    MMM-Face-Reco-DNN - All new Face Recognition
    36 Posts 14 Posters 20.5k Views 17 Watching
    • nischiN Offline
      nischi @ChrizZz
      @ChrizZz
      Yes i know this issue. i’m currently working on a bugfix. will tell you if i’m done.
      • I Offline
        Ivanov_d
        I am turning on the monitor using a PIR sensor and it is instant. Keep in mind that it also depends on your monitor, some are slower to respond - this is my second monitor, the first one was very slow to respond to any HDMI related commands.
        • C Offline
          ChrizZz
          I have a new strange error and I think it’s just if I restart mm with “pm2 restart mm”. If I reboot my pi, everything is fine.
          SyntaxError: Unexpected token m in JSON at position 0
              at JSON.parse (<anonymous>:null:null)
              at PythonShell.asJson (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:375:21)
              at /home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:326:42
              at Array.forEach (<anonymous>:null:null)
              at PythonShell.receiveInternal (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:322:15)
              at PythonShell.receiveStderr (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:306:21)
              at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:109:22)
              at Socket.emit (events.js:182:13)
              at addChunk (_stream_readable.js:279:12)
              at readableAddChunk (_stream_readable.js:260:13)
              at Socket.Readable.push (_stream_readable.js:219:10)
              at Pipe.onread (net.js:636:20)
          SyntaxError: Unexpected token T in JSON at position 0
          { Error: mmal: mmal_vc_port_enable: failed to enable port vc.null_sink:in:0(OPQV): ENOSPC
          mmal: mmal_port_enable: failed to enable connected port (vc.null_sink:in:0(OPQV))0x631b2f0 (ENOSPC)
          mmal: mmal_connection_enable: output port couldn't be enabled
          Traceback (most recent call last):
            File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 56, in <module>
              vs = VideoStream(usePiCamera=True).start()
            File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/stream.py", line 18, in __init__
              framerate=framerate)
            File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/picam.py", line 10, in __init__
              self.camera = PiCamera()
            File "/usr/lib/python3/dist-packages/picamera/camera.py", line 433, in __init__
              self._init_preview()
            File "/usr/lib/python3/dist-packages/picamera/camera.py", line 513, in _init_preview
              self, self._camera.outputs[self.CAMERA_PREVIEW_PORT])
            File "/usr/lib/python3/dist-packages/picamera/renderers.py", line 558, in __init__
              self.renderer.inputs[0].connect(source).enable()
            File "/usr/lib/python3/dist-packages/picamera/mmalobj.py", line 2212, in enable
              prefix="Failed to enable connection")
            File "/usr/lib/python3/dist-packages/picamera/exc.py", line 184, in mmal_check
              raise PiCameraMMALError(status, prefix)
          picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
              at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:268:21)
              at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:139:32)
              at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:131:13)
              at ChildProcess.emit (events.js:182:13)
              at Process.ChildProcess._handle.onexit (internal/child_process.js:237:12)
            executable: 'python3',
            options: null,
            script: 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
            args:
             [ '--cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
               '--encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
               '--usePiCamera=1',
               '--method=dnn',
               '--detectionMethod=hog',
               '--interval=2000',
               '--output=0' ],
            exitCode: 1 }
            Blauenfeldt
            I get this too, when my PI can’t connect to the camera. I know that, because if i use
            I will get an error there too. A reboot seems to fix it though. I don’t know what makes it happen, but i suspect the cable.
              sdetweil @Blauenfeldt
              @Blauenfeldt the python code returns an error, but the module does not expect it, and fails.
                rjlinden
                Will this work if the camera is rotated? If not, can you tell me where I need to change the code?
                • H Offline
                  hANNEsLUL
                  when im trying to install the face_recogtnition I’m getting this error code:
                  Does anybody know how to fix this/what is causing this?
                  Sorry if it’s obvious, im a super noob with this kind of stuff
                  Cheers
                  pi@raspberrypi:~ $ pip install face_recognition
                  Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                  Collecting face_recognition
                    Using cached https://files.pythonhosted.org/packages/1e/95/f6c9330f54ab07bfa032bf3715c12455a381083125d8880c43cbe76bb3d0/face_recognition-1.3.0-py2.py3-none-any.whl
                  Requirement already satisfied: dlib>=19.7 in ./.local/lib/python2.7/site-packages (from face_recognition) (19.19.0)
                  Collecting face-recognition-models>=0.3.0 (from face_recognition)
                    Downloading https://www.piwheels.org/simple/face-recognition-models/face_recognition_models-0.3.0-py2.py3-none-any.whl (100.6MB)
                      99% |████████████████████████████████| 100.6MB 1.7MB/s eta 0:00:01
                  Exception:
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/cli/base_command.py", line 143, in main
                      status = self.run(options, args)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/commands/install.py", line 338, in run
                      resolver.resolve(requirement_set)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 102, in resolve
                      self._resolve_one(requirement_set, req)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 256, in _resolve_one
                      abstract_dist = self._get_abstract_dist_for(req_to_install)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 209, in _get_abstract_dist_for
                      self.require_hashes
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/operations/prepare.py", line 283, in prepare_linked_requirement
                      progress_bar=self.progress_bar
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 836, in unpack_url
                      progress_bar=progress_bar
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 673, in unpack_http_url
                      progress_bar)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 897, in _download_http_url
                      _download_url(resp, link, content_file, hashes, progress_bar)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 617, in _download_url
                      hashes.check_against_chunks(downloaded_chunks)
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/hashes.py", line 48, in check_against_chunks
                      for chunk in chunks:
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 585, in written_chunks
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/ui.py", line 159, in iter
                      for x in it:
                    File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 574, in resp_read
                      decode_content=False):
                    File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 494, in stream
                      data = self.read(amt=amt, decode_content=decode_content)
                    File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 442, in read
                      data = self._fp.read(amt)
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 63, in read
                      self._close()
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 50, in _close
                      self.__callback(self.__buf.getvalue())
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/controller.py", line 275, in cache_response
                      self.serializer.dumps(request, response, body=body),
                    File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/serialize.py", line 87, in dumps
                      ).encode("utf8"),
                  MemoryError
                  • G Offline
                    gaudouy @hANNEsLUL
                    @hANNEsLUL
                    Try this :
                    pip --no-cache-dir install face_recognition
                    -python setup.py install
                    • G Offline
                      gaudouy
                      What is the best camera for this module ?
                      Pi NoIR Camera V2
                      alt text
                      https://www.raspberrypi.org/products/pi-noir-camera-v2/
                      Or
                      Camera Module V2
                      alt text
                      https://www.raspberrypi.org/products/camera-module-v2/
                      Thanks for advance :)
                      • H Offline
                        hANNEsLUL @gaudouy
                        @gaudouy
                        Thank you, seems like that worked.
                        But now I am getting following error when I’m trying to run “encode.py”
                        Python 3.7.3 (/usr/bin/python3)
                        >>> %Run encode.py
                          File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/encode.py", line 5, in <module>
                            from imutils import paths
                        ModuleNotFoundError: No module named 'imutils'
                        But when I’m installing “imutils” using “pip install imutils” I am getting no error, but following message:
                        Requirement already satisfied: imutils in ./.local/lib/python2.7/site-packages (0.5.3)
                        Any Idea how to fix that?
                        And to your best camera question for this module, I’m using the PiCamera Module v.2, but I can’t tell you how good its working, since the Face-Reco is not working yet…
                        • 3 / 4
