    Dumbest question of the week Calendar Module
    7 Posts 3 Posters 1.3k Views 3 Watching
    • N6NGN Offline
      N6NG
      When I start my MM I get a message that says " Error in Calendar Module - Check logs for details"
      So my question is… Where are those pesky logs? I tried Whereis *.log but got nothing in return…
      Help? and thanks
      Dennis
        sdetweil @N6NG
        @n6ng where u start mm the messages are output. if u save them, they are the log. if not they are lost
        if you use pm2 to launch mm
        then the command
        pm2 logs --lines=???
        where ??? is some number, default 15
        will show you ??? lines of the error messages and ??? lines of the non error messages
        1st debug step for calendar , take the url u put in config for the ics file , and use it in a browser on the mm system.
        it should download the calendar ics file.
        which is just text.
        N6NGN 1 Reply Last reply Reply Quote 0
        • N6NGN Offline
          N6NG @sdetweil
          @sdetweil Thanks Sam… I’ll give it a try.
          Dennis
          • BKeyportB Online
            BKeyport Module Developer @N6NG
            @n6ng alternatively, if you can open two ssh sessions, you can use one of them with just pm2 logs - and watch it live as you restart MagicMirror in the other one.
            N6NGN 1 Reply Last reply Reply Quote 1
            • N6NGN Offline
              N6NG @BKeyport
              @bkeyport That’s my next project, to get the SSH working so I can program the mm from my PC…
              Thanks…
              There was an error in the calendar address and once I fixed that it works great… now on to the SSH programing…
              Thanks again Sam
              Dennis
                sdetweil @N6NG
                @n6ng use one of the integrated ssh clients. bitvise or winscp
                you get an ssh window AND a file browser over the pi file system. just double click to edit w your favorite editor.
                notepad++, vscode, whatever…
                • BKeyportB Online
                  @n6ng sudo raspi-config will give ya the options to enable SSH - on the PC, use termius or putty.
                  As for further PC control, you could look into samba - follow the instructions here for samba, they’re brilliant, even though it claims it’s for MacOS, it works for Windows too.
                  Edit: Forgot the link: https://kremalicious.com/raspberry-pi-file-and-screen-sharing-macos-ios
