Raspberry Pi 4 Released !
65 Posts 16 Posters 41.4k Views 13 Watching
    SH20192
    Unfortunately didn’t make it 24 hours of being up. :(
    D 1 Reply Last reply Jun 28, 2019, 5:44 AM Reply Quote 0
      dazza120 @SH20192
      @SH20192 said in Raspberry Pi 4 Released !:
      Nooooooooooo with that spec I wouldn’t have thought there would be any problems 🤦🏾‍♂️😢
      S 1 Reply Last reply Jun 28, 2019, 1:06 PM Reply Quote 0
      • C Offline
        Cr4z33 @dazza120
        @dazza120 ouch correct. :smiling_face_with_open_mouth_cold_sweat:
        On the other board I could place it on the bottom side while on the Rpi you can’t.
          SH20192 @dazza120
          @dazza120 said in Raspberry Pi 4 Released !:
          Me too. The first test I just lost the HDMI signal but it seemed to be up. Second test it all locked up around 4 hours in.
          C 1 Reply Last reply Jun 28, 2019, 1:55 PM Reply Quote 0
          • C Offline
            Cr4z33 @SH20192
            @SH20192 just out of curiosity were you running MagicMirror?
            And if so were you running MMM-Spotify?
            I ask because last update of this module is giving me a black screen.
            My Rpi 4 arrived a couple of hours ago, but I still have to take it out of the box.
            S S 2 Replies Last reply Jun 28, 2019, 2:22 PM Reply Quote 0
              sdetweil @Cr4z33
              @Cr4z33 black screen means error in the UI code… so, open the developers window, ctrl-shift-i, select the console tab, and scroll up to find the error…
                SH20192 @Cr4z33
                @Cr4z33 said in Raspberry Pi 4 Released !:
                Yes to MagicMirror. Only thing running on it. I was not running Spotify.
                D 1 Reply Last reply Jun 28, 2019, 4:57 PM Reply Quote 0
                  dazza120 @SH20192
                  is it over heating? ETA prime has his overclocked to 1.7Ghz CPU and 600Mhz on the GPU 😳 it must be on fire 🔥 😂
                  S 1 Reply Last reply Jun 28, 2019, 5:13 PM Reply Quote 0
                    SH20192 @dazza120
                    Probably not. There was a fan on it.
                    • C Offline
                      Cr4z33
                      My issue with the Pi and MM is different.
                      After installing MM, configuring autostart I rebooted, but now the max resolution is 1024x768… 😣
                      C 1 Reply Last reply Jul 3, 2019, 1:19 PM Reply Quote 0
                      • 6
                      • 7
                      • 4 / 7
                      4 / 7
