    Please create a config file
    8 Posts 4 Posters 4.3k Views 3 Watching
      jiminsav
      I have a config file. i tried to add the remote control module exactly like it says on the github page, and it never works…works fine with the sample config. any ideas before i scrub it?
        sdetweil @jiminsav
        @jiminsav sorry, i don’t understand what you said.
        so it does work… like the doc says (sample config)…
        so, what is the next thing you are trying to do… so the config (please use the markdown feature to organize the stuff you post)… three backtics before (ket to left of number 1) and 3 backtics after
          jiminsav
          what i am trying to express, is that Magic Mirror works fine out the box, but when i add the remote module, and edit the config.js file, the magic Mirror shows “please add a config file” when it starts. if i then use the backup and rename it to Config.js, the program works fine.
          i add the module info EXACTLY as it shows in the Github page for the remote control module, and it does not work. i copy and pasted a few examples from this forum, it still does not start Magic Mirror. at this point, it’s pretty worthless if i can’t remote access it.
          B S 2 Replies Last reply Reply Quote 0
            bhepler Module Developer @jiminsav
            @jiminsav - It sounds like there’s an error in the module configuration. So let’s solve that.
            Please copy & paste the module configuration here, using the markdown features. We’ll look it over and see if we can spot the problem.
            The other technique is to run the config checker that is included in the module. Change to your Magic Mirror folder and run npm run config:check
              sdetweil @jiminsav
              @jiminsav yes, the MMM-Remote-Control module text has an error…
                  module: 'MMM-Remote-Control'   // < ---- missing comma, add it
                  // uncomment the following line to show the URL of the remote control on the mirror
                  //  position: 'bottom_left',
                  // you can hide this module afterwards from the remote control itself
                      customCommand: {},  // Optional, See "Using Custom Commands" below
                      customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                      showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                      apiKey: "",         // Optional, See API/README.md for details
              as @bhepler has added, there are ways to check out the config…
                jiminsav
                here is my config file. I don’t understand markdown feature. might not work with FireFox
                • By Michael Teeuw http://michaelteeuw.nl
                • MIT Licensed.
                • For more information how you can configurate this file
                • See https://github.com/MichMich/MagicMirror#configuration
                var config = {
                address: “0.0.0.0”, // Address to listen on, can be:
                // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
                // - “”, “0.0.0.0”, “::” to listen on any interface
                // Default, when address config is left out, is “localhost”
                port: 8080,
                ipWhitelist: [], // Set [] to allow all IP addresses
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                language: "en",
                timeFormat: 24,
                units: "metric",
                		module: "alert",
                		module: "updatenotification",
                		position: "top_bar"
                		module: "clock",
                		position: "top_left"
                		header: "US Holidays",
                					symbol: "calendar-check",
                					url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                		module: "compliments",
                		position: "lower_third"
                		module: "currentweather",
                			locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                			appid: "YOUR_OPENWEATHER_API_KEY"
                		module: "weatherforecast",
                		header: "Weather Forecast",
                			locationID: "5128581",  //ID from https://openweathermap.org/city
                		module: "newsfeed",
                		position: "bottom_bar",
                			feeds: [
                					title: "New York Times",
                			showSourceTitle: true,
                			showPublishDate: true
                			// , position: 'bottom_left'
                if (typeof module !== “undefined”) {module.exports = config;}
                justjim1220J 1 Reply Last reply Reply Quote 0
                • justjim1220J Offline
                  justjim1220 Module Developer @jiminsav
                  @jiminsav said in Please create a config file:
                  missing comma after this line
                  should be:
                  module: 'MMM-Remote-Control',
                  “Life’s Too Short To Dance With Ugly People”
                  Jim Hallock - 1995
                    jiminsav
                    Folks. i figured it out. just commented out everything except the module name and it works. and i did add the comma. thanks
