    node_helper.js does not work.
    21 Posts 2 Posters 9.0k Views 2 Watching
      sdetweil @emrhssla
      @emrhssla show me output of
      ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
      E 1 Reply Last reply Reply Quote 1
      • E
        emrhssla @sdetweil
        pi@raspberrypi:~ $ ls /home/pi/Desktop/Beauty/MagicMirror/config -laF
        total 20
        drwxr-xr-x 2 pi pi 4096 Apr 15 22:18 ./
        drwxr-xr-x 17 pi pi 4096 Apr 15 22:16 …/
        -rw-r–r-- 1 pi pi 2960 Apr 15 2019 config.js
        -rw-r–r-- 1 pi pi 2623 Apr 15 22:11 config.js.sample
        -rw-r–r-- 1 pi pi 13 Apr 15 22:29 .gitignore
          sdetweil @emrhssla
          @emrhssla ok, trying to replicate… moved mine to desktop/MagicMirror and it worked ok,
          working on installing that repo
          • E
            emrhssla @sdetweil
            @sdetweil I don’t see what the problem is.
            After upgrading the npm and node to the latest version, I installed the Magic Mirror, and I wonder if that’s the problem.
            And I did the npm install python3 and I don’t think this is the cause.
              sdetweil @emrhssla
              @emrhssla will advise once I see it myself
                sdetweil @emrhssla
                @emrhssla which MM are u working in?
                /home/pi/Desktop/Beauty (see its config/config.js
                or
                /home/pi/Desktop/Beauty/MagicMirror one? (see ITS config/config.js
                they are different (u have MagicMirror installed INSIDE a MagicMirror folder)
                to fix this, in /home/pi/Desktop/Beauty do
                mv MagicMirror ..
                now you will have
                and
                /home/pi/Desktop/MagicMirror
                • E
                  emrhssla @sdetweil
                  I first ran a magic mirror at /home/pi/Desktop/MagicMirror . But after failing, another one was installed. Running /home/pi/Desktop/Beauty/MagicMirror gave the same result.
                  In conclusion, there are two magic mirrors: /home/pi/Desktop/MagicMirror and /home/pi/Desktop/Beauty/MagicMirror.
                  I’ll try it tomorrow, but maybe it doesn’t matter.
                    sdetweil @emrhssla
                    @emrhssla when the mirror app is running, can u access from another system at http://mirror_ip:mirror_port
                    • E
                      emrhssla @sdetweil
                      @sdetweil said in node_helper.js does not work.:
                      I solved it!!
                      A month ago, /fi/MagicMirror was installed.
                      /pi/Magicmirror puts the code above, so node_helper.js work well.
                      But I don’t know why /pi/Desktop/Beauty/Magicmirror isn’t working. Is this because of /pi/Magicmirror?
                      Thanks to you, I solved it. Thank you all the time.
                        sdetweil @emrhssla
                        @emrhssla said in node_helper.js does not work.:
                        because its a mess with all that macOS level binaries installed…
                        i had to
                        rm -rf  ~/Desktop/Beauty/node_modules/electron
                        cp ~/MagicMirror/node_modules/electron ~/Desktop/Beauty/node_modules
                        to get the UI to show on the pi…
                        i tested before by executing Electron to show some page
                        in a terminal window ON THE PI
                        do
                        ~/Desktop/Beauty/node_modules/electron/dist/electron http://cnn.com
                        this should open electron to show some web page
                        initially I got a frame, with empty insides
