    mmm-wu-moon-phases - Moonphases from Weather Underground
    moonphase
    25 Posts 9 Posters 23.0k Views 9 Watching
    • K Offline
      kurt @Raffaello
      @Raffaello
      Hi, I don’t know why, but your module is working fine by now, i put it on an other place and that’s it. I havn’t changed a bit on the modul or the config, just the moon didn’t liked the old place.:last_quarter_moon_with_face:
      So I just want to inform you about that. Sometimes it’s hard to find the reason, when there is none.
      • qu1queQ Offline
        qu1que Project Sponsor
        Hello, first of all, thanks for the module, I find it quite interesting. I tried to install it, but I found a problem trying to get the api key from Weather Underground. By accessing the following link: https://www.wunderground.com/weather/api says that “we will no longer provide free weather API keys”.
        Do you know if it is possible to use an api key from openweathermap.org? If it is not possible, I think that the module can not be used.
        Thanks in advance for the answer
          Mykle1 Project Sponsor Module Developer @qu1que
          @qu1que
          You cannot use an API key from another API provider. However, until the issue with WU is corrected, you can use another module that requires no API key.
          https://github.com/mykle1/MMM-Lunartic
          qu1queQ 1 Reply Last reply Reply Quote 0
          • qu1queQ Offline
            qu1que Project Sponsor @Mykle1
            @mykle1 Thanks. Cool module! I will try it.
              @qu1que said in mmm-wu-moon-phases - Moonphases from Weather Underground:
              You’re welcome. I hope you like it
