    node_helper.js does not work.
    21 Posts 2 Posters 7.4k Views 2 Watching
      sdetweil @emrhssla
      @emrhssla i cut/pasted your code to create your module, added it to config.js
      and it performs as expected…
      i get in developers console
      hello~hello~hello~hello~hello~hello~hello~hello~hello~hello~    MMM-Testpython.js:62
       Socket recevied : hello                                        MMM-Testpython.js:71
      and in terminal window
      notification : TEST
      config entry
        module: "MMM-Testpython",
        disabled: false,
        position: "middle",
        config:{
        after the npm start &
        press enter… you should get the prompt back, and can do any command
        add this to your node module start function
          start: function() {
            socketTestpython=this;
            console.log(this.name + " node_helper started")    // < ---- add this
        should see this in terminal window
        MMM-Testpython node_helper started
        i do
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          emrhssla @sdetweil
            sdetweil @emrhssla
            @emrhssla that console output doesn’t make sense… cause u should have seen this line at least
            Module helper loaded: MMM-Testpython
            before the
            Launching application
            show me your config.js
            • E Offline
              emrhssla @sdetweil
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	address: "0.0.0.0", // Address to listen on, can be:
              	port: 8080,
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","172.16.100.133", "::ffff:172.16.100.133", "::1"], // Set [] to allow all IP addresses
              	language: "en",
              	timeFormat: 24,
              	units: "metric",
              			module: 'MMM-iFrame',
              			position: "bottom_center",	// This can be any of the regions.
              					url: ["https://comic.naver.com/webtoon/weekday.nhn"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
              					updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
              					width: "2000", // width of iframe
              					height: "1800", // height of iframe
              					frameWidth: "950", // width of embedded iframe, height is beeing calculated by aspect ratio of iframe
              		//1
              			module: "MMM-EmbedYoutube1",
              			position: "bottom_bar",
              				video_id: "w3jLJU7DT5E",
              				searchlist1: "쯔위",
              				loop: true
              		//2
                          module: "MMM-Modulebar1",
                          classes: "default everyone",
                          module: "MMM-Modulebar",
                          module: "MMM-Dynamic-Modules",
              			module: "alert",
              			module: "updatenotification",
              			position: "top_bar"
              			module: "clock",
              			position: "top_right"
              			module: "newsfeed",
              				feeds: [
              						title: "New York Times",
              				showSourceTitle: true,
              				showPublishDate: true
              			  disabled: false,
              			  position: "middle",
              			  config:{
                sdetweil @emrhssla
                @emrhssla that doesn’t match with the terminal window output…
                in terminal window only
                Starting MagicMirror: v2.7.1
                Loading config …
                Loading module helpers …
                Module helper loaded: updatenotification   < ----
                No helper found for module: helloworld. < -----
                All module helpers loaded.
                Starting server on port 8080 …
                Server started …
                Sockets connected & modules started …
                Launching application.
                there are only two modules referenced…
                never mind, two of mine don’t have position and work fine
                delete ---------also, all modules require a position
                  this what I see on my startup in the terminal window, before the node_modules start outputing their text
                  Starting MagicMirror: v2.7.0-develop
                  Loading config ...
                  Loading module helpers ...
                  handler helper in init
                  Module helper loaded: MMM-SleepWake
                  Module helper loaded: MMM-ImagesPhotos
                  Module helper loaded: MMM-AssistantMk2
                  Module helper loaded: MMM-Hotword
                  Module helper loaded: WaterLevels
                  Starting server on port 8086 ...
                  You're using a full whitelist configuration to allow for all IPs
                  Server started ...
                  Connecting socket for: MMM-SleepWake
                  handler helper in start
                  Connecting socket for: MMM-ImagesPhotos
                  Starting node helper for: MMM-ImagesPhotos
                  Starting module: newsfeed
                  Connecting socket for: MMM-AssistantMk2
                  Connecting socket for: MMM-Hotword
                  MMM-Hotword started
                  Connecting socket for: WaterLevels
                  Starting module: WaterLevels
                  Connecting socket for: MMM-Testpython
                  MMM-Testpythonnode_helper started
                  • E Offline
                    emrhssla @sdetweil
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    		//1
                    				searchlist1: "쯔위",
                    				loop: true
                    		//2
                    			position: "top_bar"
                    			module: "clock",
                    			module: "newsfeed",
                    				feeds: [
                    			  disabled: false,
                    			  position: "middle",
                    			  config:{
                    It’s the same. :(
                    pi@raspberrypi:~/Desktop/Beauty/MagicMirror $ npm start &
                    [1] 3066
                    > magicmirror@2.7.1 start /home/pi/Desktop/Beauty/MagicMirror
                    > sh run-start.sh
                    Loading config ...
                    Server started ...
                      sdetweil @emrhssla
                      @emrhssla show me output of
                      ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
                      • E Offline
                        emrhssla @sdetweil
                        pi@raspberrypi:~ $ ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
                        total 20
                        drwxr-xr-x 2 pi pi 4096 Apr 15 22:18 ./
                        drwxr-xr-x 17 pi pi 4096 Apr 15 22:16 …/
                        -rw-r–r-- 1 pi pi 2960 Apr 15 2019 config.js
                        -rw-r–r-- 1 pi pi 2623 Apr 15 22:11 config.js.sample
                        -rw-r–r-- 1 pi pi 13 Apr 15 22:29 .gitignore
