    MMM-Spotify
    249 Posts 51 Posters 345.4k Views 54 Watching
    • ? Offline
      A Former User @Lasmazze
      @Lasmazze
      Limitation of api. Until spotify really starts, api doesn’t return even the device list. So module can do nothing. Sorry.
        banbutcher
        im wondering if its possible to allign the spotify module to the right edge of the screen? ive recently added a covid-19 module and the spotify module alligns its self with the longer left edge. also is it possible to increse the padding on the bottom, i just want to space it away from th e covid module.
        hopefully the link works and you can see what i mean…
        https://drive.google.com/open?id=1_n5ntrUBSJITaOsOVct8U_-VpiiMSaAr
        thanks,
        Richie
        • ? Offline
          A Former User @banbutcher
          @banbutcher
          Try this. (But it could make unexpected result by your other modules. anyway worthy to try)
          /* In your `css/custom.css` */
          #SPOTIFY {
              position: absolute;
              right:0;
          Or you can adjust by manual.
          #SPOTIFY {
            left: 150px ; /* depends on your layout */
          • L Offline
            Lasmazze @Guest
            @Sean Ok thank you for your answer. apart from that your modules work really well, continue like that!
              SuperfrogMe
              Hi !
              Thirst, thanks to the devs for this module and the multi account function !
              I have a problem with the module. After some songs, the module stay stuck on a song.
              I have only some modules on my MM, and all others modules work fine.
              We are 2 at home, with 2 premium account and 1 Spotify Connect receiver. We mainly use le Spotify Connect receiver.
              The problem occurs with all the revceivers (Spotify connect or smartphones).
              Do you have an idea of the problem ?
                    "USERNAME": "First user",
                    "CLIENT_ID" : "xxx",
                    "CLIENT_SECRET" : "yyy",
                    "AUTH_DOMAIN" : "http://localhost",
                    "AUTH_PATH" : "/callback",
                    "AUTH_PORT" : "8888",
                    "SCOPE" : "user-read-private app-remote-control playlist-read-private streaming user-read-playback-state user-modify-playback-state",
                    "TOKEN" : "./firstuser_token.json"
                    "USERNAME": "Second user",
                    "CLIENT_ID" : "zzz",
                    "CLIENT_SECRET" : "www",
                    "TOKEN" : "./seconduser_token.json"
                SuperfrogMe @SuperfrogMe
                I did a clean total reinstallation of my RPI3 under Raspbian Buster. Always the same problem, module blocked after a few minutes.
                Can we think of a bug?
                I will reinstall MMM-Spotify with only 1 account configured to see if the problem recurs.
                • F Offline
                  ForrestFire2222
                  Hi!
                  I have been trouble shooting an install of MMM-Spotify for a few days now and I can’t seem to authorize/authenticate the token…
                  When executing Step 4 of the install Get Auth;
                  cd ~/MagicMirror/modules/MMM-Spotify node first_auth.js
                  My terminal hangs up and I need to CTRL-C to get out.
                  pi@raspberrypi:~/MagicMirror $ npm start dev
                  > magicmirror@2.11.0 start /home/pi/MagicMirror
                  > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                  [2020-04-20 17:46:11.400] [LOG]    Starting MagicMirror: v2.11.0
                  [2020-04-20 17:46:11.413] [LOG]    Loading config ...
                  [2020-04-20 17:46:11.427] [LOG]    Loading module helpers ...
                  [2020-04-20 17:46:11.433] [LOG]    No helper found for module: alert.
                  [2020-04-20 17:46:11.538] [LOG]    Initializing new module helper ...
                  [2020-04-20 17:46:11.539] [LOG]    Module helper loaded: updatenotification
                  [2020-04-20 17:46:11.541] [LOG]    No helper found for module: clock.
                  [2020-04-20 17:46:12.258] [LOG]    Initializing new module helper ...
                  [2020-04-20 17:46:12.260] [LOG]    Module helper loaded: MMM-Spotify
                  [2020-04-20 17:46:12.262] [LOG]    All module helpers loaded.
                  [2020-04-20 17:46:12.503] [LOG]    Starting server on port 8080 ...
                  [2020-04-20 17:46:12.531] [LOG]    Server started ...
                  [2020-04-20 17:46:12.533] [LOG]    Connecting socket for: updatenotification
                  [2020-04-20 17:46:12.535] [LOG]    Connecting socket for: MMM-Spotify
                  [2020-04-20 17:46:12.539] [LOG]    Sockets connected & modules started ...
                  [2020-04-20 17:46:12.700] [LOG]    Whoops! There was an uncaught exception...
                  [2020-04-20 17:46:12.701] [ERROR]  Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                      at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                      at listenInCluster (net.js:1274:12)
                      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
                    code: 'EADDRINUSE',
                    errno: 'EADDRINUSE',
                    syscall: 'listen',
                    address: '127.0.0.1',
                    port: 8080
                  My 8080 port is already in use causing an error? I’ve followed the installation procedure and verified my callback in Spotify Dev is copy and pasted as http://localhost:8888/callback
                  My spotify.config.json;
                        "USERNAME": "myname",
                        "CLIENT_ID" : "spot_id",
                        "CLIENT_SECRET" : "spot_secret",
                        "TOKEN" : "./myname_token.json"
                  My MagicMirror config.js;
                  var config = {
                          address: "localhost",           // Address to listen on, can be:
                          port: 8080,
                          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
        // Set [] to allow all IP addresses
                          language: "en",
                          timeFormat: 24,
                          units: "imperial",
                                               // false, default for all  NON-armv6l devices
                                          module: "MMM-Spotify",
                                          position: "lower_third",
                                                  style: "mini", // "default" or "mini" available
                                                  control: "hidden", //"default", "hidden" available
                                                  updateInterval: 2000,
                                                  onStart: null, // disable onStart feature with `null`
                                                  allowDevices: [], //If you want to limit devices to display info, use this.
                                                  // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
                  Any help, thanks
                  • ? Offline
                    A Former User @ForrestFire2222
                    @ForrestFire2222
                    It’s not issue of module. You just executed MagicMirror twice.
                    • F Offline
                      ForrestFire2222 @Guest
                      @Sean I really appreciate the reply.
                      Im new so maybe I didn’t convey my issue/logs correctly. As I mention above, when I try to execute Step 4, I get the error below…
                      pi@raspberrypi:~/MagicMirror/modules/MMM-Spotify $ node first_auth.js
                      [SPOTIFY_AUTH] creating server { USERNAME: 'MyName',
                        CLIENT_ID: 'My_ID',
                        CLIENT_SECRET: 'My_Secret',
                        AUTH_DOMAIN: 'http://localhost',
                        AUTH_PATH: '/callback',
                        AUTH_PORT: '8888',
                        SCOPE:
                         'user-read-private app-remote-control playlist-read-private streaming user-read-playback-state user-modify-playback-state',
                        TOKEN: './MyName_token.json' }
                      [SPOTIFY_AUTH] Opening URL.(https://accounts.spotify.com/authorize?response_type=code&client_id=My_ID&scope=user-read-private%20app-remote-control%20playlist-read-private%20streaming%20user-read-playback-state%20user-modify-playback-state&redirect_uri=http%3A%2F%2Flocalhost%3A8888%2Fcallback&state=1587478945270&show_dialog=true)
                      At this point the terminal just stalls out. Hope this clarifies the above, my configs are still above. Thanks again
                      • ? Offline
                        @ForrestFire2222
                        If browser couldn’t open the url automatically, copy the URL and paste it into your web browser.
                        • F Offline
                          @Sean Thanks.
                          I’ve tried a couple things…
                          through ssh i tried the link on my laptop browser, and I got an error displayed on the page of “INVALID_CLIENT: Invalid client”.
                          And on my Mirror, through the command line i executed node first_auth.js and the browser opened up to login to Spotify (this is a good sign, haven’t got this far yet), however, when I enter my Spotify Acct info I get the same error as above, Invalid Client.
                          • F Offline
                            ForrestFire2222 @ForrestFire2222
                            I started from scratch, loading MMM-Spotify first to my mirror and it works with no issues… sorry I didn’t try that sooner. Thanks again!
                            • T Offline
                              Telliman
                              Set this up and works great! Thanks so much! Now next for me is to set up Assistant and this will be sweet!
                              Thanks so much!
                                mmmmh Project Sponsor
                                @Sean Is there a way to make the connection watchdog more forgiving/resilient? Even though I set the refresh rate to 5 seconds I see API connection timeouts and recently also this:
                                [SPOTIFY] API Request fail on : /v1/me/player
                                [2020-05-05 16:43:27.591] [LOG]
                                { Error: socket hang up
                                    at createHangUpError (_http_client.js:332:15)
                                    at TLSSocket.socketOnEnd (_http_client.js:435:23)
                                    at TLSSocket.emit (events.js:203:15)
                                    at endReadableNT (_stream_readable.js:1145:12)
                                    at process._tickCallback (internal/process/next_tick.js:63:19) code: 'ECONNRESET' } undefined
                                  What would the best approach to hide other specific modules when this module is active, i.e. when music is being played?
                                  It may be to early to ask this since @Bugsounet just volunteered a few minutes ago to take over this project so take your time with your feedback.
                                  • ? Offline
                                    A Former User
                                    leave me a few days … I have to inspect the entire API :)
                                      sdetweil @mmmmh
                                      @mmmmh i tried to use watchdog for another problem, but there were normal disconnects between the front and back ends, which WOULD have recovered, had watchdbog not restarted MM… I gave up
                                        mmmmh Project Sponsor @Guest
                                        @Bugsounet Take your time.
                                        Currently, the module already has awareness about playback activity. An API call to an endpoint of my choosing on state change would already solve it for me. The endpoint could also be MMM-Remote-Control’s API.
                                        I guess I can sift through the module’s code and see if with my humble skills can insert a simple request at the proper place. We’ll see how it goes.
                                        • ? Offline
                                          A Former User
                                          don’t worry ;)
                                          I was trained by @eouia!
                                          • ? Offline
                                            A Former User
                                            MMM-Spotify
                                            new owner, new version, new change :)
                                            v1.3.0 (2020-05-13)
                                            • Fixed: on lost internet connexion
                                            • Added: SPOTIFY_CONNECTED SPOTIFY_DISCONNECTED notification
                                            • Added: debug mode
                                            • Added: deviceDisplay feature
                                            • Added: handling for extra device icons
                                            • Added: debug mode for Hiding console logs (memory leaks)
                                            • Added: fade in transition on cover
                                            • Added: box shadow around cover to highlight from background
                                            Again, not in the change log
                                            • Fixed : Spotify Free ads errors solved
                                            M 1 Reply Last reply Reply Quote 2
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 12
                                            • 13
                                            • 7 / 13
