror  | [10.12.2021 21:27.07.835] [LOG]
                      0|MagicMirror  | Initializing new module helper ...
                      0|MagicMirror  | [10.12.2021 21:27.07.839] [LOG]
                      0|MagicMirror  | Module helper loaded: updatenotification
                      0|MagicMirror  | [10.12.2021 21:27.07.843] [LOG]   No helper found for module: clock.
                      0|MagicMirror  | [10.12.2021 21:27.08.182] [LOG]
                      0|MagicMirror  | [10.12.2021 21:27.08.184] [LOG]
                      0|MagicMirror  | Module helper loaded: calendar
                      0|MagicMirror  | [10.12.2021 21:27.08.188] [LOG]   No helper found for module: compliments.
                      0|MagicMirror  | [10.12.2021 21:27.08.191] [LOG]
                      0|MagicMirror  | No helper found for module: weather.
                      0|MagicMirror  | [10.12.2021 21:27.08.241] [LOG]
                      0|MagicMirror  | [10.12.2021 21:27.08.243] [LOG]
                      0|MagicMirror  | Module helper loaded: newsfeed
                      0|MagicMirror  | [10.12.2021 21:27.08.245] [LOG]   All module helpers loaded.
                      0|MagicMirror  | [10.12.2021 21:27.08.471] [LOG]
                      0|MagicMirror  | Starting server on port 8080 ...
                      0|MagicMirror  | [10.12.2021 21:27.08.505] [LOG]
                      0|MagicMirror  | Server started ...
                      0|MagicMirror  | [10.12.2021 21:27.08.508] [LOG]   Connecting socket for: updatenotification
                      0|MagicMirror  | [10.12.2021 21:27.08.512] [LOG]
                      0|MagicMirror  | Connecting socket for: calendar
                      0|MagicMirror  | [10.12.2021 21:27.08.515] [LOG]   Starting node helper for: calendar
                      0|MagicMirror  | [10.12.2021 21:27.08.518] [LOG]   Connecting socket for: newsfeed
                      0|MagicMirror  | [10.12.2021 21:27.08.520] [LOG]   Starting node helper for: newsfeed
                      0|MagicMirror  | [10.12.2021 21:27.08.522] [LOG]   Sockets connected & modules started ...
                      0|MagicMirror  | npm
                      0|MagicMirror  | npm ERR!     /home/michel/.npm/_logs/2021-12-10T20_27_08_775Z-debug.log
                        sdetweil @michelw
                        @michelw do
                        pm2 stop all
                        export DISPLAY=:0
                        npm start
                        • 1 / 5
