    Where to git clone MagicMirror 2.16
    12 Posts 4 Posters 7.4k Views 3 Watching
      sdetweil @mumblebaj
      @mumblebaj and if you use my upgrade script, it will do all the missing require lib corrections for the active modules
      • mumblebajM Offline
        @sdetweil That is true. But he already upgraded to latest. Not sure if your scripts will fix after the fact?
          sdetweil @mumblebaj
          @mumblebaj add force instead of apply, then its a re-upgrade (npm install, not pull) … and do the whole thing
            @plainbroke There you go. Use the upgrade script by @sdetweil with the apply option and it should sort out your modules’ missing dependencies. If you still have issues then post the logs so we can see what else is wrong.
              sdetweil @mumblebaj
              @mumblebaj FORCE if already upgraded… otherwise it will say ‘already at current release’ and abort
              mumblebajM plainbrokeP 2 Replies Last reply Reply Quote 0
                @sdetweil Sorry, mind was thinking “force” but the fingers overwrote with “apply” :-)
                • plainbrokeP Offline
                  plainbroke @sdetweil
                  @sdetweil said in Where to git clone MagicMirror 2.16:
                  Thanks guys I have slowly and I mean slowly got a few to work… I will install all of them and see what sdetweils upgrade script can do under force…
