    mmm-wu-moon-phases - Moonphases from Weather Underground
    moonphase
    25 Posts 9 Posters 24.4k Views 9 Watching
    • K
      kurt @schlachtkreuzer6
      @schlachtkreuzer6
      Hi can you help me with the api key. Also I took an acount it’s to hard for me to find a way to the right datas for Vienna Austria.
      Can’t find a way to the right site, boring system.
      Thank you in Advance
      Kurt
        schlachtkreuzer6 @kurt
        @kurt Hey Kurt :) or servus! yeah sure i will help you!
        1. go to this site: https://www.wunderground.com/weather/api/
        2. klick on the explore my options button
        3. it doesn´t matter what package you´re choosing all 3 are free, only if you need more data requests as 500 a day (10 per minute)
        4. register to the site with your email etc.
          @kurt and in the config:
          	module: 'mmm-wu-moonphase',
          	header: 'Aktuelle Mondphase',   // optionally you can add a header to this block
          	position: 'top_right',  // this can be any of the regions.
          			apikey: 'your api',
          			country: 'Austria',
          		city: 'Vienna',
          		apiLang: 'DL',
          • K
            @schlachtkreuzer6
            Ahhh I looked for the country and city settings on the Weather U ground…but you have to do it in the config. Right?
            Thanks for quick help!
            Kurt
              @kurt yeah, you are right! all module specific changes and settings are in the main config ~/MagicMirror/config/
              • K
                @schlachtkreuzer6
                Danke ! I can see the New Moon, at least some shades of him or her :)
                Thanks a lot ! works fine, only when I tell him middle_ rightthe screen stays black. But with top_right everythings works out fine.
                kurt
                  Raffaello
                  Hello Kurt
                  As first, thanks to @schlachtkreuzer6 for quickly answering the questions of Kurt.
                  Kurt, I hope it worked and yes, at the moment we have new moon and you see only a weak shadow.
                  If you need help, please contact me. I can also support you in your native language. :-)
                  Greetings from switzerland
                  K 2 Replies Last reply Reply Quote 1
                  • K
                    kurt @Raffaello
                    @Raffaello
                    Hi
                    Thank you and Dankeschön for the offer to help me in my native language.
                    Der Tag wird kommen :)
                    Oisdan bisdan
                    Kurt
                    • K
                      kurt @Raffaello
                      @Raffaello
                      Hallo Raffaello
                      The day has come…your moonphase doesn’t load anymore, and I don’t no why, because I havn’t changed a thing.
                      I updated the rpi some days ago, but the fault was also bevor the update.
                      I hope you can help, cause by now I miss the moon already.
                      And by the way Gratulation to the Swiss Tennis Finale. Love to watch both of them !
                      Liebe Grüße aus Wien
                      Starting MagicMirror: v2.1.0
                      Loading config ...
                      Loading module helpers ...
                      No helper found for module: mmm-wu-moonphase.
                      All module helpers loaded.
                      Starting server op port 8080 ...
                      Server started ...
                      Connecting socket for: internet-monitor
                      internet-monitor helper started ...
                      Connecting socket for: mmm-systemtemperature
                      Starting node helper: mmm-systemtemperature
                      Connecting socket for: MMM-WienerLinien
                      Starting module: MMM-WienerLinien
                      Starting module: newsfeed
                      (node:6133) DeprecationWarning: sys is deprecated. Use util instead.
                      Launching application.
                      starting internet monitor node helper
                      Create new news fetcher for url: http://derStandard.at/?page=rss&ressort=Seite1 - Interval: 300000
                        Raffaello
                        Hello Kurt, have checked on two raspi the module and it works with both. Can you upload your config.js?
                        • K
                          kurt @Raffaello
                          @Raffaello
                          Hallo Raffaello
                          this is my config.js
                          Thank you
                          /* Magic Mirror Config Sample
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                                  ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                          	language: 'de',
                          	timeFormat: 24,
                          	units: 'metric',
                          		    module: 'internet-monitor',
                                      position: 'top_center',
                                      header: '',
                                      config:{
                                          type: '',
                                          maxTime: 20000,
                                          updateInterval: 0,
                                          verbose: false,
                                          displayStrength: true,
                                          displaySpeed: false,
                                          strengthIconSize: 80,
                                          maxGaugeScale: 100,
                          	         position: 'bottom_right',  // this can be any of the regions.
                          			apikey: ' xxxxxx ',
                          			country: 'Austria',
                          		        city: 'Vienna',
                          		        apiLang: 'DL',
                          		module: 'mmm-systemtemperature',
                          		position: 'top_center',	// This can be any of the regions.
                          		classes: 'small dimmed', // Add your own styling. Optional.
                                                    module: "MMM-WienerLinien",
                                                  position: "bottom_left",
                                                   api_key: "xxxxxxx",
                                                   stations: ["141"],
                          			module: 'alert',
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: 'clock',
                          			position: 'top_left'
                          			module: 'compliments',
                          			position: 'lower_third'
                          			module: 'currentweather',
                          				locationID: '2761369',  //ID from http://www.openweathermap.org
                          				appid: 'xxxxxxxx'
                          			module: 'weatherforecast',
                          			header: 'Weather Forecast',
                          				appid: 'xxxxxxx'
                          			module: 'newsfeed',
                          			position: 'bottom_bar',
                          				feeds: [
                          						title: "Der Standard",
                          						url: "http://derStandard.at/?page=rss&ressort=Seite1"
                          				showSourceTitle: true,
                          				showPublishDate: true
                          • Y
                            yawns Moderator @kurt
                            @kurt
                            what do you mean by “doesn’t load any more” ? Do you see any error message? Did the whole mirror stop working? Or is it simply “gone” ?
                            K 1 Reply Last reply Reply Quote 1
                            • K
                              kurt @yawns
                              @yawns
                              I just see: Aktuelle Mondphase wird geladen...is loading
                              • K
                                kurt @kurt
                                @yawns
                                to completely answer your questions… sorry got a phone call…
                                The whole mirror is working, the module isn’t gone, I do not see any error messages,
                                Thank you
                                  JoeFranz
                                  In my display the state of the moon appears in english and the lighting down in German. Why is not this completely in German?
                                  Someone an idea?
                                  Jörg
                                  • G
                                    geeflaxx @JoeFranz
                                    can i use the same api key what i use for my weather underground ? or should i edit something?
                                    because i have the same error like kurt. it always shows me “moonphase wird geladen”
                                    is the comma after the apiLang: correct ?
                                    apiLang: ‘DL’, <-------------------------------
                                      Raffaello
                                      Yes, you can use the same api key and yes, the comma to apiLang is correct.
                                      What happens if you enter the link directly in the browser?
                                      http://api.wunderground.com/api/“apikey”/astronomy/lang:“language”/q/“country”/“city”.json
                                      Replace the " "-placeholders accordingly.
                                      • K
                                        kurt @Raffaello
                                        @Raffaello
                                        Hi, I don’t know why, but your module is working fine by now, i put it on an other place and that’s it. I havn’t changed a bit on the modul or the config, just the moon didn’t liked the old place.:last_quarter_moon_with_face:
                                        So I just want to inform you about that. Sometimes it’s hard to find the reason, when there is none.
                                        • qu1queQ
                                          qu1que Project Sponsor
                                          Hello, first of all, thanks for the module, I find it quite interesting. I tried to install it, but I found a problem trying to get the api key from Weather Underground. By accessing the following link: https://www.wunderground.com/weather/api says that “we will no longer provide free weather API keys”.
                                          Do you know if it is possible to use an api key from openweathermap.org? If it is not possible, I think that the module can not be used.
                                          Thanks in advance for the answer
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @qu1que
                                            @qu1que
                                            You cannot use an API key from another API provider. However, until the issue with WU is corrected, you can use another module that requires no API key.
                                            https://github.com/mykle1/MMM-Lunartic
                                            qu1queQ 1 Reply Last reply Reply Quote 0
