    npm install error
    11 Posts 3 Posters 5.6k Views 3 Watching
    • E Offline
      emrhssla
      I am working with my friend on a project. When I downloaded what my friend had been working on with my raspberry pie and installed npm start, I got the error:
      0_1555310776532_d9fb8868-2613-4b33-a10d-a0d7000d7d14-image.png 0_15
      Friend’s environment is Mac, and I downloaded it to the raspberry pie.
      My freiend’s repository is https://github.com/ENTITYSmartMirror/BeautyMirrorTEST
      Friend installed and used python-shell module on April 15.
      /home/pi/Desktop/BeautyMirrorTEST/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron: 1: /home/pi/Desktop/BeautyMirrorTEST/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron: ���� � 0: not found
      /home/pi/Desktop/BeautyMirrorTEST/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron: 4: /home/pi/Desktop/BeautyMirrorTEST/node_modules/electron/dist/Electron.app/Contents/MacOS/Electron: Syntax error: word unexpected (expecting “)”)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 2
      npm ERR! magicmirror@2.6.0 start: sh run-start.sh
      npm ERR! Exit status 2
      npm ERR!
      npm ERR! Failed at the magicmirror@2.6.0 start script.
      npm ERR! /home/pi/.npm/_logs/2019-04-15T06_36_00_871Z-debug.log
      • G Offline
        ganget
        I’m not really sure what your question is, or if you even have a question?
        I’m making the assumption that your question is: why do you get the errors? That is probably because mac and RPI have 2 totally diferrent operatings systems.
        The errors are a result of that, This bold part of the error is telling that the ellection.app is installed on MacOS: "Electron.app/Contents/MacOS/Electron: 1: " But you are running it on a RPI.
        To solve this you can do a clean install of MagicMirror on the RPI and install the modules as well. Then copy the changed config files, probably being config.js and custom.css
          sdetweil @emrhssla
          @emrhssla ok, so you are installing a clone of MM… its ok, do that all the time.
          after the git clone, then u do npm install, right?
          he has copied the node_modules folder into his repo… u don’t want that…
          so, go to the folder
          and do
          rm -rf node_modules
          npm install
          then try the
          npm start dev &
          and have him remove the node_modules folder from his git repo
          and from all the modules which have a node_modules folder…
          and the vendor folder too
          the platforms are different, you cannot copy the binary runtimes
          G E 2 Replies Last reply Reply Quote 0
            sdetweil
            This post is deleted!
            • G Offline
              ganget @sdetweil
              @sdetweil Same problem identification, way better solution!
              • E Offline
                emrhssla @sdetweil
                pi@raspberrypi:~/Desktop/Chanyoung/BeautyMirrorTEST $ rm -rf node_modules
                pi@raspberrypi:~/Desktop/Chanyoung/BeautyMirrorTEST $ npm install
                npm ERR! code ENOLOCAL
                npm ERR! Could not install from "node_modules/danger/vm2@github:patriksimek/vm2#7e82f90ac705fc44fad044147cb0df09b4c79a57" as it does not contain a package.json file.
                npm ERR!     /home/pi/.npm/_logs/2019-04-15T12_43_25_301Z-debug.log
                  sdetweil @emrhssla
                  @emrhssla AND delete node_modules from all locations, right? vendor and all modules
                  from the MM folder do
                  WATCH OUT, THIS WILL ERASE ALL THE node_modules IN THE EMBEDED MagicMirror
                  find . | grep node_modules$ | xargs rm -rf
                  and
                  find . | grep package-lock.json | xargs rm
                  this erases all the mac based stuff that should not have been added to the repo
                  then
                  npm install
                    @emrhssla also delete the package-lock.json files in the few folders
                    • E Offline
                      emrhssla @ganget
                      @ganget
                      I think cleaning is the answer too…
                      • E Offline
                        emrhssla @sdetweil
                        pi@pi:~/newTest $ npm start
                        > magicmirror@2.6.0 start /home/pi/newTest
                        > sh run-start.sh
                        Starting MagicMirror: v2.6.0
                        Loading config ...
                        Loading module helpers ...
                        No helper found for module: MMM-iFrame.
                        No helper found for module: MMM-EmbedYoutube1.
                        No helper found for module: MMM-Modulebar1.
                        No helper found for module: MMM-Modulebar.
                        No helper found for module: MMM-Dynamic-Modules.
                        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
                        App threw an error during load
                            at Module._resolveFilename (module.js:543:15)
                            at Function.Module._resolveFilename (/home/pi/newTest/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                            at Function.Module._load (module.js:473:25)
                            at Module.require (module.js:586:17)
                            at require (internal/module.js:11:18)
                            at Object.<anonymous> (/home/pi/newTest/modules/default/updatenotification/node_helper.js:6:18)
                            at Object.<anonymous> (/home/pi/newTest/modules/default/updatenotification/node_helper.js:92:3)
                            at Module._compile (module.js:642:30)
                            at Object.Module._extensions..js (module.js:653:10)
                            at Module.load (module.js:561:32)
                        { Error: Cannot find module 'node_helper'
                            at Module.load (module.js:561:32) code: 'MODULE_NOT_FOUND' }
                        Launching application.
                          sdetweil @emrhssla
                          @emrhssla yeh, my fault… i had u erase too much, there is a supplied node_helper module in the modules folder…
                          you can copy it from the /pi/MagicMirror installation
                          cp -r ~/MagicMirror/modules/node_modules/node_helper ~/newTest/modules/node_modules
