    node_helper.js does not work.
    21 Posts 2 Posters 7.3k Views 2 Watching
    • E Offline
      emrhssla @sdetweil
        sdetweil @emrhssla
        @emrhssla that console output doesn’t make sense… cause u should have seen this line at least
        Module helper loaded: MMM-Testpython
        before the
        Launching application
        show me your config.js
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          emrhssla @sdetweil
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	address: "0.0.0.0", // Address to listen on, can be:
          	port: 8080,
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","172.16.100.133", "::ffff:172.16.100.133", "::1"], // Set [] to allow all IP addresses
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: 'MMM-iFrame',
          			position: "bottom_center",	// This can be any of the regions.
          					url: ["https://comic.naver.com/webtoon/weekday.nhn"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
          					updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
          					width: "2000", // width of iframe
          					height: "1800", // height of iframe
          					frameWidth: "950", // width of embedded iframe, height is beeing calculated by aspect ratio of iframe
          		//1
          			module: "MMM-EmbedYoutube1",
          			position: "bottom_bar",
          				video_id: "w3jLJU7DT5E",
          				searchlist1: "쯔위",
          				loop: true
          		//2
                      module: "MMM-Modulebar1",
                      classes: "default everyone",
                      module: "MMM-Modulebar",
                      module: "MMM-Dynamic-Modules",
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_right"
          			module: "newsfeed",
          				feeds: [
          						title: "New York Times",
          				showSourceTitle: true,
          				showPublishDate: true
          			  module: "MMM-Testpython",
          			  disabled: false,
          			  position: "middle",
          			  config:{
            sdetweil @emrhssla
            @emrhssla that doesn’t match with the terminal window output…
            in terminal window only
            Starting MagicMirror: v2.7.1
            Loading config …
            Loading module helpers …
            Module helper loaded: updatenotification   < ----
            No helper found for module: helloworld. < -----
            All module helpers loaded.
            Starting server on port 8080 …
            Server started …
            Sockets connected & modules started …
            Launching application.
            there are only two modules referenced…
            never mind, two of mine don’t have position and work fine
            delete ---------also, all modules require a position
              this what I see on my startup in the terminal window, before the node_modules start outputing their text
              Starting MagicMirror: v2.7.0-develop
              Loading config ...
              Loading module helpers ...
              handler helper in init
              Module helper loaded: MMM-SleepWake
              Module helper loaded: MMM-ImagesPhotos
              Module helper loaded: MMM-AssistantMk2
              Module helper loaded: MMM-Hotword
              Module helper loaded: WaterLevels
              Starting server on port 8086 ...
              You're using a full whitelist configuration to allow for all IPs
              Server started ...
              Connecting socket for: MMM-SleepWake
              handler helper in start
              Connecting socket for: MMM-ImagesPhotos
              Starting node helper for: MMM-ImagesPhotos
              Starting module: newsfeed
              Connecting socket for: MMM-AssistantMk2
              Connecting socket for: MMM-Hotword
              MMM-Hotword started
              Connecting socket for: WaterLevels
              Starting module: WaterLevels
              Connecting socket for: MMM-Testpython
              MMM-Testpythonnode_helper started
              • E Offline
                emrhssla @sdetweil
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                		//1
                				searchlist1: "쯔위",
                				loop: true
                		//2
                			position: "top_bar"
                			module: "clock",
                			module: "newsfeed",
                				feeds: [
                			  disabled: false,
                			  position: "middle",
                			  config:{
                It’s the same. :(
                pi@raspberrypi:~/Desktop/Beauty/MagicMirror $ npm start &
                [1] 3066
                > magicmirror@2.7.1 start /home/pi/Desktop/Beauty/MagicMirror
                > sh run-start.sh
                Loading config ...
                Server started ...
                  sdetweil @emrhssla
                  @emrhssla show me output of
                  ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
                  • E Offline
                    emrhssla @sdetweil
                    pi@raspberrypi:~ $ ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
                    total 20
                    drwxr-xr-x 2 pi pi 4096 Apr 15 22:18 ./
                    drwxr-xr-x 17 pi pi 4096 Apr 15 22:16 …/
                    -rw-r–r-- 1 pi pi 2960 Apr 15 2019 config.js
                    -rw-r–r-- 1 pi pi 2623 Apr 15 22:11 config.js.sample
                    -rw-r–r-- 1 pi pi 13 Apr 15 22:29 .gitignore
                      sdetweil @emrhssla
                      @emrhssla ok, trying to replicate… moved mine to desktop/MagicMirror and it worked ok,
                      working on installing that repo
                      • E Offline
                        emrhssla @sdetweil
                        @sdetweil I don’t see what the problem is.
                        After upgrading the npm and node to the latest version, I installed the Magic Mirror, and I wonder if that’s the problem.
                        And I did the npm install python3 and I don’t think this is the cause.
