    error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1
    9 Posts 3 Posters 3.5k Views 3 Watching
      MrDondoT
      After updating to latest version of MM using git pull && npm install - nothing is working, looks like npm is broken.
      Using npm start 0 I get error message: npm does not support Node.js v10.24.1
      Using pm2 start 0 i get this table
      Any help is appreciate
      • karsten13K Offline
        karsten13 @MrDondoT
        @mrdondot
        min. Version for node is v14, recommended v16. You have to update node.
          MrDondoT @karsten13
          @karsten13
          after updating it (btw i thought it was already updated) i got this:
          d7975564-813b-42ac-b1c7-958bff7e95de-image.png d5e2afcc-90d0-4b78-90eb-de9d37d7ef21-image.png
            sdetweil @MrDondoT
            @mrdondot after upgrade node/npm
            you need to redo the npm install of mm
            rm -rf node_modules
            rm package-lock.json
            npm install
              MrDondoT @sdetweil
              thanks @sdetweil .
              The npm install went well with no errors, thus on restart I can only have a black screen and 2 instances of mm
                sdetweil @MrDondoT
                @mrdondot ok use pm2 delete 0 to remove 1
                then pm2 logs --lines=50
                to dump the logs so we can see what is going on.
                if you did an upgrade then see this
                  MrDondoT @sdetweil
                  after deleting the pm2 that’s the result of log:
                  /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
                  1|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                  1|MagicMir | -
                  1|MagicMir | [12.01.2022 13:12.37.327] [ERROR] App threw an error during load
                  1|MagicMir | [12.01.2022 13:12.37.330] [ERROR] Error: Cannot find module 'valid-url'
                  1|MagicMir | Require stack:
                  1|MagicMir | - /home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js
                  1|MagicMir | - /home/pi/MagicMirror/js/app.js
                  1|MagicMir | - /home/pi/MagicMirror/js/electron.js
                  1|MagicMir | -
                  1|MagicMir |     at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                  1|MagicMir |     at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128)
                  1|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                  1|MagicMir |     at Module._load (node:internal/modules/cjs/loader:785:27)
                  1|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                  1|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
                  1|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
                  1|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js:9:16)
                  1|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
                  1|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
                  1|MagicMir | [12.01.2022 13:12.37.332] [ERROR] Whoops! There was an uncaught exception...
                  1|MagicMir | [12.01.2022 13:12.37.339] [ERROR] Error: Cannot find module 'valid-url'
                  1|MagicMir | -
                  1|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) {
                  1|MagicMir |   code: 'MODULE_NOT_FOUND',
                  1|MagicMir |   requireStack: [
                  1|MagicMir |     '/home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js',
                  1|MagicMir |     '/home/pi/MagicMirror/js/app.js',
                  1|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
                  1|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                  1|MagicMir |     undefined
                  1|MagicMir |   ]
                  1|MagicMir | }
                  1|MagicMir | [12.01.2022 13:12.37.340] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  1|MagicMir | [12.01.2022 13:12.37.341] [ERROR] If you think this really is an is sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  1|MagicMir | [1030:0112/131240.512560:ERROR:service_worker_storage.cc(1899)] Failed to delete the database: Database IO error
                    sdetweil @MrDondoT
                    @mrdondot yep, see the link in the prior post
                      MrDondoT @sdetweil
                      @sdetweil thanks!! All works fine now. :clapping_hands:
