    Joke API doesn't show up at all? No errors
    6 Posts 3 Posters 923 Views 3 Watching
      releasefootball
      I followed the readme and inserted into the config as:
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      var config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 12,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "Holidays",
      						symbol: "calendar-check",
      						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: ""
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				appid: ""
      			module: 'MMM-JokeAPI',
      			position: 'top_bar',
      				category: 'Any'
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "Washington Post",
      						url: "http://feeds.washingtonpost.com/rss/national?itid=lk_inline_manual_38"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      (less some api/location stuff for other modules)
      I placed the joke api master in the module folder, next to the default one. I honestly have no idea what I could have done wrong. I’ve restarted multiple times.
      S cowboysdudeC 2 Replies Last reply Reply Quote 0
        sdetweil @releasefootball
        @releasefootball can u look in the developers window, ctrl-shift-i on the keyboard, and select the console tab and scroll up to see any errors
        • cowboysdudeC Offline
          cowboysdude Module Developer @releasefootball
          @releasefootball said in Joke API doesn't show up at all? No errors:
          MMM-JokeAPI
          Not sure what’s going on there… I tried the url and it’s working… try using double quotes like this:
          category: "any"
            sdetweil @cowboysdude
            @cowboysdude ah he has ‘Any’, with capital A
              cowboysdude Module Developer @sdetweil
              @sdetweil Still don’t think that’s his problem. I think he has a conflict OR he copied the config from the repository and his quotes are not right. You know how that works.
                @cowboysdude quotes are quotes unless u get the document kind that cause parse errors…
