    Whole font should be displayed brightly
    4 Posts 3 Posters 2.3k Views 2 Watching
    • K Offline
      Klinge
      Hello,
      my bathroom, where my MM is , is too bright. So I would like to have all fonts bright. No darker shades.
      Unfortunately, I could not find anything to this in this forum.
      I would be happy if someone could help me.
      Thanks in advance.
      Lars
        Untested, but I guess this would work…
        Look in main.css:
        https://github.com/MichMich/MagicMirror/blob/master/css/main.css
        .dimmed and .normal are the darker texts. Add these to you custom.css with a brighter color, e.g.:
        .dimmed {
        color: #aaa;
        .normal {
        color: #fff;
        Maybe you also need to override body / color and header / color. Also some modules use their own css names, then you need to override their colors in custom.css as well.
          broberg Project Sponsor
          As retroflex above stated add
          .dimmed {
            color: #fff;
          .normal {
            color: #fff;
          To the custom.css file (this will change almost all text to be white)
          You might also want to change the font weight (from normal to bold) to get a larger amount of light from the monitor.
          So add this to the custom.css as well
          body {
            font-weight: 900;
          .thin {
            font-weight: 300;
          .light {
            font-weight: 500;
          .regular {
            font-weight: 600;
          .bold {
            font-weight: 900;
          Next step is to enlarge everything and/or experiment with other fonts.
          If it’s still not ok, then you need to change the mirror glass you are using or dimm the lights.
          • K Offline
            Klinge
            Hello,
            thank you for your help.
            The changes works.
            Lars
