    node_helper.js does not work.
    21 Posts 2 Posters 9.0k Views 2 Watching
    • E
      emrhssla @sdetweil
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1","172.16.100.133", "::ffff:172.16.100.133", "::1"], // Set [] to allow all IP addresses
      	language: "en",
      	timeFormat: 24,
      	units: "metric",
      			module: 'MMM-iFrame',
      			position: "bottom_center",	// This can be any of the regions.
      					url: ["https://comic.naver.com/webtoon/weekday.nhn"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
      					updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
      					width: "2000", // width of iframe
      					height: "1800", // height of iframe
      					frameWidth: "950", // width of embedded iframe, height is beeing calculated by aspect ratio of iframe
      		//1
      			module: "MMM-EmbedYoutube1",
      			position: "bottom_bar",
      				video_id: "w3jLJU7DT5E",
      				searchlist1: "쯔위",
      				loop: true
      		//2
                  module: "MMM-Modulebar1",
                  classes: "default everyone",
                  module: "MMM-Modulebar",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_right"
      			module: "newsfeed",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      			  module: "MMM-Testpython",
      			  disabled: false,
      			  position: "middle",
      			  config:{
      It’s the same. :(
      pi@raspberrypi:~/Desktop/Beauty/MagicMirror $ npm start &
      [1] 3066
      > magicmirror@2.7.1 start /home/pi/Desktop/Beauty/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.7.1
      Loading config ...
      Loading module helpers ...
      No helper found for module: helloworld.
      All module helpers loaded.
      Server started ...
      Launching application.
        sdetweil @emrhssla
        @emrhssla show me output of
        ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
        E 1 Reply Last reply Reply Quote 1
        • E
          emrhssla @sdetweil
          pi@raspberrypi:~ $ ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
          total 20
          drwxr-xr-x 2 pi pi 4096 Apr 15 22:18 ./
          drwxr-xr-x 17 pi pi 4096 Apr 15 22:16 …/
          -rw-r–r-- 1 pi pi 2960 Apr 15 2019 config.js
          -rw-r–r-- 1 pi pi 2623 Apr 15 22:11 config.js.sample
          -rw-r–r-- 1 pi pi 13 Apr 15 22:29 .gitignore
            sdetweil @emrhssla
            @emrhssla ok, trying to replicate… moved mine to desktop/MagicMirror and it worked ok,
            working on installing that repo
            • E
              emrhssla @sdetweil
              @sdetweil I don’t see what the problem is.
              After upgrading the npm and node to the latest version, I installed the Magic Mirror, and I wonder if that’s the problem.
              And I did the npm install python3 and I don’t think this is the cause.
                sdetweil @emrhssla
                @emrhssla will advise once I see it myself
                  sdetweil @emrhssla
                  @emrhssla which MM are u working in?
                  /home/pi/Desktop/Beauty (see its config/config.js
                  or
                  /home/pi/Desktop/Beauty/MagicMirror one? (see ITS config/config.js
                  they are different (u have MagicMirror installed INSIDE a MagicMirror folder)
                  to fix this, in /home/pi/Desktop/Beauty do
                  mv MagicMirror ..
                  now you will have
                  and
                  /home/pi/Desktop/MagicMirror
                  • E
                    emrhssla @sdetweil
                    I first ran a magic mirror at /home/pi/Desktop/MagicMirror . But after failing, another one was installed. Running /home/pi/Desktop/Beauty/MagicMirror gave the same result.
                    In conclusion, there are two magic mirrors: /home/pi/Desktop/MagicMirror and /home/pi/Desktop/Beauty/MagicMirror.
                    I’ll try it tomorrow, but maybe it doesn’t matter.
                      sdetweil @emrhssla
                      @emrhssla when the mirror app is running, can u access from another system at http://mirror_ip:mirror_port
                      • E
                        emrhssla @sdetweil
                        @sdetweil said in node_helper.js does not work.:
                        I solved it!!
                        A month ago, /fi/MagicMirror was installed.
                        /pi/Magicmirror puts the code above, so node_helper.js work well.
                        But I don’t know why /pi/Desktop/Beauty/Magicmirror isn’t working. Is this because of /pi/Magicmirror?
                        Thanks to you, I solved it. Thank you all the time.
                          sdetweil @emrhssla
                          @emrhssla said in node_helper.js does not work.:
                          because its a mess with all that macOS level binaries installed…
                          i had to
                          rm -rf  ~/Desktop/Beauty/node_modules/electron
                          cp ~/MagicMirror/node_modules/electron ~/Desktop/Beauty/node_modules
                          to get the UI to show on the pi…
                          i tested before by executing Electron to show some page
                          in a terminal window ON THE PI
                          do
                          ~/Desktop/Beauty/node_modules/electron/dist/electron http://cnn.com
                          this should open electron to show some web page
                          initially I got a frame, with empty insides
