MMM-ModuleScheduler, how to hide it ?
Hello, very happy with MMM-ModuleScheduler and the supporting MMM-Remote-Control. Almost all working fine.
It’s just that I can be a bit of a stickler for detail. Both modules allow me to show and hide modules manually or set by some time schedule except … MMM-ModuleScheduler itself. I just don’t appear to be able to hide the module on the screen.
Have been trying a number of things including manual control via MMM-Remote-Control (works fine), copying schedule from another module on the display that are know to respond correctly to MMM-ModuleScheduler (fails), add a header to to module (works fine).
So at the moment my mirror shows MMM-ModuleScheduler, module_9_MMM-ModuleScheduler in the bottom_left section of the screen.
The fact I can manually hide the MMM-ModuleScheduler using MMM-Remote-Control means it must be possible, but how ?
Anyone out there that can point me in the direction as to how to hide this module on the screen ?
@Clogs Remove the
position: bottom_left(or wherever it is) entry from the config section for yourMMM-ModuleScheduler? Alternatively if you already have the Remote Control installed, you can save hide the module, and then save the config. The module will then be hidden directly after startup.Full disclosure: I am the main author of the
MMM-Remote-Control. -
@Jopyth, thank you for the reply. Like to keep it simple. Removed position: and schedule elements from my config entry for your MMM-ModuleScheduler module. and all working fine now.
