    mmm-wu-moon-phases - Moonphases from Weather Underground
    moonphase
    25 Posts 9 Posters 24.4k Views 9 Watching
      Raffaello
      Hi, here is my first Magic Mirror module based on the module CurrentWeather. The module shows the current moon phase, a picture of the moon and the percentage of the illumination. You can find the module here.
      • T
        tajno
        • for default value Switzerland.
        Nice module! Thanks for shareing.
          schlachtkreuzer6
          You need to change the name of the module in the example code, from ‘mmm-wu-moon-phases’ to ‘mmm-wu-moonphase’:
          wrong:
          module: ‘mmm-wu-moon-phases’,
          header: ‘Current Moon Phase’, // optionally you can add a header to this block
          position: ‘top_right’, // this can be any of the regions.
          // See ‘Configuration options’ for more information.
          apikey: ‘abcde12345abcde12345abcde12345ab’,
          country: ‘Switzerland’,
          city: ‘Bern’,
          apiLang: ‘EN’,
          right:
          module: ‘mmm-wu-moonphase’,
          city: ‘Bern’,
          apiLang: ‘EN’,
          • K
            kurt @schlachtkreuzer6
            @schlachtkreuzer6
            Hi can you help me with the api key. Also I took an acount it’s to hard for me to find a way to the right datas for Vienna Austria.
            Can’t find a way to the right site, boring system.
            Thank you in Advance
            Kurt
              schlachtkreuzer6 @kurt
              @kurt Hey Kurt :) or servus! yeah sure i will help you!
              1. go to this site: https://www.wunderground.com/weather/api/
              2. klick on the explore my options button
              3. it doesn´t matter what package you´re choosing all 3 are free, only if you need more data requests as 500 a day (10 per minute)
              4. register to the site with your email etc.
                @kurt and in the config:
                	module: 'mmm-wu-moonphase',
                	header: 'Aktuelle Mondphase',   // optionally you can add a header to this block
                	position: 'top_right',  // this can be any of the regions.
                			apikey: 'your api',
                			country: 'Austria',
                		city: 'Vienna',
                		apiLang: 'DL',
                • K
                  @schlachtkreuzer6
                  Ahhh I looked for the country and city settings on the Weather U ground…but you have to do it in the config. Right?
                  Thanks for quick help!
                  Kurt
                    @kurt yeah, you are right! all module specific changes and settings are in the main config ~/MagicMirror/config/
                    • K
                      @schlachtkreuzer6
                      Danke ! I can see the New Moon, at least some shades of him or her :)
                      Thanks a lot ! works fine, only when I tell him middle_ rightthe screen stays black. But with top_right everythings works out fine.
                      kurt
                        Raffaello
                        Hello Kurt
                        As first, thanks to @schlachtkreuzer6 for quickly answering the questions of Kurt.
                        Kurt, I hope it worked and yes, at the moment we have new moon and you see only a weak shadow.
                        If you need help, please contact me. I can also support you in your native language. :-)
                        Greetings from switzerland
                        K 2 Replies Last reply Reply Quote 1
                        • K
                          kurt @Raffaello
                          @Raffaello
                          Hi
                          Thank you and Dankeschön for the offer to help me in my native language.
                          Der Tag wird kommen :)
                          Oisdan bisdan
                          Kurt
                          • K
                            kurt @Raffaello
                            @Raffaello
                            Hallo Raffaello
                            The day has come…your moonphase doesn’t load anymore, and I don’t no why, because I havn’t changed a thing.
                            I updated the rpi some days ago, but the fault was also bevor the update.
                            I hope you can help, cause by now I miss the moon already.
                            And by the way Gratulation to the Swiss Tennis Finale. Love to watch both of them !
                            Liebe Grüße aus Wien
                            Starting MagicMirror: v2.1.0
                            Loading config ...
                            Loading module helpers ...
                            No helper found for module: mmm-wu-moonphase.
                            All module helpers loaded.
                            Starting server op port 8080 ...
                            Server started ...
                            Connecting socket for: internet-monitor
                            internet-monitor helper started ...
                            Connecting socket for: mmm-systemtemperature
                            Starting node helper: mmm-systemtemperature
                            Connecting socket for: MMM-WienerLinien
                            Starting module: MMM-WienerLinien
                            Starting module: newsfeed
                            (node:6133) DeprecationWarning: sys is deprecated. Use util instead.
                            Launching application.
                            starting internet monitor node helper
                            Create new news fetcher for url: http://derStandard.at/?page=rss&ressort=Seite1 - Interval: 300000
                              Raffaello
                              Hello Kurt, have checked on two raspi the module and it works with both. Can you upload your config.js?
                              • K
                                kurt @Raffaello
                                @Raffaello
                                Hallo Raffaello
                                this is my config.js
                                Thank you
                                /* Magic Mirror Config Sample
                                 * MIT Licensed.
                                var config = {
                                	port: 8080,
                                        ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                                	language: 'de',
                                	timeFormat: 24,
                                	units: 'metric',
                                		    module: 'internet-monitor',
                                            position: 'top_center',
                                            header: '',
                                            config:{
                                                type: '',
                                                maxTime: 20000,
                                                updateInterval: 0,
                                                verbose: false,
                                                displayStrength: true,
                                                displaySpeed: false,
                                                strengthIconSize: 80,
                                                maxGaugeScale: 100,
                                	         position: 'bottom_right',  // this can be any of the regions.
                                			apikey: ' xxxxxx ',
                                			country: 'Austria',
                                		        city: 'Vienna',
                                		        apiLang: 'DL',
                                		module: 'mmm-systemtemperature',
                                		position: 'top_center',	// This can be any of the regions.
                                		classes: 'small dimmed', // Add your own styling. Optional.
                                                          module: "MMM-WienerLinien",
                                                        position: "bottom_left",
                                                         api_key: "xxxxxxx",
                                                         stations: ["141"],
                                			module: 'alert',
                                			module: "updatenotification",
                                			position: "top_bar"
                                			module: 'clock',
                                			position: 'top_left'
                                			module: 'compliments',
                                			position: 'lower_third'
                                			module: 'currentweather',
                                				locationID: '2761369',  //ID from http://www.openweathermap.org
                                				appid: 'xxxxxxxx'
                                			module: 'weatherforecast',
                                			header: 'Weather Forecast',
                                				appid: 'xxxxxxx'
                                			module: 'newsfeed',
                                			position: 'bottom_bar',
                                				feeds: [
                                						title: "Der Standard",
                                						url: "http://derStandard.at/?page=rss&ressort=Seite1"
                                				showSourceTitle: true,
                                				showPublishDate: true
                                • Y
                                  yawns Moderator @kurt
                                  @kurt
                                  what do you mean by “doesn’t load any more” ? Do you see any error message? Did the whole mirror stop working? Or is it simply “gone” ?
                                  K 1 Reply Last reply Reply Quote 1
                                  • K
                                    kurt @yawns
                                    @yawns
                                    I just see: Aktuelle Mondphase wird geladen...is loading
                                    • K
                                      kurt @kurt
                                      @yawns
                                      to completely answer your questions… sorry got a phone call…
                                      The whole mirror is working, the module isn’t gone, I do not see any error messages,
                                      Thank you
                                        JoeFranz
                                        In my display the state of the moon appears in english and the lighting down in German. Why is not this completely in German?
                                        Someone an idea?
                                        Jörg
                                        • G
                                          geeflaxx @JoeFranz
                                          can i use the same api key what i use for my weather underground ? or should i edit something?
                                          because i have the same error like kurt. it always shows me “moonphase wird geladen”
                                          is the comma after the apiLang: correct ?
                                          apiLang: ‘DL’, <-------------------------------
                                            Raffaello
                                            Yes, you can use the same api key and yes, the comma to apiLang is correct.
                                            What happens if you enter the link directly in the browser?
                                            http://api.wunderground.com/api/“apikey”/astronomy/lang:“language”/q/“country”/“city”.json
                                            Replace the " "-placeholders accordingly.
