    MMM-Spotify
    249 Posts 51 Posters 329.6k Views 54 Watching
    • ? Offline
      [[global:former-user]] @larrougos
      @larrougos
      It seems MMM-AssistantMk2’s commands.
      You made some mistakes.
      This is somewhat similar what you want.
      "SPOTIFY_MA_PLAYLIST": {
        notificationExec: {
          notification: "SPOTIFY_PLAY",
          payload: "spotify:playlist:1EaTnmluBfauzzcOdjebNG"
      notificationExec cannot emit multiple notifications. It will emit just one - In your case, the last “SPOTIFY_NEXT” would be emitted. that’s why your issue happened.
      If you want to emit several notifications, use MMM-NotificationTrigger to relay and chain notifications. Or you can use moduleExec to make some logics. (Anyway that is not the point).
      And SPOTIFY_SHUFFLE is just toggle flag for current status, so it will not guarantee to be a shuffle mode.
      • L Offline
        larrougos @Guest
        @Sean said in MMM-Spotify:
        @larrougos
          notificationExec: {
        ok!! thats a start! can you please help me with that! i mean how this should have a proper syntax! i would really appreciate.
        Also another problem that i have is that if spotify is not already playing in the background i am not able to play anything. whatever command i give. and the frontend does not even show the spotify logo. it just disappears on after one sec on start.
        • ? Offline
          @larrougos
          In that case, maybe, the module cannot find available active devices. It doesn’t mean you have no device. But by default, Spotify doesn’t know which device is yours unless it is powered and logged as your account.
          So at least one of your devices need to be activated when this SDK is used. I recommend to install Raspotify, that could makes your spotify always on.
          • L Offline
            larrougos @Guest
            @larrougos
            i am running from ubuntu laptop with Spotify application! i tried with raspotify to install but from what i understood it does not support the laptop arch!
              rabbit83ka @kwaeksler
              First of all thanks for the module and the effort you put in it.
              updated
              1.1.0 (2019-03-25)
              • Device Limitation : Now you can allow or limit devices to display its playing on MM.
              One question regarding the device limitation: if I leave it empty, the module shows the cover etc. as it should. If I try to limit it to my echo dot with
               allowDevices: ["myechodot"],
              the spotify logo appears if I start playback on the echo dot, but no cover etc. is shown. Any hints?
              • ? Offline
                [[global:former-user]] @rabbit83ka
                @rabbit83ka
                When you play something on your echodot, nothing been displayed?
                  rabbit83ka @Guest
                  @Sean
                  If I comment out
                  //allwoeDevices: ["myechodot" ]
                  it shows the album cover/etx/progress etc. when I play something on my echo dot. With
                  the spotify logo appears when something is played on the echodot, but no cover/text/progress etc. is shown.
                  • I Offline
                    Ivanov_d
                    This post is deleted!
                    • I Offline
                      Ivanov_d
                      I have the following recipies:
                      var recipe = {
                        transcriptionHook: {
                          HIDE_ALL_MODULES: {
                            pattern: "standby mode",
                            command: "HIDEMODULES"
                          SHOW_ALL_MODULES: {
                            pattern: "show modules",
                            command: "SHOWMODULES"
                          SCREEN_ON: {
                            pattern: "turn on screen",
                            command: "SCREENON"
                          SCREEN_OFF: {
                            pattern: "turn off screen",
                            command: "SCREENOFF"
                          REBOOT: {
                            pattern: "reboot the mirror",
                            command: "REBOOT"
                          SHUTDOWN: {
                            pattern: "extinction totale",
                            command: "SHUTDOWN"
                          STOP_PLAY: {
                            pattern: "stop the video", // this is for youtube but it is preferable to have youtubeAutoplay: false, when running spotify so you don't get interaction with youtube player.
                            command: "STOP_VID"
                          SPOTIFY_PREVIOUS: {
                            pattern: "previous song",
                            command: "SPOTIFY_PREVIOUS"
                          SPOTIFY_PAUSE: {
                            pattern : "stop the music",
                            command: "SPOTIFY_PAUSE"
                          SPOTIFY_PLAY: {
                            pattern : "music please",
                            command: "SPOTIFY_PLAY"
                            SPOTIFY_NEXT: {
                            pattern: "next song",
                            command: "SPOTIFY_NEXT"
                          SPOTIFY_VOLUME: {
                            pattern: "set music volume to ([0-9]{1,2}[0]?|100)",
                            command: "SPOTIFY_VOLUME"
                          SPOTIFY_SEARCH: {
                            pattern: "play (.*) on Spotify",
                            command: "SPOTIFY_SEARCH"
                          SPOTIFY_SEARCH_PLAYLIST: {
                            pattern: "playlist (.*) on Spotify",
                            command: "SPOTIFY_SEARCH_PLAYLIST"
                        	SPOTIFY_MA_PLAYLIST: {
                          	pattern: "(.*) my playlist",   // (.*)  is an action  eg: play my playlist / run my playlist etc...
                          	command: "SPOTIFY_MA_PLAYLIST"
                        	SPOTIFY_TRANSFER: {
                          	pattern: "play the music on (.*)", // (.*)  is the name of your device
                          	command: "SPOTIFY_TRANSFER"
                          VOLUME_UP: {
                            pattern: "volume up",
                            command: "CMD_VOLUME_UP"
                          VOLUME_DOWN: {
                            pattern: "volume down",
                            command: "CMD_VOLUME_DOWN"
                          SET_VOLUME: {
                            pattern: "set master volume to ([0-9]{1,2}[0]?|100)",
                            command: "CMD_VOLUME_SET"
                        command: {
                          STOP_VID: {
                            moduleExec: {
                              module: ["MMM-AssistantMk2"],
                              exec: (module, params, key) => {
                                module.assistant.subdom.youtube.innerHTML = "";
                                module.assistant.subdom.youtube.style.display = "none";
                                module.youtubePlaying = false;
                          SPOTIFY_TRANSFER: {
                            notificationExec: {
                              notification: "SPOTIFY_TRANSFER",
                              payload: (params) => {
                                console.log("SPOTIFY_TRANSFER @",params)
                                return params[1];
                          SPOTIFY_PAUSE: {
                            notificationExec: {
                              notification: "SPOTIFY_PAUSE"
                          SPOTIFY_PLAY: {
                            notificationExec: {
                            notificationExec:  {
                        	      console.log("SPOTIFY_MA_PLAYLIST")
                                  return {
                                    context_uri:"spotify:playlist:0ka8HWt4xXcnTK5OpOuN2k",   // Uri of a personnal playlist or album
                        	    notification: "SPOTIFY_SHUFFLE",  // added this to toogle shuffle
                        	    notification: "SPOTIFY_NEXT" // added this to not always have the same song starting first
                        	SPOTIFY_NEXT: {
                            notificationExec: {
                          SPOTIFY_PREVIOUS: {
                            notificationExec: {
                              notification: "SPOTIFY_PREVIOUS"
                          SPOTIFY_VOLUME: {
                            notificationExec: {
                              notification: "SPOTIFY_VOLUME",
                                console.log("SPOTIFY_VOLUME @",params)
                                return params[1];
                        	SPOTIFY_SEARCH: {
                            notificationExec: {
                              notification: "SPOTIFY_SEARCH",
                                  console.log("SPOTIFY_SEARCH @",params)
                                  return {
                                    type: "artist,track,album,playlist",
                                    query: params[1],
                                    random:false,
                            notificationExec: {
                                  console.log("SPOTIFY_SEARCH_PLAYLIST @",params)
                                  return {
                                    type: "playlist",
                                    query: params[1],
                                    random:true,
                          CMD_VOLUME_UP: {
                            notificationExec: {
                              notification: "VOLUME_UP"
                          CMD_VOLUME_DOWN: {
                            notificationExec: {
                              notification: "VOLUME_DOWN"
                          CMD_VOLUME_SET: {
                            notificationExec: {
                              notification: "VOLUME_SET",
                              payload: (params, key) => {
                                console.log("@", params);
                                return params[1];
                      exports.recipe = recipe // Don't remove this line.
                      However, the
                          SPOTIFY_PLAY: {
                      Doesn’t work. It recognizes the command, but nothing happens. Playback from the mirror (raspotify) doesn’t happen. If I switch the source from my desktop/phone spotify app to Raspotify, then everything is fine (e.g. I renamed the player from Raspotify to MagicMirror if that matters).
                      There are no errors in the logs as far as I can see.
                      Any thoughts?
                      • ? Offline
                        [[global:former-user]] @Ivanov_d
                        @Ivanov_d
                        Only that command doesn’t work? Other’s OK?
                        Raspotify should be already running when you use this module. (This module cannot boot up Raspotify itself)
                        • I Offline
                          Ivanov_d
                          @Sean yes, the other commands work. I can skip the song, increase/decrease the volume and etc. Also Raspotify is running, because I can start the playback on the mirror from my Desktop/Smartphone app.0_1563467613897_Untitled20190718193321.png
                          • I Offline
                            Ivanov_d
                            @Sean, I did some more testing and I can confirm that this is the only command that doesn’t work. Maybe I am not understanding it correctly.
                            My expected results would be:
                            1. Raspotify is running in the background (but no music is playing)
                            2. When I say “music please” spotify will start a random song and play it on the MagicMirror
                            The result however is:
                            1. Raspotify is running in the background and no music is playing
                            2. When I say “music please” I see no errors in the logs, however, no music is starting as well
                            3. To workaround this I start the music from my smartphone or desktop app and switch the player to MagicMirror, after that I can control the player via AssistankMK2
                            ? 2 Replies Last reply Reply Quote 0
                            • ? Offline
                              @Ivanov_d
                              There could be 2(or 3)kinds of possibility about your issue;
                              1. AssistantMk2 cannot catch your word “music please”
                              2. AssistantMk2 could catch “music please” but cannot emit “SPOTIFY_PLAY” notification
                              3. Spotify cannot receive (or understand) SPOTIFY_PLAY notification. (hmmm… I can’t agree about this)
                              Well, I’ll test from last third issue. Wait for a while.
                              • ? Offline
                                @Ivanov_d
                                I just tested 3rd case, and there is no problem to work. I think your music please phrase is not hooked, because music is reserved word for default Music feature of Assistant itself(for Youtube Music or Spotify on Google Home itself, but not yet supported by SDK for devices - only allowed for Google Home or some genuine devices). Some keywords or phrases are reserved for Google itself. Unless you override the keywords by Custom Action for Assistant (And even though, cannot guarantee it will work), your music keyword couldn’t work.
                                Can you try other phrase? like “stay tune.” or any phrase you like.
                                • I Offline
                                  Ivanov_d
                                  @Sean I will try that and report back. Thanks for the suggestion.
                                  • F Offline
                                    Faiek
                                    Hi Guys need some help with this module - newbie :smirking_face:
                                    I have the following loaded succesfully:
                                    AssistantMk2
                                    Hotword
                                    Raspotify
                                    Change device name in Raspotify :to Mirror
                                    Created a spotify.json - recipe(code from here) in recipes file this is it:
                                    Added the recipe to the Mk2.js
                                    recipes:[“hide_and_show_all_modules.js”, “reboot.js”, “screen_onoff.js”, “shutdown.js”, “spotify.js”],
                                    Dont know what i missed - any assistance please …
                                    var recipe = {
                                              STOP_PLAY: {
                                                command: "STOP_VID"
                                             // STOP_PLAY2: {
                                             //   pattern: "arrête la musique",
                                             //   command: "STOP_VID"
                                    	 SPOTIFY_PREVIOUS: {
                                            SPOTIFY_PAUSE: {
                                            pattern : "stop the musique",
                                            SPOTIFY_PLAY: {
                                            SPOTIFY_NEXT: {
                                            SPOTIFY_VOLUME: {
                                            SPOTIFY_SEARCH: {
                                    	SPOTIFY_TRANSFER: {
                                              VOLUME_UP: {
                                              VOLUME_DOWN: {
                                              SET_VOLUME: {
                                            command: {
                                              STOP_VID: {
                                                moduleExec: {
                                    	   SPOTIFY_TRANSFER: {
                                    	    notificationExec: {
                                                    return params[1];
                                               SPOTIFY_PAUSE: {
                                                notificationExec: {
                                            SPOTIFY_PLAY: {
                                                notificationExec: {
                                    	    notificationExec:  {
                                    		return {
                                    			context_uri:"spotify:playlist:0bdByehKVfdsfdsfdsOhF5t",   // Uri of a personnal playlist or album
                                    	SPOTIFY_NEXT: {
                                             notificationExec: {
                                            SPOTIFY_PREVIOUS: {
                                             notificationExec: {
                                            SPOTIFY_VOLUME: {
                                             notificationExec: {
                                                    return params[1];
                                    	SPOTIFY_SEARCH: {
                                             notificationExec: {
                                                    return {
                                                            query: params[1],
                                                            random:false,
                                             notificationExec: {
                                                    return {
                                                            type: "playlist",
                                                            query: params[1],
                                                            random:true,
                                              CMD_VOLUME_UP: {
                                                notificationExec: {
                                              CMD_VOLUME_DOWN: {
                                                notificationExec: {
                                              CMD_VOLUME_SET: {
                                                notificationExec: {
                                                    return params[1];
                                    This is the error
                                    AMK2] Recipe is loaded: shutdown.js
                                    /home/pi/MagicMirror/modules/MMM-AssistantMk2/recipes/spotify.js:183
                                    SyntaxError: Unexpected token .
                                        at new Script (vm.js:74:7)
                                        at createScript (vm.js:246:10)
                                        at Object.runInThisContext (vm.js:298:10)
                                        at Module._compile (internal/modules/cjs/loader.js:678:28)
                                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                        at Module.load (internal/modules/cjs/loader.js:620:32)
                                        at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                                        at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                                        at Module.require (internal/modules/cjs/loader.js:658:17)
                                        at require (internal/modules/cjs/helpers.js:20:18)
                                    MagicMirror will not quit, but it might be a good idea to check why this happened.
                                    • ? Offline
                                      [[global:former-user]] @Faiek
                                      @Faiek
                                      you might have missed closing brace somewhere. check to count opening and closung pairs.
                                      • F Offline
                                        Faiek @Guest
                                        @Sean Thanks for the response - i m lost - no programming knowledge whats so ever
                                        trail and error got me thus far- and everything’s working great except spotify, still learning.
                                        Can’t i get a completed (recipe.json) with any other require details, for voice activation on this module that could assist me, once i have one, ill probably be able to see my error.
                                        Stomped for days now … online json checkers… really need to learn the basics …Thanks
                                        • ? Offline
                                          @Faiek
                                          Just add } over exports....
                                          • F Offline
                                            Faiek @Guest
                                            @Sean Thanks A Million - - working :grinning_face:
                                            • 6
                                            • 7
                                            • 12
                                            • 13
                                            • 5 / 13
