    Just upgraded to 2.18, runs, but no display
    12 Posts 3 Posters 4.6k Views 3 Watching
    • F Offline
      fribse
      Hi all
      One more to the list of people having problems after 2.18.
      I’m running a RPi to show the magicmirror.
      I can see on ‘http://mirror:8080’ that it renders the page.
      But nothing is shown on the monitor
      By now in my debugging I only have these modules activated:
      “compliments”
      “alert”
      “updatenotification”
      “clock”
      “calendar”
      “weather”
      “newsfeed”
      As far as I know, all core modules.
      I see this in the logfile:
      0|MagicMir | [974:0213/131905.747644:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|MagicMir | [1014:0213/131907.005140:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      0|MagicMir | [1036:0213/131907.699933:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
      S bugsounetB 2 Replies Last reply Reply Quote 0
        sdetweil @fribse
        @fribse yes, can reinstall like that.
        as for black screen there is this
        my upgrade only handles 2 known libs missing, request and valid-url
        if there is another, I’d update my script.
          sdetweil @fribse
          @fribse how did u upgrade? git clone & npm install, or my script?
          if you open the dev window, ctrl-shift-i on the keyboard and select the console tab, do you see any other errors?
          what pi is this?
          can u show output of
          node -v
          npm -v
          • F Offline
            fribse @sdetweil
            @sdetweil I used your script (of course :smiling_face_with_halo: )
            It’s a Raspberry Pi 3 Model B Rev 1.2
            According to /sys/firmware/devicetree/base/model
            node -v
            v16.14.0
            npm -v
            8.3.1
            I’ve now tried to only load the clock module, same result.
            No message in the debug console, except the happy ones.
            Btw. release shows:
            /etc/*release
            PRETTY_NAME=“Raspbian GNU/Linux 10 (buster)”
            NAME=“Raspbian GNU/Linux”
            VERSION_ID=“10”
            VERSION=“10 (buster)”
            VERSION_CODENAME=buster
            ID=raspbian
            ID_LIKE=debian
            HOME_URL=“http://www.raspbian.org/”
            SUPPORT_URL=“http://www.raspbian.org/RaspbianForums”
            BUG_REPORT_URL=“http://www.raspbian.org/RaspbianBugs”
            • F Offline
              fribse @fribse
              @sdetweil Can I attempt a reinstall by just renaming the MagicMirror folder?
              I’ve also lost my most appreciated module, MMM-MQTTBridge, so I would love to just go back to the 2.17.1 if possible at all and the node.js and npm to be on an older (working) version :-(
              • bugsounetB Offline
                bugsounet Banned @fribse
                Generaly:
                • 50% of problems come from the person behind the terminal
                • 48% of other problem are person don’t read pre-require
                • 2% of rest are main coding problem
                Are you sure that you are in 2% of people ? :beaming_face_with_smiling_eyes:
                So: Just use node v14.x
                  sdetweil @fribse
                  • F Offline
                    fribse @bugsounet
                    @bugsounet Ha ha ha, no, I’m not blaiming anybody except myself. :beaming_face_with_smiling_eyes:
                    How do I
                    “So: Just use node v14.x”
                    @sdetweil I just did a reinstall, and now it displays stuff on the screen.
                    I do see this in the logs repeated over and over (as I said, fresh install):
                    0|MagicMirror  | [6213:0213/182653.081807:ERROR:socket_posix.cc(96)] CreatePlatformSocket() failed: Adressefamilien er ikke understøttet af protokollen (97)
                    Now I’ll try to add modules from my old config to see if it keeps working.
                    F S 2 Replies Last reply Reply Quote 0
                    • F Offline
                      fribse @fribse
                      @fribse Ok, so the black screen has nothing to do with the error:
                      0|MagicMirror  | [1554:0213/183501.650842:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                      0|MagicMirror  | [1601:0213/183503.081619:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                      0|MagicMirror  | [1621:0213/183503.548717:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                      As that is still shown when I start the software…
                        sdetweil @fribse
                        @fribse never seen that before
                        • F Offline
                          fribse @sdetweil
                          @sdetweil Glad to show you something new :rolling_on_the_floor_laughing:
                          I wonder if it’s the
                          gpu_mem=128
                          in boot/config.txt
                          Well, after doing a reinstall, module for module, it’s working with everything except that the Screencast module interferes with the remote module for the Home Assistant Integration (which uses the remote module).
                          So a success for now, and then I hope the integration to HA will get working.
                          Thans @sdetweil and @bugsounet !
                          S F 2 Replies Last reply Reply Quote 0
