    mmm-wu-moon-phases - Moonphases from Weather Underground
    moonphase
    25 Posts 9 Posters 22.5k Views 9 Watching
    • K Offline
      kurt @schlachtkreuzer6
      @schlachtkreuzer6
      Hi can you help me with the api key. Also I took an acount it’s to hard for me to find a way to the right datas for Vienna Austria.
      Can’t find a way to the right site, boring system.
      Thank you in Advance
      Kurt
      schlachtkreuzer6S 2 Replies Last reply Reply Quote 0
      • schlachtkreuzer6S Offline
        schlachtkreuzer6 @kurt
        @kurt Hey Kurt :) or servus! yeah sure i will help you!
        1. go to this site: https://www.wunderground.com/weather/api/
        2. klick on the explore my options button
        3. it doesn´t matter what package you´re choosing all 3 are free, only if you need more data requests as 500 a day (10 per minute)
        4. register to the site with your email etc.
          @kurt and in the config:
          	module: 'mmm-wu-moonphase',
          	header: 'Aktuelle Mondphase',   // optionally you can add a header to this block
          	position: 'top_right',  // this can be any of the regions.
          			apikey: 'your api',
          			country: 'Austria',
          		city: 'Vienna',
          		apiLang: 'DL',
          • K Offline
            @schlachtkreuzer6
            Ahhh I looked for the country and city settings on the Weather U ground…but you have to do it in the config. Right?
            Thanks for quick help!
            Kurt
            schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
              @kurt yeah, you are right! all module specific changes and settings are in the main config ~/MagicMirror/config/
              • K Offline
                @schlachtkreuzer6
                Danke ! I can see the New Moon, at least some shades of him or her :)
                Thanks a lot ! works fine, only when I tell him middle_ rightthe screen stays black. But with top_right everythings works out fine.
                kurt
                  Raffaello
                  Hello Kurt
                  As first, thanks to @schlachtkreuzer6 for quickly answering the questions of Kurt.
                  Kurt, I hope it worked and yes, at the moment we have new moon and you see only a weak shadow.
                  If you need help, please contact me. I can also support you in your native language. :-)
                  Greetings from switzerland
                  K 2 Replies Last reply Reply Quote 1
                  • K Offline
                    kurt @Raffaello
                    @Raffaello
                    Hi
                    Thank you and Dankeschön for the offer to help me in my native language.
                    Der Tag wird kommen :)
                    Oisdan bisdan
                    Kurt
                    • K Offline
                      kurt @Raffaello
                      @Raffaello
                      Hallo Raffaello
                      The day has come…your moonphase doesn’t load anymore, and I don’t no why, because I havn’t changed a thing.
                      I updated the rpi some days ago, but the fault was also bevor the update.
                      I hope you can help, cause by now I miss the moon already.
                      And by the way Gratulation to the Swiss Tennis Finale. Love to watch both of them !
                      Liebe Grüße aus Wien
                      Starting MagicMirror: v2.1.0
                      Loading config ...
                      Loading module helpers ...
                      No helper found for module: mmm-wu-moonphase.
                      All module helpers loaded.
                      Starting server op port 8080 ...
                      Server started ...
                      Connecting socket for: internet-monitor
                      internet-monitor helper started ...
                      Connecting socket for: mmm-systemtemperature
                      Starting node helper: mmm-systemtemperature
                      Connecting socket for: MMM-WienerLinien
                      Starting module: MMM-WienerLinien
                      Starting module: newsfeed
                      (node:6133) DeprecationWarning: sys is deprecated. Use util instead.
                      Launching application.
                      starting internet monitor node helper
                      Create new news fetcher for url: http://derStandard.at/?page=rss&ressort=Seite1 - Interval: 300000
                        Raffaello
                        Hello Kurt, have checked on two raspi the module and it works with both. Can you upload your config.js?
