    MMM-Face-Reco-DNN - All new Face Recognition
    36 Posts 14 Posters 24.8k Views 17 Watching
    • nischiN
      nischi @ChrizZz
      @ChrizZz
      Yes i know this issue. i’m currently working on a bugfix. will tell you if i’m done.
      • I
        Ivanov_d
        I am turning on the monitor using a PIR sensor and it is instant. Keep in mind that it also depends on your monitor, some are slower to respond - this is my second monitor, the first one was very slow to respond to any HDMI related commands.
        • C
          ChrizZz
          I have a new strange error and I think it’s just if I restart mm with “pm2 restart mm”. If I reboot my pi, everything is fine.
          SyntaxError: Unexpected token m in JSON at position 0
              at JSON.parse (<anonymous>:null:null)
              at PythonShell.asJson (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:375:21)
              at /home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:326:42
              at Array.forEach (<anonymous>:null:null)
              at PythonShell.receiveInternal (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:322:15)
              at PythonShell.receiveStderr (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:306:21)
              at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:109:22)
              at Socket.emit (events.js:182:13)
              at addChunk (_stream_readable.js:279:12)
              at readableAddChunk (_stream_readable.js:260:13)
              at Socket.Readable.push (_stream_readable.js:219:10)
              at Pipe.onread (net.js:636:20)
          SyntaxError: Unexpected token T in JSON at position 0
          { Error: mmal: mmal_vc_port_enable: failed to enable port vc.null_sink:in:0(OPQV): ENOSPC
          mmal: mmal_port_enable: failed to enable connected port (vc.null_sink:in:0(OPQV))0x631b2f0 (ENOSPC)
          mmal: mmal_connection_enable: output port couldn't be enabled
          Traceback (most recent call last):
            File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 56, in <module>
              vs = VideoStream(usePiCamera=True).start()
            File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/stream.py", line 18, in __init__
              framerate=framerate)
            File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/picam.py", line 10, in __init__
              self.camera = PiCamera()
            File "/usr/lib/python3/dist-packages/picamera/camera.py", line 433, in __init__
              self._init_preview()
            File "/usr/lib/python3/dist-packages/picamera/camera.py", line 513, in _init_preview
              self, self._camera.outputs[self.CAMERA_PREVIEW_PORT])
            File "/usr/lib/python3/dist-packages/picamera/renderers.py", line 558, in __init__
              self.renderer.inputs[0].connect(source).enable()
            File "/usr/lib/python3/dist-packages/picamera/mmalobj.py", line 2212, in enable
              prefix="Failed to enable connection")
            File "/usr/lib/python3/dist-packages/picamera/exc.py", line 184, in mmal_check
              raise PiCameraMMALError(status, prefix)
          picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
              at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:268:21)
              at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:139:32)
              at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:131:13)
              at ChildProcess.emit (events.js:182:13)
              at Process.ChildProcess._handle.onexit (internal/child_process.js:237:12)
            executable: 'python3',
            options: null,
            script: 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
            args:
             [ '--cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
               '--encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
               '--usePiCamera=1',
               '--method=dnn',
               '--detectionMethod=hog',
               '--interval=2000',
               '--output=0' ],
            exitCode: 1 }
          • B
            Blauenfeldt
            I get this too, when my PI can’t connect to the camera. I know that, because if i use
            I will get an error there too. A reboot seems to fix it though. I don’t know what makes it happen, but i suspect the cable.
              sdetweil @Blauenfeldt
              @Blauenfeldt the python code returns an error, but the module does not expect it, and fails.
              • R
                rjlinden
                Will this work if the camera is rotated? If not, can you tell me where I need to change the code?
                • H
                  hANNEsLUL
                  when im trying to install the face_recogtnition I’m getting this error code:
                  Does anybody know how to fix this/what is causing this?
                  Sorry if it’s obvious, im a super noob with this kind of stuff
                  Cheers
                  pi@raspberrypi:~ $ pip install face_recognition
                  Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                  Collecting face_recognition
                    Using cached https://files.pythonhosted.org/packages/1e/95/f6c9330f54ab07bfa032bf3715c12455a381083125d8880c43cbe76bb3d0/face_recognition-1.3.0-py2.py3-none-any.whl
                  Requirement already satisfied: dlib>=19.7 in ./.local/lib/python2.7/site-packages (from face_recognition) (19.19.0)
                  Collecting face-recognition-models>=0.3.0 (from face_recognition)
                    Downloading https://www.piwheels.org/simple/face-recognition-models/face_recognition_models-0.3.0-py2.py3-none-any.whl (100.6MB)
                      99% |████████████████████████████████| 100.6MB 1.7MB/s eta 0:00:01
                  Exception:
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/cli/base_command.py", line 143, in main
                      status = self.run(options, args)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/commands/install.py", line 338, in run
                      resolver.resolve(requirement_set)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 102, in resolve
                      self._resolve_one(requirement_set, req)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 256, in _resolve_one
                      abstract_dist = self._get_abstract_dist_for(req_to_install)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 209, in _get_abstract_dist_for
                      self.require_hashes
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/operations/prepare.py", line 283, in prepare_linked_requirement
                      progress_bar=self.progress_bar
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 836, in unpack_url
                      progress_bar=progress_bar
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 673, in unpack_http_url
                      progress_bar)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 897, in _download_http_url
                      _download_url(resp, link, content_file, hashes, progress_bar)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 617, in _download_url
                      hashes.check_against_chunks(downloaded_chunks)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/hashes.py", line 48, in check_against_chunks
                      for chunk in chunks:
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 585, in written_chunks
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/ui.py", line 159, in iter
                      for x in it:
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 574, in resp_read
                      decode_content=False):
                    File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 494, in stream
                      data = self.read(amt=amt, decode_content=decode_content)
                    File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 442, in read
                      data = self._fp.read(amt)
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 63, in read
                      self._close()
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 50, in _close
                      self.__callback(self.__buf.getvalue())
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/controller.py", line 275, in cache_response
                      self.serializer.dumps(request, response, body=body),
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/serialize.py", line 87, in dumps
                      ).encode("utf8"),
                  MemoryError
                  • G
                    gaudouy @hANNEsLUL
                    @hANNEsLUL
                    Try this :
                    pip --no-cache-dir install face_recognition
                    -python setup.py install
                    • G
                      gaudouy
                      What is the best camera for this module ?
                      Pi NoIR Camera V2
                      alt text
                      https://www.raspberrypi.org/products/pi-noir-camera-v2/
                      Or
                      Camera Module V2
                      alt text
                      https://www.raspberrypi.org/products/camera-module-v2/
                      Thanks for advance :)
                      • H
                        hANNEsLUL @gaudouy
                        @gaudouy
                        Thank you, seems like that worked.
                        But now I am getting following error when I’m trying to run “encode.py”
                        Python 3.7.3 (/usr/bin/python3)
                        >>> %Run encode.py
                          File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/encode.py", line 5, in <module>
                            from imutils import paths
                        ModuleNotFoundError: No module named 'imutils'
                        But when I’m installing “imutils” using “pip install imutils” I am getting no error, but following message:
                        Requirement already satisfied: imutils in ./.local/lib/python2.7/site-packages (0.5.3)
                        Any Idea how to fix that?
                        And to your best camera question for this module, I’m using the PiCamera Module v.2, but I can’t tell you how good its working, since the Face-Reco is not working yet…
                        • B
                          boppersnr @nischi
                          @nischi
                          First off, I love your module. Well done. Its lots of fun.
                          Question - How can I display the frame/view of the camera on the magic mirror?
                          I would like to see what the camera sees on the screen in Magic Mirror. So I can see the display and the little green boxes with the names of the faces it recognises. Do you know what I would need to do to display the camera frame with the facial recognition code running the scans/outputs on screen?
                          A nischiN 2 Replies Last reply Reply Quote 1
                          • G
                            ghiesseldorf @nischi
                            @nischi If a user who isn’t known by Face-Reco-DNN moves in front of the camera, is a notification message generated and picked up by MMM-MotionControl? It doesn’t look like the “default” and/or “everyone” classes toggles the screen to un-blank. I was expecting that ANY motion (changes in the capture frames from the camera) would un-blank, but I’m not seeing this behavior. No log-in message gets written to the log.
                            • A
                              Alphons @boppersnr
                              @boppersnr i also want to know.
                              • nischiN
                                nischi @boppersnr
                                @boppersnr said in MMM-Face-Reco-DNN - All new Face Recognition:
                                This feature is not implemented, sorry. Maybe create a ticket in github?
                                • M
                                  Mattheww
                                  @nischi In my case classes doesn’t work. I was testing this at a bunch of different modules and always was the same resault, nothing change if classes was defined or not. The face recognition is working I tested it with python. But in modules MMM-Face-Reno-DNN I can’t run classes. Whats more I need to run or where I need to look for a trouble and what can I do to solve it.
                                  • A
                                    Aquamannno @nischi
                                    @nischi when I bring this up only a black screen appears with me listing my name but what about the rest of the modules in the magic mirror could be nice with a photo of the recognized precision I find only this (jimbydude / MMM-Face-Multi -User-Recognition-SMAI)
                                    is picked up by magic mirror without error and stops you who are so incredibly good please come up with a variant with photo and welcome greetings.looking forward to the changes. and on whore 1000 thanks.
                                    Sincerely an unlearned raspberry pi owns rpi4 8g hq camera.
                                    Roy Bråthe Norwar
