    Blackscreen after update to v.2.8.0
    30 Posts 8 Posters 12.9k Views 7 Watching
      Blackmirror
      Hello,
      afer the updatre I get a black screen, but Magicmirror is still running.
      pi@Mirror:~/MagicMirror $ pm2 status
      │ App name │ id │ mode │ pid  │ status │ restart │ uptime │ cpu │ mem      │ watching │
      │ mm       │ 0  │ fork │ 1030 │ online │ 0       │ 12h    │ 0%  │ 2.3 MB   │ enabled  │
       Use `pm2 show <id|name>` to get more details about an app
      pi@Mirror:~/MagicMirror $ cd ..
      pi@Mirror:~ $ cd MagicMirror
      pi@Mirror:~/MagicMirror $ ls
      CHANGELOG.md  config  css            fonts         index.html  js             LICENSE.md  module-types.ts  package.json       README.md     serveronly    tests         vendor
      clientonly    core    dangerfile.js  Gruntfile.js  installers  jsconfig.json  modules     node_modules     package-lock.json  run-start.sh  splashscreen  translations
      pi@Mirror:~/MagicMirror $ cd config
      pi@Mirror:~/MagicMirror/config $ ls
      config.js  config.js.sample
      pi@Mirror:~/MagicMirror/config $ cd ..
      pi@Mirror:~/MagicMirror $ npm run config:check
      > magicmirror@2.8.0 config:check /home/pi/MagicMirror
      > node tests/configs/check_config.js
      Checking file...  /home/pi/MagicMirror/config/config.js
      Your configuration file doesn't contain syntax errors :)
      pi@Mirror:~/MagicMirror $ npm install
      > magicmirror@2.8.0 install /home/pi/MagicMirror
      > cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
      > sh installers/postinstall/postinstall.sh && npm run install-fonts
      MagicMirror installation successful!
      > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
      > cd fonts && npm install
      npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
      I hope someone can help me.
      greets Blackmirror
      S mumblebajM 2 Replies Last reply Reply Quote 0
        sdetweil @Blackmirror
        @Blackmirror after the git pull, you did
         npm install
        in the MagicMirror folder and then also
        npm install
        in each module folder that has a package.json file
        • mumblebajM Offline
          mumblebaj Module Developer @Blackmirror
          @Blackmirror Hi. Are there any errors in pm2 logs?
            Blackmirror
            Thanks.
            I have only npm install at Magicmirror not for the modules.
            Now it was running fine.
              @Blackmirror great!.. thanks for the feedback…
              I am working on an upgrade script to do all this for users.
              https://forum.magicmirror.builders/topic/10729/new-script-for-mirror-release-upgrades
              how many modules did u have to npm install for?
              • P Offline
                potts-mike
                I am having the same issue but doing npm install in all of the modules folders doesn’t resolve it. Any other thoughts?
                  mumblebaj Module Developer @potts-mike
                  @potts-mike Are there any issues in your config.js? Can you run npm run config:check and see if there are errors?
                  • P Offline
                    potts-mike
                    I can, should I run that from the config file?
                    I will say though that it worked before the upgrade and I tried the config.js.sample file and it didnt work.
                    • bheplerB Offline
                      bhepler Module Developer @potts-mike
                      @potts-mike - Run it from the command line in the /home/pi/MagicMirror folder.
                      • P Offline
                        potts-mike
                        THe config file does not contain syntax errors.
                        pi@raspberrypi:~/MagicMirror $ npm run config:check
                          sdetweil @potts-mike
                          @potts-mike ok, then do
                          npm start dev
                          Or
                          Ctrl-shift-i   if already running
                          And in the developers window, select the console tab, and scroll up to find any errors. Red text usually.
                          • P Offline
                            potts-mike
                            I know that the last thing it says it is launching the app but a white screen with the developer console opens with the error “Dev tools was disconnected from the page…”
                            pi@raspberrypi:~/MagicMirror $ npm start dev
                            > magicmirror@2.8.0 start /home/pi/MagicMirror
                            > sh run-start.sh "dev"
                            Starting MagicMirror: v2.8.0
                            Loading config ...
                            Loading module helpers ...
                            WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node_helper'
                            App threw an error during load
                                at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                                at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                                at Module.require (internal/modules/cjs/loader.js:658:17)
                                at require (internal/modules/cjs/helpers.js:20:18)
                                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Sonos/node_helper.js:7:18)
                                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Sonos/node_helper.js:30:3)
                                at Module._compile (internal/modules/cjs/loader.js:711:30)
                                at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                at Module.load (internal/modules/cjs/loader.js:620:32)
                            { Error: Cannot find module 'node_helper'
                                at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
                            Launching application.
                              dazza120 @potts-mike
                              @potts-mike i get the same with the pi4, the npm installs on some modules are killing the mirror. i think its safe to link all of these threads into one, ive put out a request for the dev of one module, i have no idea if any other module that i will put on the mirror will do the same i can only take it one step at a time, the affected module is mmm-nest-status.
                              pi@raspberrypi:~ $ cd MagicMirror/modules
                              pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/BenRoe/MMM-SystemStats
                              Cloning into 'MMM-SystemStats'...
                              remote: Enumerating objects: 22, done.
                              remote: Counting objects: 100% (22/22), done.
                              remote: Compressing objects: 100% (14/14), done.
                              remote: Total 231 (delta 10), reused 16 (delta 8), pack-reused 209
                              Receiving objects: 100% (231/231), 88.08 KiB | 578.00 KiB/s, done.
                              Resolving deltas: 100% (122/122), done.
                              pi@raspberrypi:~/MagicMirror/modules $ cd MMM-SystemStats
                              pi@raspberrypi:~/MagicMirror/modules/MMM-SystemStats $ npm install
                              npm notice created a lockfile as package-lock.json. You should commit this file.
                              added 1 package from 1 contributor and audited 1 package in 1.265s
                              found 0 vulnerabilities
                              pi@raspberrypi:~/MagicMirror/modules/MMM-SystemStats $ cd
                              pi@raspberrypi:~/MagicMirror $ cd modules
                              pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/michael5r/mmm-nest-status.git
                              Cloning into 'mmm-nest-status'...
                              remote: Enumerating objects: 135, done.
                              remote: Total 135 (delta 0), reused 0 (delta 0), pack-reused 135
                              Receiving objects: 100% (135/135), 65.27 KiB | 718.00 KiB/s, done.
                              Resolving deltas: 100% (77/77), done.
                              pi@raspberrypi:~/MagicMirror/modules $ cd mmm-nest-status
                              pi@raspberrypi:~/MagicMirror/modules/mmm-nest-status $ npm install
                              npm WARN deprecated undefined@0.1.0: this package has been deprecated
                              npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                              npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                              npm WARN modules No description
                              npm WARN modules No repository field.
                              npm WARN modules No README data
                              npm WARN modules No license field.
                              removed 1 package in 1.141s
                              pi@raspberrypi:~/MagicMirror/modules/mmm-nest-status $ cd
                              pi@raspberrypi:~ $ pm2 restart MagicMirror
                              Use --update-env to update environment variables
                              [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
                              [PM2] [MagicMirror](0) ✓
                              │ Name        │ id │ mode │ status │ ↺ │ cpu │ memory   │
                              │ MagicMirror │ 0  │ fork │ online │ 2 │ 0%  │ 2.5 MB   │
                              pi@raspberrypi:~ $ npm  run config:check
                              npm ERR! path /home/pi/package.json
                              npm ERR! code ENOENT
                              npm ERR! errno -2
                              npm ERR! syscall open
                              npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                              npm ERR! enoent This is related to npm not being able to find a file.
                              npm ERR! enoent
                              npm ERR!     /home/pi/.npm/_logs/2019-07-13T20_08_21_703Z-debug.log
                                sdetweil @dazza120
                                @dazza120 mmm-nest-status does not have a package.json file,
                                so you should NOT do an npm install in that modules folder
                                  dazza120 @sdetweil
                                  @sdetweil ok interesting any idea why it kills it if you do that as it’s never before very strange thanks I’ll take a look at it
                                    sdetweil @dazza120
                                    @dazza120 no idea… all this npm stuff is new to me and I don’t understand all the rules and issues
                                      dazza120 @sdetweil
                                      @sdetweil 100% that man it doesn’t need npm install and is working :) thank you
                                        sdetweil @dazza120
                                        @dazza120 thanks for the update!..
                                        • P Offline
                                          panos
                                          Same issue here.
                                          Black screen after updating to v2.8. Any suggestions?
                                          Log file:
                                          pm2 logs MagicMirror
                                          [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                                          /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                                          0|MagicMir | Initializing new module helper …
                                          0|MagicMir | Module helper loaded: calendar
                                          0|MagicMir | No helper found for module: calendar_monthly.
                                          0|MagicMir | Loading module helpers …
                                          0|MagicMir | No helper found for module: alert.
                                          0|MagicMir | Module helper loaded: updatenotification
                                          0|MagicMir | No helper found for module: clock.
                                          0|MagicMir | Whoops! There was an uncaught exception…
                                          0|MagicMir | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          0|MagicMir | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          0|MagicMir | Launching application.
                                          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                                          0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:711:30)
                                          0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                                          0|MagicMir | at Module.load (internal/modules/cjs/loader.js:620:32)
                                          0|MagicMir | { Error: Cannot find module ‘del’
                                          0|MagicMir | at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                                          0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                          0|MagicMir | at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                                          0|MagicMir | at Module.require (internal/modules/cjs/loader.js:658:17)
                                          0|MagicMir | at require (internal/modules/cjs/helpers.js:20:18)
                                          0|MagicMir | at Object. (/home/pi/MagicMirror/modules/mmm-moon-phases/node_helper.js:3:11)
                                          0|MagicMir | at Object. (/home/pi/MagicMirror/modules/mmm-moon-phases/node_helper.js:39:3)
                                          0|MagicMir | at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }
                                          0|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                            sdetweil @panos
                                            @panos after you did the git clone, you have to run
                                            npm install
                                            and then
                                            npm install
                                            in each module folder that has a package.json file…
