    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    Can't get it to work...
    Utilities
      SdeGeata last edited by
      Re: MMM-MyCalendar
      Greetings Jeff;
      I am a newbie to Rpi and ssh, this Magic Mirror is in fact my first Raspberry pi project.
      I have installed the current version of Magic Mirror, as well as the latest version of your MMM-MyCalendar. The module has been dropped into the config file, but it won’t boot anymore. Commenting out your module allows Magic Mirror to load, but I can’t for the life of me find where the error is. I haven’t even got to the point of customizing the module yet in the config.
      The output from terminal is the following, hope you can help:
      > magicmirror@2.7.1 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.7.1
      Loading config ...
      WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:94
      SyntaxError: Unexpected token }
          at new Script (vm.js:74:7)
          at createScript (vm.js:246:10)
          at Object.runInThisContext (vm.js:298:10)
          at Module._compile (internal/modules/cjs/loader.js:678:28)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
          at Module.load (internal/modules/cjs/loader.js:620:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
          at Function.Module._load (internal/modules/cjs/loader.js:551:3)
          at Module.require (internal/modules/cjs/loader.js:658:17)
          at require (internal/modules/cjs/helpers.js:20:18)
      Loading module helpers ...
      No helper found for module: helloworld.
      All module helpers loaded.
      Server started ...
      Launching application.
        SdeGeata @SdeGeata last edited by
        @SdeGeata
        Hello again;
        I found the conflict… had to disable the default calendar first. Everything boots fine afterward. Thanks anyway though.
        • Stoffbeuteluwe
          Stoffbeuteluwe Project Sponsor last edited by
          I have also Problem with the module…
          my Problem is i cant See the night icons only day icons in the Night…thanks for help
          thedoorsfanatic 1 Reply Last reply Reply Quote 0
          • thedoorsfanatic
            thedoorsfanatic @Stoffbeuteluwe last edited by
            @Stoffbeuteluwe
            I changed the icons to new ones via css
            https://www.amcharts.com/free-animated-svg-weather-icons/
            My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
            • Stoffbeuteluwe
              Can you Post the css for mmm-myweather Module?
              I dont know how to change the Icon…
              • thedoorsfanatic
                thedoorsfanatic @Stoffbeuteluwe last edited by thedoorsfanatic
                @Stoffbeuteluwe
                https://forum.magicmirror.builders/topic/9936/total-newbie-24-magicmirror-munich-germany/8
                I am a total beginner and just searched the forum and found this solution. There might be a better way for you since I use a special set of icons
