    mmm-wu-moon-phases - Moonphases from Weather Underground
    moonphase
    25 Posts 9 Posters 23.7k Views 9 Watching
    • K Offline
      kurt @schlachtkreuzer6
      @schlachtkreuzer6
      Ahhh I looked for the country and city settings on the Weather U ground…but you have to do it in the config. Right?
      Thanks for quick help!
      Kurt
        schlachtkreuzer6 @kurt
        @kurt yeah, you are right! all module specific changes and settings are in the main config ~/MagicMirror/config/
        • K Offline
          @schlachtkreuzer6
          Danke ! I can see the New Moon, at least some shades of him or her :)
          Thanks a lot ! works fine, only when I tell him middle_ rightthe screen stays black. But with top_right everythings works out fine.
          kurt
            Raffaello
            Hello Kurt
            As first, thanks to @schlachtkreuzer6 for quickly answering the questions of Kurt.
            Kurt, I hope it worked and yes, at the moment we have new moon and you see only a weak shadow.
            If you need help, please contact me. I can also support you in your native language. :-)
            Greetings from switzerland
            K 2 Replies Last reply Reply Quote 1
            • K Offline
              kurt @Raffaello
              @Raffaello
              Hi
              Thank you and Dankeschön for the offer to help me in my native language.
              Der Tag wird kommen :)
              Oisdan bisdan
              Kurt
              • K Offline
                kurt @Raffaello
                @Raffaello
                Hallo Raffaello
                The day has come…your moonphase doesn’t load anymore, and I don’t no why, because I havn’t changed a thing.
                I updated the rpi some days ago, but the fault was also bevor the update.
                I hope you can help, cause by now I miss the moon already.
                And by the way Gratulation to the Swiss Tennis Finale. Love to watch both of them !
                Liebe Grüße aus Wien
                Starting MagicMirror: v2.1.0
                Loading config ...
                Loading module helpers ...
                No helper found for module: mmm-wu-moonphase.
                All module helpers loaded.
                Starting server op port 8080 ...
                Server started ...
                Connecting socket for: internet-monitor
                internet-monitor helper started ...
                Connecting socket for: mmm-systemtemperature
                Starting node helper: mmm-systemtemperature
                Connecting socket for: MMM-WienerLinien
                Starting module: MMM-WienerLinien
                Starting module: newsfeed
                (node:6133) DeprecationWarning: sys is deprecated. Use util instead.
                Launching application.
                starting internet monitor node helper
                Create new news fetcher for url: http://derStandard.at/?page=rss&ressort=Seite1 - Interval: 300000
                  Raffaello
                  Hello Kurt, have checked on two raspi the module and it works with both. Can you upload your config.js?
                  • K Offline
                    kurt @Raffaello
                    @Raffaello
                    Hallo Raffaello
                    this is my config.js
                    Thank you
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                            ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
                    	language: 'de',
                    	timeFormat: 24,
                    	units: 'metric',
                    		    module: 'internet-monitor',
                                position: 'top_center',
                                header: '',
                                config:{
                                    type: '',
                                    maxTime: 20000,
                                    updateInterval: 0,
                                    verbose: false,
                                    displayStrength: true,
                                    displaySpeed: false,
                                    strengthIconSize: 80,
                                    maxGaugeScale: 100,
                    	         module: 'mmm-wu-moonphase',
                    	         header: 'Aktuelle Mondphase',   // optionally you can add a header to this block
                    	         position: 'bottom_right',  // this can be any of the regions.
                    			apikey: ' xxxxxx ',
                    			country: 'Austria',
                    		        city: 'Vienna',
                    		        apiLang: 'DL',
                    		module: 'mmm-systemtemperature',
                    		position: 'top_center',	// This can be any of the regions.
                    		classes: 'small dimmed', // Add your own styling. Optional.
                                              module: "MMM-WienerLinien",
                                            position: "bottom_left",
                                             api_key: "xxxxxxx",
                                             stations: ["141"],
                    			module: 'alert',
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: 'clock',
                    			position: 'top_left'
                    			module: 'compliments',
                    			position: 'lower_third'
                    			module: 'currentweather',
                    			position: 'top_right',
                    				locationID: '2761369',  //ID from http://www.openweathermap.org
                    				appid: 'xxxxxxxx'
                    			module: 'weatherforecast',
                    			header: 'Weather Forecast',
                    				appid: 'xxxxxxx'
                    			module: 'newsfeed',
                    			position: 'bottom_bar',
                    				feeds: [
                    						title: "Der Standard",
                    						url: "http://derStandard.at/?page=rss&ressort=Seite1"
                    				showSourceTitle: true,
                    				showPublishDate: true
                    • Y Offline
                      yawns Moderator @kurt
                      @kurt
                      what do you mean by “doesn’t load any more” ? Do you see any error message? Did the whole mirror stop working? Or is it simply “gone” ?
                      K 1 Reply Last reply Reply Quote 1
                      • K Offline
                        kurt @yawns
                        @yawns
                        I just see: Aktuelle Mondphase wird geladen...is loading
                        • K Offline
                          kurt @kurt
                          @yawns
                          to completely answer your questions… sorry got a phone call…
                          The whole mirror is working, the module isn’t gone, I do not see any error messages,
                          Thank you
                            JoeFranz
                            In my display the state of the moon appears in english and the lighting down in German. Why is not this completely in German?
                            Someone an idea?
                            Jörg
                            • G Offline
                              geeflaxx @JoeFranz
                              can i use the same api key what i use for my weather underground ? or should i edit something?
                              because i have the same error like kurt. it always shows me “moonphase wird geladen”
                              is the comma after the apiLang: correct ?
                              apiLang: ‘DL’, <-------------------------------
                                Raffaello
                                Yes, you can use the same api key and yes, the comma to apiLang is correct.
                                What happens if you enter the link directly in the browser?
                                http://api.wunderground.com/api/“apikey”/astronomy/lang:“language”/q/“country”/“city”.json
                                Replace the " "-placeholders accordingly.
                                • K Offline
                                  kurt @Raffaello
                                  @Raffaello
                                  Hi, I don’t know why, but your module is working fine by now, i put it on an other place and that’s it. I havn’t changed a bit on the modul or the config, just the moon didn’t liked the old place.:last_quarter_moon_with_face:
                                  So I just want to inform you about that. Sometimes it’s hard to find the reason, when there is none.
                                  • qu1queQ Offline
                                    qu1que Project Sponsor
                                    Hello, first of all, thanks for the module, I find it quite interesting. I tried to install it, but I found a problem trying to get the api key from Weather Underground. By accessing the following link: https://www.wunderground.com/weather/api says that “we will no longer provide free weather API keys”.
                                    Do you know if it is possible to use an api key from openweathermap.org? If it is not possible, I think that the module can not be used.
                                    Thanks in advance for the answer
                                      Mykle1 Project Sponsor Module Developer @qu1que
                                      @qu1que
                                      You cannot use an API key from another API provider. However, until the issue with WU is corrected, you can use another module that requires no API key.
                                      https://github.com/mykle1/MMM-Lunartic
                                      qu1queQ 1 Reply Last reply Reply Quote 0
                                      • qu1queQ Offline
                                        qu1que Project Sponsor @Mykle1
                                        @mykle1 Thanks. Cool module! I will try it.
                                          @qu1que said in mmm-wu-moon-phases - Moonphases from Weather Underground:
                                          You’re welcome. I hope you like it
