Unsolved OrangePi Zero 2 installation issues
@michelw no, but I can try armbian on my pi now
@michelw and when u are using vnc, the monitor is showing the desktop, right?
Ah right.
I would like to thank you very much for all your help.
Went looking for a second hand Raspberry PI 4B 1G today and found one. A little expensive but at least I have something more compatible now so I at least can get the magicmirror running :)
Still willing to help out (testing) if you would like to make your script Orange Pi Zero 2 compatible. That might help others.
@sdetweil said in OrangePi Zero 2 installation issues:
Yes, that is correct.
@michelw it’s not the script, it’s the assumption by the mm startup, defined in package.json), that DISPLAY needs to be :0 if not already set.
which image did u try?
debian or Ubuntu?
I tried all of them, the latest I tried was : Orangepizero2_2.1.6_debian_buster_desktop_linux4.9.170.img
@michelw installed XFCE desktop armbian on pi4(4gb)…
opened terminal on desktop, see
DISPLAY=:0.0installing MM now
DISPLAY not set on ssh session
SLOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW!
Any results?
@michelw no, looks like I picked a bad SD card.
have to try again. hour or so
