    Where to git clone MagicMirror 2.16
    12 Posts 4 Posters 8.2k Views 3 Watching
    • plainbrokeP Offline
      plainbroke
      Sorry Sam,
      I do not understand how to do this.
      Went to the link you provided, evidently this is above my pay grade. LOL
      Jeff
      SharkbyteS 1 Reply Last reply Reply Quote 0
      • SharkbyteS Offline
        Sharkbyte @plainbroke
        @plainbroke
        Top oh the evening
        If you follow the url he sent you you can use the tag to rollback below is a screenshot showing the tag
        alt text
        You can use the tag to git that specific version
        The version you are looking for is below but you have to follow the instructions provided by @sdetweil To get the git to get that version (wanted to throw another get in that sentence) lol
        $ git clone -b <tagname> <repository>
        tagged version url
        If you complete this task sir your pay grade will be raised along with gitrank. Lol
        Feel free to ask any questions
        Technically challenged all day everyday.
        So then I just go here Evolution MMA
        Of course though spending time with the son is always the best of the best!
        • mumblebajM Offline
          mumblebaj Module Developer @plainbroke
          @plainbroke So, you may want to supply us the error messages that you are getting when you start the mirror. Either the content from the terminal when you start the mirror with npm or if you start the mirror with pm2 then pm2 log --lines 100. There are underlying issues with the modules that you have installed. To get you up and running on 2.18 then you need to provide us with the log output so we can see how to assist. Rolling back to older version of MM may not be the right thing to do. Let’s see if we can resolve the issues.
            sdetweil @mumblebaj
            @mumblebaj and if you use my upgrade script, it will do all the missing require lib corrections for the active modules
              @sdetweil That is true. But he already upgraded to latest. Not sure if your scripts will fix after the fact?
                sdetweil @mumblebaj
                @mumblebaj add force instead of apply, then its a re-upgrade (npm install, not pull) … and do the whole thing
                  @plainbroke There you go. Use the upgrade script by @sdetweil with the apply option and it should sort out your modules’ missing dependencies. If you still have issues then post the logs so we can see what else is wrong.
                    sdetweil @mumblebaj
                    @mumblebaj FORCE if already upgraded… otherwise it will say ‘already at current release’ and abort
                    mumblebajM plainbrokeP 2 Replies Last reply Reply Quote 0
                      @sdetweil Sorry, mind was thinking “force” but the fingers overwrote with “apply” :-)
                        plainbroke @sdetweil
                        @sdetweil said in Where to git clone MagicMirror 2.16:
                        Thanks guys I have slowly and I mean slowly got a few to work… I will install all of them and see what sdetweils upgrade script can do under force…
