    node_helper.js does not work.
    21 Posts 2 Posters 8.7k Views 2 Watching
      sdetweil @emrhssla
      @emrhssla that doesn’t match with the terminal window output…
      in terminal window only
      Starting MagicMirror: v2.7.1
      Loading config …
      Loading module helpers …
      Module helper loaded: updatenotification   < ----
      No helper found for module: helloworld. < -----
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Sockets connected & modules started …
      Launching application.
      there are only two modules referenced…
      never mind, two of mine don’t have position and work fine
      delete ---------also, all modules require a position
      E 1 Reply Last reply Reply Quote 1
        this what I see on my startup in the terminal window, before the node_modules start outputing their text
        Starting MagicMirror: v2.7.0-develop
        Loading config ...
        Loading module helpers ...
        handler helper in init
        Module helper loaded: MMM-SleepWake
        Module helper loaded: MMM-ImagesPhotos
        Module helper loaded: MMM-AssistantMk2
        Module helper loaded: MMM-Hotword
        Module helper loaded: WaterLevels
        Module helper loaded: MMM-Testpython
        Starting server on port 8086 ...
        You're using a full whitelist configuration to allow for all IPs
        Server started ...
        Connecting socket for: MMM-SleepWake
        handler helper in start
        Connecting socket for: MMM-ImagesPhotos
        Starting node helper for: MMM-ImagesPhotos
        Starting module: newsfeed
        Connecting socket for: MMM-AssistantMk2
        Connecting socket for: MMM-Hotword
        MMM-Hotword started
        Connecting socket for: WaterLevels
        Starting module: WaterLevels
        Connecting socket for: MMM-Testpython
        MMM-Testpythonnode_helper started
        • E Offline
          emrhssla @sdetweil
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	address: "0.0.0.0", // Address to listen on, can be:
          	port: 8080,
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","172.16.100.133", "::ffff:172.16.100.133", "::1"], // Set [] to allow all IP addresses
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: 'MMM-iFrame',
          			position: "bottom_center",	// This can be any of the regions.
          					url: ["https://comic.naver.com/webtoon/weekday.nhn"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
          					updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
          					width: "2000", // width of iframe
          					height: "1800", // height of iframe
          					frameWidth: "950", // width of embedded iframe, height is beeing calculated by aspect ratio of iframe
          		//1
          			module: "MMM-EmbedYoutube1",
          			position: "bottom_bar",
          				video_id: "w3jLJU7DT5E",
          				searchlist1: "쯔위",
          				loop: true
          		//2
                      module: "MMM-Modulebar1",
                      classes: "default everyone",
                      module: "MMM-Modulebar",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_right"
          			module: "newsfeed",
          				feeds: [
          						title: "New York Times",
          				showSourceTitle: true,
          				showPublishDate: true
          			  module: "MMM-Testpython",
          			  disabled: false,
          			  position: "middle",
          			  config:{
          It’s the same. :(
          pi@raspberrypi:~/Desktop/Beauty/MagicMirror $ npm start &
          [1] 3066
          > magicmirror@2.7.1 start /home/pi/Desktop/Beauty/MagicMirror
          > sh run-start.sh
          Loading config ...
          Server started ...
            sdetweil @emrhssla
            @emrhssla show me output of
            ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
            • E Offline
              emrhssla @sdetweil
              pi@raspberrypi:~ $ ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
              total 20
              drwxr-xr-x 2 pi pi 4096 Apr 15 22:18 ./
              drwxr-xr-x 17 pi pi 4096 Apr 15 22:16 …/
              -rw-r–r-- 1 pi pi 2960 Apr 15 2019 config.js
              -rw-r–r-- 1 pi pi 2623 Apr 15 22:11 config.js.sample
              -rw-r–r-- 1 pi pi 13 Apr 15 22:29 .gitignore
                sdetweil @emrhssla
                @emrhssla ok, trying to replicate… moved mine to desktop/MagicMirror and it worked ok,
                working on installing that repo
                • E Offline
                  emrhssla @sdetweil
                  @sdetweil I don’t see what the problem is.
                  After upgrading the npm and node to the latest version, I installed the Magic Mirror, and I wonder if that’s the problem.
                  And I did the npm install python3 and I don’t think this is the cause.
                    sdetweil @emrhssla
                    @emrhssla will advise once I see it myself
                      sdetweil @emrhssla
                      @emrhssla which MM are u working in?
                      /home/pi/Desktop/Beauty (see its config/config.js
                      or
                      /home/pi/Desktop/Beauty/MagicMirror one? (see ITS config/config.js
                      they are different (u have MagicMirror installed INSIDE a MagicMirror folder)
                      to fix this, in /home/pi/Desktop/Beauty do
                      mv MagicMirror ..
                      now you will have
                      and
                      /home/pi/Desktop/MagicMirror
                      • E Offline
                        emrhssla @sdetweil
                        I first ran a magic mirror at /home/pi/Desktop/MagicMirror . But after failing, another one was installed. Running /home/pi/Desktop/Beauty/MagicMirror gave the same result.
                        In conclusion, there are two magic mirrors: /home/pi/Desktop/MagicMirror and /home/pi/Desktop/Beauty/MagicMirror.
                        I’ll try it tomorrow, but maybe it doesn’t matter.
                          sdetweil @emrhssla
                          @emrhssla when the mirror app is running, can u access from another system at http://mirror_ip:mirror_port
                          • E Offline
                            emrhssla @sdetweil
                            @sdetweil said in node_helper.js does not work.:
                            I solved it!!
                            A month ago, /fi/MagicMirror was installed.
                            /pi/Magicmirror puts the code above, so node_helper.js work well.
                            But I don’t know why /pi/Desktop/Beauty/Magicmirror isn’t working. Is this because of /pi/Magicmirror?
                            Thanks to you, I solved it. Thank you all the time.
                              sdetweil @emrhssla
                              @emrhssla said in node_helper.js does not work.:
                              because its a mess with all that macOS level binaries installed…
                              i had to
                              rm -rf  ~/Desktop/Beauty/node_modules/electron
                              cp ~/MagicMirror/node_modules/electron ~/Desktop/Beauty/node_modules
                              to get the UI to show on the pi…
                              i tested before by executing Electron to show some page
                              in a terminal window ON THE PI
                              do
                              ~/Desktop/Beauty/node_modules/electron/dist/electron http://cnn.com
                              this should open electron to show some web page
                              initially I got a frame, with empty insides
