mmm-wu-moon-phases - Moonphases from Weather Underground
Hi, here is my first Magic Mirror module based on the module CurrentWeather. The module shows the current moon phase, a picture of the moon and the percentage of the illumination. You can find the module here.
- for default value Switzerland.
Nice module! Thanks for shareing.
You need to change the name of the module in the example code, from ‘mmm-wu-moon-phases’ to ‘mmm-wu-moonphase’:
wrong:
module: ‘mmm-wu-moon-phases’,
header: ‘Current Moon Phase’, // optionally you can add a header to this block
position: ‘top_right’, // this can be any of the regions.
// See ‘Configuration options’ for more information.
apikey: ‘abcde12345abcde12345abcde12345ab’,
country: ‘Switzerland’,
city: ‘Bern’,
apiLang: ‘EN’,} },
right:
module: ‘mmm-wu-moonphase’,
city: ‘Bern’,
apiLang: ‘EN’,} },
@schlachtkreuzer6
Hi can you help me with the api key. Also I took an acount it’s to hard for me to find a way to the right datas for Vienna Austria.
Can’t find a way to the right site, boring system.
Thank you in Advance
Kurt
@kurt Hey Kurt
or servus! yeah sure i will help you!
- go to this site: https://www.wunderground.com/weather/api/
- klick on the explore my options button
- it doesn´t matter what package you´re choosing all 3 are free, only if you need more data requests as 500 a day (10 per minute)
- register to the site with your email etc.
@kurt and in the config:
{ module: 'mmm-wu-moonphase', header: 'Aktuelle Mondphase', // optionally you can add a header to this block position: 'top_right', // this can be any of the regions. config: { // See 'Configuration options' for more information. apikey: 'your api', country: 'Austria', city: 'Vienna', apiLang: 'DL', } },
@schlachtkreuzer6
Ahhh I looked for the country and city settings on the Weather U ground…but you have to do it in the config. Right?
Thanks for quick help!
Kurt
@kurt yeah, you are right! all module specific changes and settings are in the main config
~/MagicMirror/config/
@schlachtkreuzer6
Danke ! I can see the New Moon, at least some shades of him or her
Thanks a lot ! works fine, only when I tell himmiddle_ right
the screen stays black. But withtop_right
everythings works out fine.
kurt
Hello Kurt
As first, thanks to @schlachtkreuzer6 for quickly answering the questions of Kurt.
Kurt, I hope it worked and yes, at the moment we have new moon and you see only a weak shadow.
If you need help, please contact me. I can also support you in your native language.
Greetings from switzerland
