    Help with Update to 2.7.0
    13 Posts 5 Posters 6.4k Views 5 Watching
    • K Offline
      Kenny
      Sorry if this is an obvious question. I tried to update to 2.7.0.
      From the MagicMirror folder, I type git pull && npm install
      But the only response I see is “Updating de57daa…b508a62”. The I get the prompt back in a couple seconds.
        sdetweil @Kenny
        @Kenny try it one at a time
        git pull
        then
        npm install
        • K Offline
          Kenny
          @sdetweil : Thanks. I gave that a try.
          git pull
          npm install
          [installs MagicMirror 2.6.0]
            sdetweil @Kenny
            @Kenny could u do
            git remote -v
            • K Offline
              Kenny
              git remote -v
              RESPONSE:
              origin https://github.com/MichMich/MagicMirror.git (fetch)
              origin https://github.com/MichMich/MagicMirror.git (push)
              • CyruS1337C Offline
                CyruS1337 Project Sponsor
                Run the following command in the MagicMirror folder
                rm package-lock.json
                rm vendor/package-lock.json
                Then execute in the folder the usual command for the upload
                Now it should work
                Atelier-Made-in-iKiA 1 Reply Last reply Reply Quote 2
                • K Offline
                  Kenny
                  Thanks for the help @sdetweil and @CyruS1337. The latest suggestion gave me the same "Updating … " response.
                  I just renamed my MagicMirror folder and did a clean install. Everything is working great again. THANKS!
                  • Atelier-Made-in-iKiA Offline
                    Atelier-Made-in-iKi @CyruS1337
                    @CyruS1337 said in Help with Update to 2.7.0:
                    Now it should work
                    @CyruS1337 this solved the firt install command but…
                    ownloading tmp-2822-0-electron-v3.0.13-linux-armv7l.zip
                    Error: read ECONNRESET
                    /home/pi/MagicMirror/node_modules/electron/install.js:49
                      throw err
                        at TLSWrap.onStreamRead (internal/stream_base_commons.js:111:27)
                    npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! electron@3.0.13 postinstall: `node install.js`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the electron@3.0.13 postinstall script.
                    npm ERR!     /home/pi/.npm/_logs/2019-04-05T19_09_38_688Z-debug.log
                    pi@raspberrypi:~/MagicMirror $
                    > magicmirror@2.7.1 start /home/pi/MagicMirror
                    > sh run-start.sh
                    run-start.sh: 4: run-start.sh: electron: not found
                    npm ERR! file sh
                    npm ERR! errno ENOENT
                    npm ERR! syscall spawn
                    npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
                    npm ERR! spawn ENOENT
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.7.1 start script.
                    if an idea
                    thanks
                    Jean-Philippe
                    • swvalentiS Offline
                      swvalenti Project Sponsor
                      pi@raspberrypi:~ $ cd MagicMirror
                      pi@raspberrypi:~/MagicMirror $ git remote -v
                      pi@raspberrypi:~/MagicMirror $ rm package-lock.json
                      pi@raspberrypi:~/MagicMirror $ rm vendor/package-lock.json
                      pi@raspberrypi:~/MagicMirror $ git pull && npm install
                      Updating de57daa..b508a62
                      Still have the same issue and can’t update…any help would be appreciated.
                        sdetweil
                        @swvalenti said in Help with Update to 2.7.0:
                        ok, lets try this
                        git stash
                        git pull
                        if ok, then npm install
