    mmm-wu-moon-phases - Moonphases from Weather Underground
    moonphase
    25 Posts 9 Posters 24.0k Views 9 Watching
    • K Offline
      kurt @Raffaello
      @Raffaello
      Hallo Raffaello
      The day has come…your moonphase doesn’t load anymore, and I don’t no why, because I havn’t changed a thing.
      I updated the rpi some days ago, but the fault was also bevor the update.
      I hope you can help, cause by now I miss the moon already.
      And by the way Gratulation to the Swiss Tennis Finale. Love to watch both of them !
      Liebe Grüße aus Wien
      Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: mmm-wu-moonphase.
      All module helpers loaded.
      Starting server op port 8080 ...
      Server started ...
      Connecting socket for: internet-monitor
      internet-monitor helper started ...
      Connecting socket for: mmm-systemtemperature
      Starting node helper: mmm-systemtemperature
      Connecting socket for: MMM-WienerLinien
      Starting module: MMM-WienerLinien
      Starting module: newsfeed
      (node:6133) DeprecationWarning: sys is deprecated. Use util instead.
      Launching application.
      starting internet monitor node helper
      Create new news fetcher for url: http://derStandard.at/?page=rss&ressort=Seite1 - Interval: 300000
        Raffaello
        Hello Kurt, have checked on two raspi the module and it works with both. Can you upload your config.js?
        K 2 Replies Last reply Reply Quote 1
        • K Offline
          kurt @Raffaello
          @Raffaello
          Hallo Raffaello
          this is my config.js
          Thank you
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
                  ipWhitelist: ["::fff:0.0.0.0/1", "::fff:128.0.0.0/2", "::fff:192.0.0.0/3", "::fff:224.0.0.0/4", "127.0.0.1", "::ffff:127.0.0.1", "::1"],
          	language: 'de',
          	timeFormat: 24,
          	units: 'metric',
          		    module: 'internet-monitor',
                      position: 'top_center',
                      header: '',
                      config:{
                          type: '',
                          maxTime: 20000,
                          updateInterval: 0,
                          verbose: false,
                          displayStrength: true,
                          displaySpeed: false,
                          strengthIconSize: 80,
                          maxGaugeScale: 100,
          	         module: 'mmm-wu-moonphase',
          	         header: 'Aktuelle Mondphase',   // optionally you can add a header to this block
          	         position: 'bottom_right',  // this can be any of the regions.
          			apikey: ' xxxxxx ',
          			country: 'Austria',
          		        city: 'Vienna',
          		        apiLang: 'DL',
          		module: 'mmm-systemtemperature',
          		position: 'top_center',	// This can be any of the regions.
          		classes: 'small dimmed', // Add your own styling. Optional.
                                    module: "MMM-WienerLinien",
                                  position: "bottom_left",
                                   api_key: "xxxxxxx",
                                   stations: ["141"],
          			module: 'alert',
          			module: "updatenotification",
          			position: "top_bar"
          			module: 'clock',
          			position: 'top_left'
          			module: 'compliments',
          			position: 'lower_third'
          			module: 'currentweather',
          			position: 'top_right',
          				locationID: '2761369',  //ID from http://www.openweathermap.org
          				appid: 'xxxxxxxx'
          			module: 'weatherforecast',
          			header: 'Weather Forecast',
          				appid: 'xxxxxxx'
          			module: 'newsfeed',
          			position: 'bottom_bar',
          				feeds: [
          						title: "Der Standard",
          						url: "http://derStandard.at/?page=rss&ressort=Seite1"
          				showSourceTitle: true,
          				showPublishDate: true
          • Y Offline
            yawns Moderator @kurt
            @kurt
            what do you mean by “doesn’t load any more” ? Do you see any error message? Did the whole mirror stop working? Or is it simply “gone” ?
            K 1 Reply Last reply Reply Quote 1
            • K Offline
              kurt @yawns
              @yawns
              I just see: Aktuelle Mondphase wird geladen...is loading
              • K Offline
                kurt @kurt
                @yawns
                to completely answer your questions… sorry got a phone call…
                The whole mirror is working, the module isn’t gone, I do not see any error messages,
                Thank you
                  JoeFranz
                  In my display the state of the moon appears in english and the lighting down in German. Why is not this completely in German?
                  Someone an idea?
                  Jörg
                  • G Offline
                    geeflaxx @JoeFranz
                    can i use the same api key what i use for my weather underground ? or should i edit something?
                    because i have the same error like kurt. it always shows me “moonphase wird geladen”
                    is the comma after the apiLang: correct ?
                    apiLang: ‘DL’, <-------------------------------
                      Raffaello
                      Yes, you can use the same api key and yes, the comma to apiLang is correct.
                      What happens if you enter the link directly in the browser?
                      http://api.wunderground.com/api/“apikey”/astronomy/lang:“language”/q/“country”/“city”.json
                      Replace the " "-placeholders accordingly.
                      • K Offline
                        kurt @Raffaello
                        @Raffaello
                        Hi, I don’t know why, but your module is working fine by now, i put it on an other place and that’s it. I havn’t changed a bit on the modul or the config, just the moon didn’t liked the old place.:last_quarter_moon_with_face:
                        So I just want to inform you about that. Sometimes it’s hard to find the reason, when there is none.
                        • qu1queQ Offline
                          qu1que Project Sponsor
                          Hello, first of all, thanks for the module, I find it quite interesting. I tried to install it, but I found a problem trying to get the api key from Weather Underground. By accessing the following link: https://www.wunderground.com/weather/api says that “we will no longer provide free weather API keys”.
                          Do you know if it is possible to use an api key from openweathermap.org? If it is not possible, I think that the module can not be used.
                          Thanks in advance for the answer
                            Mykle1 Project Sponsor Module Developer @qu1que
                            @qu1que
                            You cannot use an API key from another API provider. However, until the issue with WU is corrected, you can use another module that requires no API key.
                            https://github.com/mykle1/MMM-Lunartic
                            qu1queQ 1 Reply Last reply Reply Quote 0
                            • qu1queQ Offline
                              qu1que Project Sponsor @Mykle1
                              @mykle1 Thanks. Cool module! I will try it.
                                @qu1que said in mmm-wu-moon-phases - Moonphases from Weather Underground:
                                You’re welcome. I hope you like it
