Trying to fix my module
9 Posts 2 Posters 2.9k Views 2 Watching
    skoz
    Hello, I come to you because I started trying to create my own module. Because I didn’t know anything about javascript, html and css 2 weeks ago and not much in programmation either, I pretty much learned everything in 2 weeks so please, be indulgent :p
    The module I’m creating is supposed to display the data from a french public transport API. I worked on the display using a local server, just to test things out, I made it work, then I tried to implement it to my magic mirror, but here started the problems, I used the default modules as a guide and tried to move the diffrents pieces where they should be and now, I have this, but when I start my mirror, the screen stays black and it doesn’t start:
    Module.register(“schedules”, {
            defaults: {
                updateInterval: 20000
                fadeSpeed: 4000
            getScripts: function() {
                return ["moment.js"]
            getStyles: function() {
                return ["font-awesome.css", "schedules.css"]
            start: function() {
                var self = this;
                setInterval(function() {
                    self.updateDom(self.config.fadeSpeed);
                }, this.config.updateInterval);
            getDom: function() {
                dataDirSM = loadJSON("https://api-ratp.pierre-grimaud.fr/v2/rers/B/stations/les+baconnets?destination=robinson+saint+remy+les+chevreuse&endingstation=les+baconnets")
                data = loadJSON("https://api-ratp.pierre-grimaud.fr/v2/rers/B/stations/les+baconnets?destination=charles+de+gaulle+mitry+claye&endingstation=les+baconnets");
                setTimeout(function() {
                    var wrapper = document.createElement("div")
                    var realtable = document.createElement('table');
                    realtable.appendChild(this.createUpperRow());
                    var row1 = document.createElement('tr')
                    row1.appendChild(this.boxHeader(data.response.schedules[0].message))
                    row1.appendChild(this.boxHeader(data.response.schedules[0].id))
                    row1.appendChild(this.boxHeader(dataDirSM.response.schedules[0].id))
                    row1.appendChild(this.boxHeader(dataDirSM.response.schedules[0].message))
                    realtable.appendChild(row1)
                    var row2 = document.createElement('tr')
                    row2.appendChild(this.boxHeader(data.response.schedules[1].message))
                    row2.appendChild(this.boxHeader(data.response.schedules[1].id))
                    row2.appendChild(this.boxHeader(dataDirSM.response.schedules[1].id))
                    row2.appendChild(this.boxHeader(dataDirSM.response.schedules[1].message))
                    realtable.appendChild(row2)
                    var row3 = document.createElement('tr')
                    row3.appendChild(this.boxHeader(data.response.schedules[2].message))
                    row3.appendChild(this.boxHeader(data.response.schedules[2].id))
                    row3.appendChild(this.boxHeader(dataDirSM.response.schedules[2].id))
                    row3.appendChild(this.boxHeader(dataDirSM.response.schedules[2].message))
                    realtable.appendChild(row3)
                    wrapper.appendChild(realtable)
                    return wrapper
                }, (5 * 1000));
            createUpperRow: function() {
                function createUpperRow() {
                    var firstTableRow = document.createElement('tr');
                    var tableh1 = document.createElement('th');
                    tableh1.classList.add('align-left');
                    var tx1 = document.createTextNode('Time');
                    tableh1.appendChild(tx1);
                    firstTableRow.appendChild(tableh1);
                    var tableh2 = document.createElement('th');
                    tableh2.classList.add('align-left');
                    var tx2 = document.createTextNode('Paris');
                    tableh2.appendChild(tx2);
                    firstTableRow.appendChild(tableh2);
                    // deuxième moitier
                    var tableh3 = document.createElement('th');
                    tableh3.classList.add('align-right');
                    var tx3 = document.createTextNode('Sud');
                    tableh3.appendChild(tx3);
                    firstTableRow.appendChild(tableh3);
                    var tableh4 = document.createElement('th');
                    tableh4.classList.add('align-right');
                    var tx4 = document.createTextNode('Time');
                    tableh4.appendChild(tx4);
                    firstTableRow.appendChild(tableh4);
                    return firstTableRow;
                boxHeader: function(inside) {
                    if (inside == 'Train à l\'approche' || inside == 'Train à quai') {
                        inside = 'no way'
                    } else if (inside == 'Train retardé') {
                        inside = 'retard'
                    var fillNode = document.createTextNode(inside);
                    var realBox = document.createElement('td')
                    realBox.appendChild(fillNode);
                    return realBox;
    and my css file :
    .schedules .logo {
    margin-right: 5px;
    .schedules .centered {
    text-align: center;
    .schedules .table {
    border-spacing: 10px 0px;
    border-collapse: separate;
    (I don’t know why it doesn’t auto format)
    if you guys had little hints for me to fix my mistakes, I’ll be highly thankful.
    S 1 Reply Last reply Dec 25, 2016, 8:52 PM Reply Quote 0
      strawberry 3.141 Project Sponsor Module Developer @skoz
      @skoz
      what jumped on my eyes on the first look,
      the getDom function requires a synchronous answer, but with the timeout it’s asynchronous, you should load your data outside of this function and in getdom check if the data is there otherwise display a placeholder, then when you received data in the other function you call updateDom to refresh your display
      and there is a ratp module out there, maybe you will extend this one instead of creating a new one https://github.com/lgmorand/MMM-Ratp
        skoz
        Thank you for your reply, I didn’t know about this synchronous problem. But I think I saw that the start function is only called once, not each reload, so in which function should I get the data ?
        I couldn’t find the ratp module you told me about, if you could send me a link, that would be cool :)
        S 1 Reply Last reply Dec 25, 2016, 9:16 PM Reply Quote 0
          @skoz the link is above
          to give you an idea i wrote something little quick to give you an idea how it can be
          set an interval in start()
          setInterval(() => {
            this.getData();
            this.updateDom();
          }, 30*60*1000); //calls getData every 30 mins
          getData()
          this.dataDirSM = loadJSON("https://api-ratp.pierre-grimaud.fr/v2/rers/B/stations/les+baconnets?destination=robinson+saint+remy+les+chevreuse&endingstation=les+baconnets");
          this.data = loadJSON("https://api-ratp.pierre-grimaud.fr/v2/rers/B/stations/les+baconnets?destination=charles+de+gaulle+mitry+claye&endingstation=les+baconnets");
          getDom()
          if(this.dataDirSM && this.data){
          for(var i = 0; i < Math.min(this.data.response.schedules.length, this.dataDirSM.response.schedules.length); i++){
                          var row = document.createElement('tr')
                          row.appendChild(this.boxHeader(this.data.response.schedules[i].message))
                          row.appendChild(this.boxHeader(this.data.response.schedules[i].id))
                          row.appendChild(this.boxHeader(this.dataDirSM.response.schedules[i].id))
                          row.appendChild(this.boxHeader(this.dataDirSM.response.schedules[i].message))
                          realtable.appendChild(row)
          } else {
          wrapper.innerHTML = "NO DATA";
                          return wrapper
            skoz
            oh, i’m blind xD I had never seen this module, thanks for pointing it out !
            You fixed the for loop, i had trouble with this one, I refused to work and i still don’t know why so i decided to bypass it. Thanks alot for fixing my code, if I understand right, the getDom function will check if data has arrived and if True, it will display the table, if False, it will display the"NO DATA" ? and each reload, the program will reload the data and display it ?
            I’ll just have to shorten the time between each refresh because train pass by a bit more regularly so it wont be up to date if i wait 30 minutes each time.
            Thank you alot, I will try this new code now :)
            S 1 Reply Last reply Dec 25, 2016, 9:34 PM Reply Quote 0
              @skoz yes, but it’s not tested i just wrote it down to give you an idea. if you get in trouble feel free to wite me a pn or check out the other module
                skoz
                Well at least, this time, something happened, the mirror boot up but where the table should be, its written :
                schedules
                module_5_schedules
                        defaults: {
                            fadeSpeed: 4000
                        start: function() {
                            setInterval(() => {
                                this.getData();
                                this.updateDom();
                            }, 20 * 1000); //calls getData every 20 second
                            if (this.dataDirSM && this.data) {
                                for (var i = 0; i < Math.min(this.data.response.schedules.length, this.dataDirSM.response.schedules.length); i++) {
                            } else {
                            getData: function() {
                                        // deuxième moitier
                                            inside = 'no way'
                                            inside = 'retard'
                                        return realBox;
                and here is what I got from your advices
                S 1 Reply Last reply Dec 25, 2016, 9:51 PM Reply Quote 0
                  @skoz you forgot to return wrapper at the end of getDom and remove function createUpperRow() { in vreateUpperRow
                    skoz
                    Oh you are right, I also forget a curly brace after the ‘else’, I changed all that but it still doesn’t work
                    I paste the code again if you want to see it clear
                    defaults: {
                        fadeSpeed: 4000
                    start: function() {
                        setInterval(() => {
                            this.getData();
                            this.updateDom();
                        }, 20 * 1000); //calls getData every 20 seconds
                        } else {
                        return wrapper
                        // deuxième moitier
                            inside = 'no way'
                            inside = 'retard'
                        return realBox;
