    error on v 2.18 update - magicmirror npm does not support Node.js v10.24.1
    9 Posts 3 Posters 2.9k Views 3 Watching
      sdetweil @MrDondoT
      @mrdondot after upgrade node/npm
      you need to redo the npm install of mm
      rm -rf node_modules
      rm package-lock.json
      npm install
        MrDondoT @sdetweil
        thanks @sdetweil .
        The npm install went well with no errors, thus on restart I can only have a black screen and 2 instances of mm
          sdetweil @MrDondoT
          @mrdondot ok use pm2 delete 0 to remove 1
          then pm2 logs --lines=50
          to dump the logs so we can see what is going on.
          if you did an upgrade then see this
            MrDondoT @sdetweil
            after deleting the pm2 that’s the result of log:
            /home/pi/.pm2/logs/MagicMirror-error.log last 50 lines:
            1|MagicMir | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
            1|MagicMir | -
            1|MagicMir | [12.01.2022 13:12.37.327] [ERROR] App threw an error during load
            1|MagicMir | [12.01.2022 13:12.37.330] [ERROR] Error: Cannot find module 'valid-url'
            1|MagicMir | Require stack:
            1|MagicMir | - /home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js
            1|MagicMir | - /home/pi/MagicMirror/js/app.js
            1|MagicMir | - /home/pi/MagicMirror/js/electron.js
            1|MagicMir | -
            1|MagicMir |     at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
            1|MagicMir |     at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128)
            1|MagicMir |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
            1|MagicMir |     at Module._load (node:internal/modules/cjs/loader:785:27)
            1|MagicMir |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
            1|MagicMir |     at Module.require (node:internal/modules/cjs/loader:1012:19)
            1|MagicMir |     at require (node:internal/modules/cjs/helpers:94:18)
            1|MagicMir |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js:9:16)
            1|MagicMir |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
            1|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
            1|MagicMir | [12.01.2022 13:12.37.332] [ERROR] Whoops! There was an uncaught exception...
            1|MagicMir | [12.01.2022 13:12.37.339] [ERROR] Error: Cannot find module 'valid-url'
            1|MagicMir | -
            1|MagicMir |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) {
            1|MagicMir |   code: 'MODULE_NOT_FOUND',
            1|MagicMir |   requireStack: [
            1|MagicMir |     '/home/pi/MagicMirror/modules/MMM-MyCalendar/node_helper.js',
            1|MagicMir |     '/home/pi/MagicMirror/js/app.js',
            1|MagicMir |     '/home/pi/MagicMirror/js/electron.js',
            1|MagicMir |     '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
            1|MagicMir |     undefined
            1|MagicMir |   ]
            1|MagicMir | }
            1|MagicMir | [12.01.2022 13:12.37.340] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            1|MagicMir | [12.01.2022 13:12.37.341] [ERROR] If you think this really is an is sue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            1|MagicMir | [1030:0112/131240.512560:ERROR:service_worker_storage.cc(1899)] Failed to delete the database: Database IO error
              sdetweil @MrDondoT
              @mrdondot yep, see the link in the prior post
                MrDondoT @sdetweil
                @sdetweil thanks!! All works fine now. :clapping_hands:
