    MMM-NewsAPI
    103 Posts 10 Posters 77.9k Views 8 Watching
      DarrenHill @mumblebaj
      @mumblebaj - Thanks for the reply.
      I corrected the case, but it’s made no difference.
      Yes npm install ran on the folder after doing the git clone (and run again just now to check).
      One thing I did notice when going onto the API site is that there doesn’t seem to be any content from the BBC in the feed. Shouldn’t affect the config above as it doesn’t use that domain for the moment, but may explain why the original MMM-News stopped working.
      Also can I just confirm that MMM-News is now depreciated, and that MMM-NewsAPI is its successor (as you are author of both)?
      • mumblebajM Offline
        mumblebaj Module Developer @DarrenHill
        @darrenhill I tested the config that you provided and I am getting results returned from it. MMM-News is still around and can be found here:
        MMM-News. MMM-NewsApi is a lightweight version of MMM-News.
        Do you see any errors in the terminal or the pm2 logs or in the Dev Window (shift+ctrl+i)?
          @mumblebaj Nothing I can see that’s relevant to MMM-NewsAPI:
          http://paste.debian.net/1231616/
          The config error (around line 98) was me trying a few different things in the set-up , and made a typo (forgot a comma).
          Neither of the modules are giving any response for me. MMM-News was working about a week ago, and then just seemed to stop (or at least not display anything).
          Has the BBC stopped making their feeds available to the API, I can’t see anything from them in the stream if I look via their website…
            @darrenhill BBC seems to be working fine.
            Not sure why yours is not pulling anything. I am using the following config.
                                    module: "MMM-NewsAPI",
                                    header: "news",
                                    position: "bottom_bar",
                                    pages: {"sport": "bottom_bar"},
                                            apiKey: "API_KEY",
                                            type: "horizontal",
                                            choice: "everything",
                                            pageSize: 20,
                                            sortBy: "publishedAt",
                                            drawInterval: 1000*30,
                                            templateFile: "template.html",
                                            fetchInterval: 1000*60*60,
                                            query: {
                                                    country: "",
                                                    category: "",
                                                    q: "",
                                                    qInTitle: "",
                                                    sources: "",
                                                    domains: "bbc.co.uk",
                                                    excludeDomains: "",
                                                    language: ""
              @mumblebaj With your exact config above (only adding in my API key) I just get the news title and the divider bar. Nothing below it at all?
              Very weird…
                @darrenhill Something else is definitely going on. Can you add debug: true to your config and send me the output?
                                            apiKey: "API_KEY",
                                            type: "horizontal",
                                            pageSize: 20,
                                           debug: true,
                                            query: {
                  @mumblebaj Below is a pastebinit of mm-out.log (I presume that’s what you want).
                  http://paste.debian.net/1231629/
                  From what I can see, it’s working there fine. It just doesn’t actually display anything?
                  I’m going to try moving it to the top of the screen just to make sure it’s not something stupid like it’s displaying it below the screen or something like that.
                  Edited to add - nope, moving it to the top just gives me the same title and divider bar, but this time at the top…
                    @darrenhill Ok. It is getting results and sends it to the main module. Can you check in the Developer Window if there is anything received there. You should see something like payload received with the json payload.
                      @mumblebaj How do I do that?
                      Normally I access the mirror via ssh, but I can use a keyboard/mouse on it if needed (it’s running in a PiTop Ceed).
                        @darrenhill just press ctrl+shift+i and select the console tab
                        • 10
                        • 11
                        • 5 / 11
