    Just upgraded to 2.18, runs, but no display
    12 Posts 3 Posters 4.7k Views 3 Watching
    • F Offline
      fribse @sdetweil
      @sdetweil I used your script (of course :smiling_face_with_halo: )
      It’s a Raspberry Pi 3 Model B Rev 1.2
      According to /sys/firmware/devicetree/base/model
      node -v
      v16.14.0
      npm -v
      8.3.1
      I’ve now tried to only load the clock module, same result.
      No message in the debug console, except the happy ones.
      Btw. release shows:
      /etc/*release
      PRETTY_NAME=“Raspbian GNU/Linux 10 (buster)”
      NAME=“Raspbian GNU/Linux”
      VERSION_ID=“10”
      VERSION=“10 (buster)”
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL=“http://www.raspbian.org/”
      SUPPORT_URL=“http://www.raspbian.org/RaspbianForums”
      BUG_REPORT_URL=“http://www.raspbian.org/RaspbianBugs”
      • F Offline
        fribse @fribse
        @sdetweil Can I attempt a reinstall by just renaming the MagicMirror folder?
        I’ve also lost my most appreciated module, MMM-MQTTBridge, so I would love to just go back to the 2.17.1 if possible at all and the node.js and npm to be on an older (working) version :-(
        • bugsounetB Offline
          bugsounet Banned @fribse
          I see this in the logfile:
          0|MagicMir | [974:0213/131905.747644:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
          0|MagicMir | [1014:0213/131907.005140:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
          0|MagicMir | [1036:0213/131907.699933:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
          Generaly:
          • 50% of problems come from the person behind the terminal
          • 48% of other problem are person don’t read pre-require
          • 2% of rest are main coding problem
          Are you sure that you are in 2% of people ? :beaming_face_with_smiling_eyes:
          So: Just use node v14.x
            sdetweil @fribse
            @fribse yes, can reinstall like that.
            as for black screen there is this
            my upgrade only handles 2 known libs missing, request and valid-url
            if there is another, I’d update my script.
            • F Offline
              fribse @bugsounet
              @bugsounet Ha ha ha, no, I’m not blaiming anybody except myself. :beaming_face_with_smiling_eyes:
              How do I
              “So: Just use node v14.x”
              @sdetweil I just did a reinstall, and now it displays stuff on the screen.
              I do see this in the logs repeated over and over (as I said, fresh install):
              0|MagicMirror  | [6213:0213/182653.081807:ERROR:socket_posix.cc(96)] CreatePlatformSocket() failed: Adressefamilien er ikke understøttet af protokollen (97)
              Now I’ll try to add modules from my old config to see if it keeps working.
              F S 2 Replies Last reply Reply Quote 0
              • F Offline
                fribse @fribse
                @fribse Ok, so the black screen has nothing to do with the error:
                0|MagicMirror  | [1554:0213/183501.650842:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                0|MagicMirror  | [1601:0213/183503.081619:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
                0|MagicMirror  | [1621:0213/183503.548717:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
                As that is still shown when I start the software…
                  sdetweil @fribse
                  @fribse never seen that before
                  • F Offline
                    fribse @sdetweil
                    @sdetweil Glad to show you something new :rolling_on_the_floor_laughing:
                    I wonder if it’s the
                    gpu_mem=128
                    in boot/config.txt
                    Well, after doing a reinstall, module for module, it’s working with everything except that the Screencast module interferes with the remote module for the Home Assistant Integration (which uses the remote module).
                    So a success for now, and then I hope the integration to HA will get working.
                    Thans @sdetweil and @bugsounet !
                    S F 2 Replies Last reply Reply Quote 0
                      sdetweil @fribse
                      @fribse try without the entry in config.txt
                      • F Offline
                        fribse @fribse
                        @fribse Nope, just removed it and booted the mirror, still seeing those…
