    node_helper.js does not work.
    21 Posts 2 Posters 7.9k Views 2 Watching
    • E Offline
      emrhssla
      I transferred what I had done with Mac to the Raspberry pie. I only tried the basic reservation code because the result I wanted was not available. But it didn’t work, either.
      It’s good at Mac. Why not at Raspberry Pi?
      MMM-TestPython.js
      var Testpythons;
      Module.register("MMM-Testpython", {
          defaults: {},
          start: function (){
              Testpythons = this;
        getDom: function() {
          var element = document.createElement("div")
          element.className = "myContent"
          element.id="divid"
          element.innerHTML = "Hello, World!!! " + this.config.foo
          var subElement = document.createElement("p")
          subElement.innerHTML = "Click"
          subElement.id = "clickid"
          element.appendChild(subElement)
          return element
        notificationReceived: function(notification, payload, sender) {
          switch(notification) {
            case "DOM_OBJECTS_CREATED":
            var elem = document.getElementById("clickid")
            elem.addEventListener("click", () => {
              Testpythons.sendSocketNotification("TEST")
              console.log("hello~hello~hello~hello~hello~hello~hello~hello~hello~hello~")
              elem.innerHTML = "click success"
              break
            case "I_DID":
              console.log("Socket recevied : "+payload)
              var elemk = document.getElementById("divid")
              elemk.innerHTML = payload
              break
      node_helper.js
      var NodeHelper = require("node_helper");
      var socketTestpython;
        start: function() {
          socketTestpython=this;
            case "TEST":
              console.log("notification : " + notification)
      	socketTestpython.sendSocketNotification("I_DID",'hello');
              break
      npm start dev &
      in terminal=>
      pi@raspberrypi:~/Desktop/MagicMirror $ npm start dev &
      [1] 1452
      magicmirror@2.7.1 start /home/pi/Desktop/MagicMirror
      sh run-start.sh “dev”
      Starting MagicMirror: v2.7.1
      Loading config …
      Loading module helpers …
      Initializing new module helper …
      No helper found for module: helloworld.
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Sockets connected & modules started …
      Launching application.
        sdetweil @emrhssla
        @emrhssla which MM are u working in?
        /home/pi/Desktop/Beauty (see its config/config.js
        or
        /home/pi/Desktop/Beauty/MagicMirror one? (see ITS config/config.js
        they are different (u have MagicMirror installed INSIDE a MagicMirror folder)
        to fix this, in /home/pi/Desktop/Beauty do
        mv MagicMirror ..
        now you will have
        and
        E 1 Reply Last reply Reply Quote 1
          sdetweil @emrhssla
          @emrhssla what is the error?
          open a terminal window or ssh window
          do
          npm start dev &
          node_helper output will show up in the terminal window
          then on the mirror UI, developers window
          select the console tab
          note that the filenames are CASE sensitive
          so you code should be in
          mm/modules/MMM-TestPython
          • E Offline
            emrhssla @sdetweil
            in terminal, output is
            [1] 1452
            Loading config …
            Server started …
            after click,That’s all.
            There are no errors, and console.log() is not visible from the terminal window.
              sdetweil @emrhssla
              @emrhssla i cut/pasted your code to create your module, added it to config.js
              and it performs as expected…
              i get in developers console
              hello~hello~hello~hello~hello~hello~hello~hello~hello~hello~    MMM-Testpython.js:62
               Socket recevied : hello                                        MMM-Testpython.js:71
              and in terminal window
              notification : TEST
              config entry
                module: "MMM-Testpython",
                disabled: false,
                position: "middle",
                config:{
                sdetweil
                after the npm start &
                press enter… you should get the prompt back, and can do any command
                add this to your node module start function
                  start: function() {
                    console.log(this.name + " node_helper started")    // < ---- add this
                should see this in terminal window
                MMM-Testpython node_helper started
                i do
                • E Offline
                  emrhssla @sdetweil
                    sdetweil @emrhssla
                    @emrhssla that console output doesn’t make sense… cause u should have seen this line at least
                    Module helper loaded: MMM-Testpython
                    before the
                    show me your config.js
                    • E Offline
                      emrhssla @sdetweil
                      /* Magic Mirror Config Sample
                       * MIT Licensed.
                      var config = {
                      	address: "0.0.0.0", // Address to listen on, can be:
                      	port: 8080,
                      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","172.16.100.133", "::ffff:172.16.100.133", "::1"], // Set [] to allow all IP addresses
                      	language: "en",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: 'MMM-iFrame',
                      			position: "bottom_center",	// This can be any of the regions.
                      					url: ["https://comic.naver.com/webtoon/weekday.nhn"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
                      					updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
                      					width: "2000", // width of iframe
                      					height: "1800", // height of iframe
                      					frameWidth: "950", // width of embedded iframe, height is beeing calculated by aspect ratio of iframe
                      		//1
                      			module: "MMM-EmbedYoutube1",
                      			position: "bottom_bar",
                      				video_id: "w3jLJU7DT5E",
                      				searchlist1: "쯔위",
                      				loop: true
                      		//2
                                  module: "MMM-Modulebar1",
                                  classes: "default everyone",
                                  module: "MMM-Modulebar",
                                  module: "MMM-Dynamic-Modules",
                      			module: "alert",
                      			module: "updatenotification",
                      			position: "top_bar"
                      			module: "clock",
                      			position: "top_right"
                      			module: "newsfeed",
                      				feeds: [
                      						title: "New York Times",
                      				showSourceTitle: true,
                      				showPublishDate: true
                      			  disabled: false,
                      			  position: "middle",
                      			  config:{
                        sdetweil @emrhssla
                        @emrhssla that doesn’t match with the terminal window output…
                        in terminal window only
                        Loading config …
                        Module helper loaded: updatenotification   < ----
                        No helper found for module: helloworld. < -----
                        Server started …
                        there are only two modules referenced…
                        never mind, two of mine don’t have position and work fine
                        delete ---------also, all modules require a position
                          sdetweil
                          this what I see on my startup in the terminal window, before the node_modules start outputing their text
                          Starting MagicMirror: v2.7.0-develop
                          Loading config ...
                          Loading module helpers ...
                          handler helper in init
                          Module helper loaded: MMM-SleepWake
                          Module helper loaded: MMM-ImagesPhotos
                          Module helper loaded: MMM-AssistantMk2
                          Module helper loaded: MMM-Hotword
                          Module helper loaded: WaterLevels
                          Starting server on port 8086 ...
                          You're using a full whitelist configuration to allow for all IPs
                          Server started ...
                          Connecting socket for: MMM-SleepWake
                          handler helper in start
                          Connecting socket for: MMM-ImagesPhotos
                          Starting node helper for: MMM-ImagesPhotos
                          Starting module: newsfeed
                          Connecting socket for: MMM-AssistantMk2
                          Connecting socket for: MMM-Hotword
                          MMM-Hotword started
                          Connecting socket for: WaterLevels
                          Starting module: WaterLevels
                          Connecting socket for: MMM-Testpython
                          MMM-Testpythonnode_helper started
                          • E Offline
                            emrhssla @sdetweil
                             * MIT Licensed.
                            var config = {
                            	port: 8080,
                            	language: "en",
                            	timeFormat: 24,
                            	units: "metric",
                            		//1
                            				searchlist1: "쯔위",
                            				loop: true
                            		//2
                            			position: "top_bar"
                            			module: "clock",
                            			module: "newsfeed",
                            				feeds: [
                            			  disabled: false,
                            			  position: "middle",
                            			  config:{
                            It’s the same. :(
                            pi@raspberrypi:~/Desktop/Beauty/MagicMirror $ npm start &
                            [1] 3066
                            > magicmirror@2.7.1 start /home/pi/Desktop/Beauty/MagicMirror
                            > sh run-start.sh
                            Loading config ...
                            Server started ...
                              sdetweil @emrhssla
                              @emrhssla show me output of
                              ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
                              • E Offline
                                emrhssla @sdetweil
                                pi@raspberrypi:~ $ ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
                                total 20
                                drwxr-xr-x 2 pi pi 4096 Apr 15 22:18 ./
                                drwxr-xr-x 17 pi pi 4096 Apr 15 22:16 …/
                                -rw-r–r-- 1 pi pi 2960 Apr 15 2019 config.js
                                -rw-r–r-- 1 pi pi 2623 Apr 15 22:11 config.js.sample
                                -rw-r–r-- 1 pi pi 13 Apr 15 22:29 .gitignore
                                  sdetweil @emrhssla
                                  @emrhssla ok, trying to replicate… moved mine to desktop/MagicMirror and it worked ok,
                                  working on installing that repo
                                  • E Offline
                                    emrhssla @sdetweil
                                    @sdetweil I don’t see what the problem is.
                                    After upgrading the npm and node to the latest version, I installed the Magic Mirror, and I wonder if that’s the problem.
                                    And I did the npm install python3 and I don’t think this is the cause.
                                      sdetweil @emrhssla
                                      @emrhssla will advise once I see it myself
                                        sdetweil @emrhssla
                                        or
                                        mv MagicMirror ..
                                        now you will have
                                        and
                                        • E Offline
                                          emrhssla @sdetweil
                                          I first ran a magic mirror at /home/pi/Desktop/MagicMirror . But after failing, another one was installed. Running /home/pi/Desktop/Beauty/MagicMirror gave the same result.
                                          In conclusion, there are two magic mirrors: /home/pi/Desktop/MagicMirror and /home/pi/Desktop/Beauty/MagicMirror.
                                          I’ll try it tomorrow, but maybe it doesn’t matter.
                                            sdetweil @emrhssla
                                            @emrhssla when the mirror app is running, can u access from another system at http://mirror_ip:mirror_port
                                            • E Offline
                                              emrhssla @sdetweil
                                              @sdetweil said in node_helper.js does not work.:
                                              I solved it!!
                                              A month ago, /fi/MagicMirror was installed.
                                              /pi/Magicmirror puts the code above, so node_helper.js work well.
                                              But I don’t know why /pi/Desktop/Beauty/Magicmirror isn’t working. Is this because of /pi/Magicmirror?
                                              Thanks to you, I solved it. Thank you all the time.
