    Blackscreen after update to v.2.8.0
    30 Posts 8 Posters 12.5k Views 7 Watching
      Blackmirror
      afer the updatre I get a black screen, but Magicmirror is still running.
      pi@Mirror:~/MagicMirror $ pm2 status
      │ App name │ id │ mode │ pid  │ status │ restart │ uptime │ cpu │ mem      │ watching │
      │ mm       │ 0  │ fork │ 1030 │ online │ 0       │ 12h    │ 0%  │ 2.3 MB   │ enabled  │
       Use `pm2 show <id|name>` to get more details about an app
      pi@Mirror:~/MagicMirror $ cd ..
      pi@Mirror:~ $ cd MagicMirror
      pi@Mirror:~/MagicMirror $ ls
      CHANGELOG.md  config  css            fonts         index.html  js             LICENSE.md  module-types.ts  package.json       README.md     serveronly    tests         vendor
      clientonly    core    dangerfile.js  Gruntfile.js  installers  jsconfig.json  modules     node_modules     package-lock.json  run-start.sh  splashscreen  translations
      pi@Mirror:~/MagicMirror $ cd config
      pi@Mirror:~/MagicMirror/config $ ls
      config.js  config.js.sample
      pi@Mirror:~/MagicMirror/config $ cd ..
      pi@Mirror:~/MagicMirror $ npm run config:check
      > magicmirror@2.8.0 config:check /home/pi/MagicMirror
      > node tests/configs/check_config.js
      Checking file...  /home/pi/MagicMirror/config/config.js
      Your configuration file doesn't contain syntax errors :)
      pi@Mirror:~/MagicMirror $ npm install
      > magicmirror@2.8.0 install /home/pi/MagicMirror
      > cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
      > sh installers/postinstall/postinstall.sh && npm run install-fonts
      MagicMirror installation successful!
      > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
      > cd fonts && npm install
      npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
      I hope someone can help me.
      greets Blackmirror
      S mumblebajM 2 Replies Last reply Reply Quote 0
        sdetweil @Blackmirror
        @Blackmirror after the git pull, you did
         npm install
        in the MagicMirror folder and then also
        npm install
        in each module folder that has a package.json file
        • mumblebajM Offline
          mumblebaj Module Developer @Blackmirror
          @Blackmirror Hi. Are there any errors in pm2 logs?
            Blackmirror
            Thanks.
            I have only npm install at Magicmirror not for the modules.
            Now it was running fine.
              @Blackmirror great!.. thanks for the feedback…
              I am working on an upgrade script to do all this for users.
              https://forum.magicmirror.builders/topic/10729/new-script-for-mirror-release-upgrades
              how many modules did u have to npm install for?
                potts-mike
                I am having the same issue but doing npm install in all of the modules folders doesn’t resolve it. Any other thoughts?
                  mumblebaj Module Developer @potts-mike
                  @potts-mike Are there any issues in your config.js? Can you run npm run config:check and see if there are errors?
                    potts-mike
                    I can, should I run that from the config file?
                    I will say though that it worked before the upgrade and I tried the config.js.sample file and it didnt work.
                    • bheplerB Offline
                      bhepler Module Developer @potts-mike
                      @potts-mike - Run it from the command line in the /home/pi/MagicMirror folder.
                        potts-mike
                        THe config file does not contain syntax errors.
                        pi@raspberrypi:~/MagicMirror $ npm run config:check
