    node_helper.js does not work.
    21 Posts 2 Posters 7.5k Views 2 Watching
    • E Offline
      emrhssla @sdetweil
      in terminal, output is
      pi@raspberrypi:~/Desktop/MagicMirror $ npm start dev &
      [1] 1452
      magicmirror@2.7.1 start /home/pi/Desktop/MagicMirror
      sh run-start.sh “dev”
      Starting MagicMirror: v2.7.1
      Loading config …
      Loading module helpers …
      No helper found for module: helloworld.
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Sockets connected & modules started …
      Launching application.
      after click,That’s all.
      There are no errors, and console.log() is not visible from the terminal window.
        sdetweil @emrhssla
        @emrhssla i cut/pasted your code to create your module, added it to config.js
        and it performs as expected…
        i get in developers console
        hello~hello~hello~hello~hello~hello~hello~hello~hello~hello~    MMM-Testpython.js:62
         Socket recevied : hello                                        MMM-Testpython.js:71
        and in terminal window
        notification : TEST
        config entry
          module: "MMM-Testpython",
          disabled: false,
          position: "middle",
          config:{
          after the npm start &
          press enter… you should get the prompt back, and can do any command
          add this to your node module start function
            start: function() {
              socketTestpython=this;
              console.log(this.name + " node_helper started")    // < ---- add this
          should see this in terminal window
          MMM-Testpython node_helper started
          i do
          E 1 Reply Last reply Reply Quote 1
          • E Offline
            emrhssla @sdetweil
              sdetweil @emrhssla
              @emrhssla that console output doesn’t make sense… cause u should have seen this line at least
              Module helper loaded: MMM-Testpython
              before the
              show me your config.js
              • E Offline
                emrhssla @sdetweil
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	address: "0.0.0.0", // Address to listen on, can be:
                	port: 8080,
                	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","172.16.100.133", "::ffff:172.16.100.133", "::1"], // Set [] to allow all IP addresses
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                			module: 'MMM-iFrame',
                			position: "bottom_center",	// This can be any of the regions.
                					url: ["https://comic.naver.com/webtoon/weekday.nhn"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
                					updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
                					width: "2000", // width of iframe
                					height: "1800", // height of iframe
                					frameWidth: "950", // width of embedded iframe, height is beeing calculated by aspect ratio of iframe
                		//1
                			module: "MMM-EmbedYoutube1",
                			position: "bottom_bar",
                				video_id: "w3jLJU7DT5E",
                				searchlist1: "쯔위",
                				loop: true
                		//2
                            module: "MMM-Modulebar1",
                            classes: "default everyone",
                            module: "MMM-Modulebar",
                            module: "MMM-Dynamic-Modules",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_right"
                			module: "newsfeed",
                				feeds: [
                						title: "New York Times",
                				showSourceTitle: true,
                				showPublishDate: true
                			  disabled: false,
                			  position: "middle",
                			  config:{
                  sdetweil @emrhssla
                  @emrhssla that doesn’t match with the terminal window output…
                  in terminal window only
                  Loading config …
                  Module helper loaded: updatenotification   < ----
                  No helper found for module: helloworld. < -----
                  Server started …
                  there are only two modules referenced…
                  never mind, two of mine don’t have position and work fine
                  delete ---------also, all modules require a position
                    this what I see on my startup in the terminal window, before the node_modules start outputing their text
                    Starting MagicMirror: v2.7.0-develop
                    Loading config ...
                    Loading module helpers ...
                    handler helper in init
                    Module helper loaded: MMM-SleepWake
                    Module helper loaded: MMM-ImagesPhotos
                    Module helper loaded: MMM-AssistantMk2
                    Module helper loaded: MMM-Hotword
                    Module helper loaded: WaterLevels
                    Starting server on port 8086 ...
                    You're using a full whitelist configuration to allow for all IPs
                    Server started ...
                    Connecting socket for: MMM-SleepWake
                    handler helper in start
                    Connecting socket for: MMM-ImagesPhotos
                    Starting node helper for: MMM-ImagesPhotos
                    Starting module: newsfeed
                    Connecting socket for: MMM-AssistantMk2
                    Connecting socket for: MMM-Hotword
                    MMM-Hotword started
                    Connecting socket for: WaterLevels
                    Starting module: WaterLevels
                    Connecting socket for: MMM-Testpython
                    MMM-Testpythonnode_helper started
                    • E Offline
                      emrhssla @sdetweil
                       * MIT Licensed.
                      var config = {
                      	port: 8080,
                      	language: "en",
                      	timeFormat: 24,
                      	units: "metric",
                      		//1
                      				searchlist1: "쯔위",
                      				loop: true
                      		//2
                      			position: "top_bar"
                      			module: "clock",
                      			module: "newsfeed",
                      				feeds: [
                      			  disabled: false,
                      			  position: "middle",
                      			  config:{
                      It’s the same. :(
                      pi@raspberrypi:~/Desktop/Beauty/MagicMirror $ npm start &
                      [1] 3066
                      > magicmirror@2.7.1 start /home/pi/Desktop/Beauty/MagicMirror
                      > sh run-start.sh
                      Loading config ...
                      Server started ...
                        sdetweil @emrhssla
                        @emrhssla show me output of
                        ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
