    MMM-Spotify
    249 Posts 51 Posters 345.4k Views 54 Watching
    • I Offline
      Ivanov_d
      @Sean I have changed the hook phrase to “showtime” and it still doesn’t work.
      SPOTIFY_PLAY: {
          pattern : "showtime",
          command: "SPOTIFY_PLAY"
      [HOTWORD] Final Result: { detected: true, hotword: 'assistant', file: null }
      [AMK2] assistant ready
      [AMK2] Conversation starts.
      [AMK2] Assistant Text Response:
      [AMK2] Transcription: show  --- Done: false
      [AMK2] Transcription: shut  --- Done: false
      [AMK2] Transcription: showtime  --- Done: false
      [AMK2] end-of-utterance
      [AMK2] Transcription: showtime  --- Done: true
      { requestId: '5d433446-0000-2772-8141-089e0827c3f4' } { profileFile: 'default.json', lang: 'en-US' }
      [AMK2] Device Action: { requestId: '5d433446-0000-2772-8141-089e0827c3f4' }
      [AMK2] Conversation Completed
      null
      [HOTWORD] begins.
      [HOTWORD] Detector starts listening.
        menanr
        This post is deleted!
        • ? Offline
          A Former User @menanr
          @menanr
          Check your firewall or network setting. And check also your MM is running on port 8888. You can try to connect “https://localhost:8888/callback” outside of your home network to check whether it is accessible from outside.
          • T Offline
            t.architecture99
            i can only see spotify logo and hear music . But nothing to show !!
            What can i do ? and how to config onStart: { ??
            Here is error logs
            [AMK2] Temporal storage directory is clearing.
            Whoops! There was an uncaught exception…
            TypeError: Cannot read property ‘getCurrentPlayback’ of null
            at Class.updatePulse (/home/pi/MagicMirror/modules/MMM-Spotify/node_helper.js:30:18)
            at Class.initAfterLoading (/home/pi/MagicMirror/modules/MMM-Spotify/node_helper.js:26:10)
            at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-Spotify/node_helper.js:44:12)
            at Socket. (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:113:11)
            at Socket.emit (events.js:182:13)
            at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
            at process._tickCallback (internal/process/next_tick.js:61:11)
            • ? Offline
              A Former User @t.architecture99
              @t-architecture99
              Maybe your ‘spotify.config.json’ would be wrong. Check it again.
                ricardoyen
                @brokenwings
                Hi did you figure this out, I’m stuck at this very same issue, I have Spotify working . how do I get voice assistant to integrate, do I modify the config.js file or the AssistantMK2.json file…??
                  bminer1
                  Having an issue with the song info showing up on the MM.
                  I have everything installed correctly ( to my knowledge, or else it would work right?) and have the white Spotify symbol.
                  I entered my Client ID and Secret.
                  Callback and port are in there. I authorized through Spotify…
                  Not sure what i am missing…
                  Help?
                    			module: "MMM-Spotify",
                    			position: "bottom_left",
                      				style: "mini", // "default" or "mini" available
                      				control: "default", //"default", "hidden" available
                      				updateInterval: 1000,
                      				onStart: null, // disable onStart feature with `null`
                      				allowDevices: [], //If you want to limit devices to display info, use this.
                      				// allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
                    "CLIENT_ID" : "xxxx",
                    "CLIENT_SECRET" : "xxxx",
                    "AUTH_DOMAIN" : "http://localhost",
                    "AUTH_PATH" : "/callback",
                    "AUTH_PORT" : "8888",
                    "SCOPE" : "user-read-private app-remote-control playlist-read-private streaming user-read-playback-state user-modify-playback-state",
                    "TOKEN" : "./token.json"
                  • ? Offline
                    A Former User @bminer1
                    @bminer1
                    Tell me more details. What happens on MagicMirror when you activate your spotify app on your smartphone?
                      bminer1 @Guest
                      @Sean i restarted the pi and my computer that is running the spotify. Everything is running and working as it should. buttons work, displays very well and its all good. Sorry, for the false alarm. noob moment.
                        matt216
                        Love the module, but noticed it makes the mirror by far the noisiest device on my network. Any idea why it talks so much to the spotify api?
                        • ? Offline
                          A Former User @matt216
                          @matt216
                          Because, Spotify playback API doesn’t be designed to push the status to the caller. The module should use pooling to get CURRENT playback status whenever it is needed. Set bigger value to updateInterval.
                            matt216 @Guest
                            @Sean thanks, appreciate the reply. Makes sense!
                            • MondfischM Offline
                              Mondfisch
                              Hello,
                              i am using your Module a couple of Months, it always worked well…
                              …but since the last Update, it “hangs” after a couple of Minutes, which means,
                              it still shows up, but the Title-Information and the Time is frozen.
                              I am using MMM-Spotify and MMM-NowPlayingOnSpotify (I also use MMM-Carousel,
                              so I have different “screens” on which I use both Modules, but not simultaneously.
                              While MMM-Spotify is “freezing”, MMM-NowPlayingonSpotify is going on well…
                              They worked BOTH OK, before the Update…
                              Any Ideas?
                              • ? Offline
                                A Former User @Mondfisch
                                @Mondfisch
                                Hmmm. A recent update was for just multi-account supporting. Can you show backend log when it happened?
                                  Mondfisch
                                  Thank you for answering…
                                  I´m not sure which log do you mean… Can you give me a path, i will post it, then…
                                  • W Offline
                                    woodstock37
                                    I have similar situation like @Mondfisch described. And once problem appears, I got below log:
                                    [15:46:23.437] [LOG] [SPOTIFY] API Request fail on : /v1/me/player
                                    [15:46:23.440] [LOG] { Error: Client network socket disconnected before secure TLS connection was established
                                    at TLSSocket.onConnectEnd (_tls_wrap.js:1092:19)
                                    at Object.onceWrapper (events.js:273:13)
                                    at TLSSocket.emit (events.js:187:15)
                                    at endReadableNT (_stream_readable.js:1090:12)
                                    at process._tickCallback (internal/process/next_tick.js:63:19)
                                    code: ‘ECONNRESET’,
                                    path: null,
                                    host: ‘api.spotify.com’,
                                    port: 443,
                                    localAddress: undefined } undefined
                                    [15:46:23.458] [LOG] Whoops! There was an uncaught exception…
                                    [15:46:23.461] [ERROR] TypeError: Cannot read property ‘statusCode’ of undefined
                                    at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-Spotify/Spotify.js:199:34)
                                    at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
                                    at Request.emit (events.js:182:13)
                                    at Request.onRequestError (/home/pi/MagicMirror/node_modules/request/request.js:881:8)
                                    at ClientRequest.emit (events.js:182:13)
                                    at TLSSocket.socketErrorListener (_http_client.js:382:9)
                                    at TLSSocket.emit (events.js:182:13)
                                    at emitErrorNT (internal/streams/destroy.js:82:8)
                                    at emitErrorAndCloseNT (internal/streams/destroy.js:50:3)
                                    [15:46:23.470] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [15:46:23.472] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    [16:09:49.712] [LOG] Shutting down server…
                                    I tried to uninstall and install the module, but no luck, the problem keeps exist. Not sure if there is any solution on it.
                                    • ? Offline
                                      A Former User @woodstock37
                                      @woodstock37
                                      Try to set updateInterval: to 2000 or 3000. I’ll inspect later.
                                      • W Offline
                                        woodstock37 @Guest
                                        @Sean Thanks for your suggestion. It definitely helps. Thanks.
                                        • E Offline
                                          Ezz91
                                          Re: [MMM - Spotify]
                                          Hi @Sean
                                          Just a suggestion, If you could include the heart/like button on the controls (to add the current song to your liked playlist)
                                          Thanks!
                                          p.s installed and works perfectly with 2 accounts!
                                          • L Offline
                                            Lasmazze
                                            Hi @Sean, I just have a question I read the whole forum but I did not find the answer.
                                            I installed Raspotify on my Raspberry pi, but when I launch my mirror, I cannot launch music by saying “music play”, only from my phone, once I have started the music from my phone and I connect it on raspotify I can change the music as well as all the other commands.
                                            And spotify does not launch with onStart.
                                                control: "hidden", //"default", "hidden" available
                                                onStart: {
                                                  deviceName: "RASPOTIFY", //if null, current(last) activated device will be.
                                                  spotifyUri: "spotify:track:0hNduWmlWmEmuwEFcYvRu1"
                                                  //when search is set, sportifyUri will be ignored.
                                            thank you for your answers.
                                            • 6
                                            • 7
                                            • 8
                                            • 12
                                            • 13
                                            • 6 / 13
