    MMM-YouTube
    64 Posts 15 Posters 31.9k Views 16 Watching
    • ? Offline
      A Former User
      MMM-YouTube
      MagicMirror module for youtube player with runtime configuration and controllable by notification.
      Feature
      • Embedded YouTube Player on MagicMirror
      • Load and Play videos dynamically on runtime, not only statically by configuration.
      • Almost every YouTube iFrame APIs be supported.
      • Controllable by notification and callback
      • Controllable by MMM-TelegramBot command (You can send youtube video from Phone to MM via TelegramBot)
      Download and Details
      [card:eouia/MMM-YouTube]
      Note
      I know there be some of YouTube modules already, but nothing found to be controllable on runtime. So made it.
      J rafaelcotaR 2 Replies Last reply Reply Quote 1
        juantata @Guest
        @Sean Hi. After installing the module. When I start the MagicMirror I get this error
        magicmirror@2.8.0 start /home/pi/MagicMirror
        sh run-start.sh
        Starting MagicMirror: v2.8.0
        Loading config …
        WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: ReferenceError: disabled is not defined
        at Object. (/home/pi/MagicMirror/config/config.js:86:14)
        at Object. (/home/pi/MagicMirror/config/config.js:210:3)
        at Module._compile (internal/modules/cjs/loader.js:711:30)
        at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
        at Module.load (internal/modules/cjs/loader.js:620:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
        at Function.Module._load (internal/modules/cjs/loader.js:551:3)
        at Module.require (internal/modules/cjs/loader.js:658:17)
        at require (internal/modules/cjs/helpers.js:20:18)
        at loadConfig (/home/pi/MagicMirror/js/app.js:64:12)
        Loading module helpers …
        Initializing new module helper …
        No helper found for module: helloworld.
        All module helpers loaded.
        Starting server on port 8080 …
        Server started …
        Sockets connected & modules started …
        Launching application.
        S ? 2 Replies Last reply Reply Quote 0
          sdetweil @juantata
          @juantata can u paste your config here, three back-tics before and after
          • ? Offline
            A Former User @juantata
            @juantata
            Sorry, there was my mistake. I left my experimental codes on config example. I fixed the README. Back to the page and copy again (Just remove disabled:disabled["MMM-Youtube"], line.)
              juantata @Guest
              @Sean I say: YouTube Michael Jackson Thriller. And the answer is
                juantata @sdetweil
                @sdetweil {
                module: “MMM-YouTube”,
                position: “top_center”,
                verbose:true,
                defaultQuality: “default”,
                disableCC: true,
                showPlayingOnly: true,
                defaultLoop: false,
                defaultShuffle: false,
                defaultAutoplay: true,
                onStartPlay: null,
                playerVars: {
                controls: 0,
                hl: “en”,
                enablejsapi: 1,
                showinfo: 0,
                rel: 0,
                cc_load_policy: 0,
                outNotifications: {
                “-1”: “UNSTARTED”,
                “0”: “ENDED”,
                “1”: “PLAYING”,
                “2”: “PAUSED”,
                “3”: “BUFFERING”,
                “5”: “VIDEO CUED”,
                • ? Offline
                  @juantata it seems not allowed. some clips are limited by right owner not to be played out of youtube
                    sdetweil @juantata
                    @juantata forgot the 3 backticks before and after
                      juantata @sdetweil
                      @sdetweil said in MMM-YouTube:
                      backticks
                      Sorry but I’m a newbie. What do you mean with the three backticks?
                        sdetweil @juantata
                        @juantata on the US keyboard, shifted key left of the number 1 ` (like single quote, but leaning to the left) . the non shifted symbol is tidle ~
                        see https://github.com/adam-p/markdown-here/wiki/Markdown-Cheatsheet
                        Code and Syntax Highlighting
                        • 6
                        • 7
                        • 1 / 7
