    MMM-Spotify
    249 Posts 51 Posters 359.7k Views 54 Watching
      SuperfrogMe @SuperfrogMe
      I did a clean total reinstallation of my RPI3 under Raspbian Buster. Always the same problem, module blocked after a few minutes.
      Can we think of a bug?
      I will reinstall MMM-Spotify with only 1 account configured to see if the problem recurs.
      • F
        ForrestFire2222
        Hi!
        I have been trouble shooting an install of MMM-Spotify for a few days now and I can’t seem to authorize/authenticate the token…
        When executing Step 4 of the install Get Auth;
        cd ~/MagicMirror/modules/MMM-Spotify node first_auth.js
        My terminal hangs up and I need to CTRL-C to get out.
        pi@raspberrypi:~/MagicMirror $ npm start dev
        > magicmirror@2.11.0 start /home/pi/MagicMirror
        > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
        [2020-04-20 17:46:11.400] [LOG]    Starting MagicMirror: v2.11.0
        [2020-04-20 17:46:11.413] [LOG]    Loading config ...
        [2020-04-20 17:46:11.427] [LOG]    Loading module helpers ...
        [2020-04-20 17:46:11.433] [LOG]    No helper found for module: alert.
        [2020-04-20 17:46:11.538] [LOG]    Initializing new module helper ...
        [2020-04-20 17:46:11.539] [LOG]    Module helper loaded: updatenotification
        [2020-04-20 17:46:11.541] [LOG]    No helper found for module: clock.
        [2020-04-20 17:46:12.258] [LOG]    Initializing new module helper ...
        [2020-04-20 17:46:12.260] [LOG]    Module helper loaded: MMM-Spotify
        [2020-04-20 17:46:12.262] [LOG]    All module helpers loaded.
        [2020-04-20 17:46:12.503] [LOG]    Starting server on port 8080 ...
        [2020-04-20 17:46:12.531] [LOG]    Server started ...
        [2020-04-20 17:46:12.533] [LOG]    Connecting socket for: updatenotification
        [2020-04-20 17:46:12.535] [LOG]    Connecting socket for: MMM-Spotify
        [2020-04-20 17:46:12.539] [LOG]    Sockets connected & modules started ...
        [2020-04-20 17:46:12.700] [LOG]    Whoops! There was an uncaught exception...
        [2020-04-20 17:46:12.701] [ERROR]  Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
            at Server.setupListenHandle [as _listen2] (net.js:1226:14)
            at listenInCluster (net.js:1274:12)
            at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
            at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
          code: 'EADDRINUSE',
          errno: 'EADDRINUSE',
          syscall: 'listen',
          address: '127.0.0.1',
          port: 8080
        My 8080 port is already in use causing an error? I’ve followed the installation procedure and verified my callback in Spotify Dev is copy and pasted as http://localhost:8888/callback
        My spotify.config.json;
              "USERNAME": "myname",
              "CLIENT_ID" : "spot_id",
              "CLIENT_SECRET" : "spot_secret",
              "AUTH_DOMAIN" : "http://localhost",
              "AUTH_PATH" : "/callback",
              "AUTH_PORT" : "8888",
              "SCOPE" : "user-read-private app-remote-control playlist-read-private streaming user-read-playback-state user-modify-playback-state",
              "TOKEN" : "./myname_token.json"
        My MagicMirror config.js;
        var config = {
                address: "localhost",           // Address to listen on, can be:
                port: 8080,
        // Set [] to allow all IP addresses
                language: "en",
                timeFormat: 24,
                units: "imperial",
                                     // false, default for all  NON-armv6l devices
                                module: "MMM-Spotify",
                                position: "lower_third",
                                        style: "mini", // "default" or "mini" available
                                        control: "hidden", //"default", "hidden" available
                                        updateInterval: 2000,
                                        onStart: null, // disable onStart feature with `null`
                                        allowDevices: [], //If you want to limit devices to display info, use this.
                                        // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
        Any help, thanks
        ? 1 Reply Last reply
          A Former User @ForrestFire2222
          @ForrestFire2222
          It’s not issue of module. You just executed MagicMirror twice.
          F 1 Reply Last reply
          • F
            ForrestFire2222 @Guest
            @Sean I really appreciate the reply.
            Im new so maybe I didn’t convey my issue/logs correctly. As I mention above, when I try to execute Step 4, I get the error below…
            pi@raspberrypi:~/MagicMirror/modules/MMM-Spotify $ node first_auth.js
            [SPOTIFY_AUTH] creating server { USERNAME: 'MyName',
              CLIENT_ID: 'My_ID',
              CLIENT_SECRET: 'My_Secret',
              AUTH_DOMAIN: 'http://localhost',
              AUTH_PATH: '/callback',
              AUTH_PORT: '8888',
              SCOPE:
               'user-read-private app-remote-control playlist-read-private streaming user-read-playback-state user-modify-playback-state',
              TOKEN: './MyName_token.json' }
            [SPOTIFY_AUTH] Opening URL.(https://accounts.spotify.com/authorize?response_type=code&client_id=My_ID&scope=user-read-private%20app-remote-control%20playlist-read-private%20streaming%20user-read-playback-state%20user-modify-playback-state&redirect_uri=http%3A%2F%2Flocalhost%3A8888%2Fcallback&state=1587478945270&show_dialog=true)
            At this point the terminal just stalls out. Hope this clarifies the above, my configs are still above. Thanks again
              @ForrestFire2222
              If browser couldn’t open the url automatically, copy the URL and paste it into your web browser.
              • F
                @Sean Thanks.
                I’ve tried a couple things…
                through ssh i tried the link on my laptop browser, and I got an error displayed on the page of “INVALID_CLIENT: Invalid client”.
                And on my Mirror, through the command line i executed node first_auth.js and the browser opened up to login to Spotify (this is a good sign, haven’t got this far yet), however, when I enter my Spotify Acct info I get the same error as above, Invalid Client.
                • F
                  ForrestFire2222 @ForrestFire2222
                  I started from scratch, loading MMM-Spotify first to my mirror and it works with no issues… sorry I didn’t try that sooner. Thanks again!
                  • T
                    Telliman
                    Set this up and works great! Thanks so much! Now next for me is to set up Assistant and this will be sweet!
                    Thanks so much!
                      mmmmh Project Sponsor
                      @Sean Is there a way to make the connection watchdog more forgiving/resilient? Even though I set the refresh rate to 5 seconds I see API connection timeouts and recently also this:
                      [SPOTIFY] API Request fail on : /v1/me/player
                      [2020-05-05 16:43:27.591] [LOG]
                      { Error: socket hang up
                          at createHangUpError (_http_client.js:332:15)
                          at TLSSocket.socketOnEnd (_http_client.js:435:23)
                          at TLSSocket.emit (events.js:203:15)
                          at endReadableNT (_stream_readable.js:1145:12)
                          at process._tickCallback (internal/process/next_tick.js:63:19) code: 'ECONNRESET' } undefined
                        What would the best approach to hide other specific modules when this module is active, i.e. when music is being played?
                        It may be to early to ask this since @Bugsounet just volunteered a few minutes ago to take over this project so take your time with your feedback.
                          A Former User
                          leave me a few days … I have to inspect the entire API :)
                          M 1 Reply Last reply
                            sdetweil @mmmmh
                            @mmmmh i tried to use watchdog for another problem, but there were normal disconnects between the front and back ends, which WOULD have recovered, had watchdbog not restarted MM… I gave up
                              mmmmh Project Sponsor @Guest
                              @Bugsounet Take your time.
                              Currently, the module already has awareness about playback activity. An API call to an endpoint of my choosing on state change would already solve it for me. The endpoint could also be MMM-Remote-Control’s API.
                              I guess I can sift through the module’s code and see if with my humble skills can insert a simple request at the proper place. We’ll see how it goes.
                                A Former User
                                don’t worry ;)
                                I was trained by @eouia!
                                  A Former User
                                  MMM-Spotify
                                  new owner, new version, new change :)
                                  v1.3.0 (2020-05-13)
                                  • Fixed: on lost internet connexion
                                  • Added: SPOTIFY_CONNECTED SPOTIFY_DISCONNECTED notification
                                  • Added: debug mode
                                  • Added: deviceDisplay feature
                                  • Added: handling for extra device icons
                                  • Added: debug mode for Hiding console logs (memory leaks)
                                  • Added: fade in transition on cover
                                  • Added: box shadow around cover to highlight from background
                                  Again, not in the change log
                                  • Fixed : Spotify Free ads errors solved
                                  Reply Quote 2
                                    @Bugsounet Cool additions and fixes. I need to find out more about the notifications to learn how to disable other modules when music is streaming.
                                      A Former User
                                      I make a developer tools module for displaying notification and payload Read there :)
                                      I think it can help you
                                        @Bugsounet Very interesting. This also looks promising. I’ll comment in the other topic.
                                          @Bugsounet I noticed in my pihole logs that there were at least 10 DNS queries for Spotify per second, something is not right. The actual refresh rate for the module is set to 3000 ms. I had to disable the module.
                                            A Former User
                                            i correct it with last update :)
                                            1.3.2 (2020-05-15)
                                            Modified: onStart script (Now launched if Spotify initialized)
                                            Added: "Cast" Icons
                                            1.3.1 (2020-05-14)
                                            Modified: 'progress bar'
                                            Fixed: number of request on idle (depend now of updateInterval config)
                                            • 12
                                            • 13
                                            • 7 / 13
