    Blackscreen after update to v.2.8.0
    30 Posts 8 Posters 12.9k Views 7 Watching
    • P Offline
      panos @sdetweil
      @sdetweil still no luck…:(
      pi@raspberrypi:~/MagicMirror $ npm install
      magicmirror@2.8.0 install /home/pi/MagicMirror
      cd vendor && npm install
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
      audited 220 packages in 13.958s
      found 5 vulnerabilities (4 low, 1 high)
      run npm audit fix to fix them, or npm audit for details
      magicmirror@2.8.0 postinstall /home/pi/MagicMirror
      sh installers/postinstall/postinstall.sh && npm run install-fonts
      MagicMirror installation successful!
      magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
      cd fonts && npm install
      audited 1 package in 1.893s
      found 0 vulnerabilities
      audited 3581 packages in 72.743s
      found 44 high severity vulnerabilities
      When I manually try to launch MagicMirror I get this:
      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
      magicmirror@2.8.0 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.8.0
      Loading config …
      Loading module helpers …
      Initializing new module helper …
      No helper found for module: calendar_monthly.
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘del’
      App threw an error during load
      at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      at Module.require (internal/modules/cjs/loader.js:658:17)
      at require (internal/modules/cjs/helpers.js:20:18)
      at Object. (/home/pi/MagicMirror/modules/mmm-moon-phases/node_helper.js:3:11)
      at Object. (/home/pi/MagicMirror/modules/mmm-moon-phases/node_helper.js:39:3)
      at Module._compile (internal/modules/cjs/loader.js:711:30)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
      at Module.load (internal/modules/cjs/loader.js:620:32)
      Whoops! There was an uncaught exception…
      { Error: Cannot find module ‘del’
      at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }
      Launching application.
        sdetweil
        ok, one more forceful try
        from the MagicMirror folder do
        rm -rf node_modules
        npm install
        • P Offline
          panos @sdetweil
          @sdetweil No man…:( still the same
          • P Offline
            panos
            How to completely remove magicmirror in order to install it from scratch?
              sdetweil @panos
              @panos rename the MagicMirror folder to MagicMirror-old
              then run install again…
              then u can copy modules, config file, … then when all is good,
              rm -rf MagicMirror-old
              • P Offline
                panos
                Finally I get this worked!!
                thanks dude
                Edit:
                After restoring config/custom.css/ and install all modules from the beginning, the problem has occurred again.:(:(
                • P Offline
                  panos
                  Is there a way to install v2.7 instead?
                    sdetweil @panos
                    @panos that generally means a mismatch between node_module levels…
                    so, in each module with a node_modules folder do
                    rm -rf node_modules
                    npm install
                    first, just disable one module at a time,
                    update the failing one first
                    add disabled: true,
                    in front of the module name
                    • P Offline
                      panos @sdetweil
                      @sdetweil it turns out that MMM-moon-phases module has the problem! I comment out the code and everything works like a charm!! Thanks for your help!!
                        Mykle1 Project Sponsor Module Developer @panos
                        @panos
                        There are other moon phase modules that you can try. Search the 3rd party modules page
