    Blackscreen after update to v.2.8.0
    30 Posts 8 Posters 14.5k Views 7 Watching
      dazza120 @potts-mike
      @potts-mike i get the same with the pi4, the npm installs on some modules are killing the mirror. i think its safe to link all of these threads into one, ive put out a request for the dev of one module, i have no idea if any other module that i will put on the mirror will do the same i can only take it one step at a time, the affected module is mmm-nest-status.
      pi@raspberrypi:~ $ cd MagicMirror/modules
      pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/BenRoe/MMM-SystemStats
      Cloning into 'MMM-SystemStats'...
      remote: Enumerating objects: 22, done.
      remote: Counting objects: 100% (22/22), done.
      remote: Compressing objects: 100% (14/14), done.
      remote: Total 231 (delta 10), reused 16 (delta 8), pack-reused 209
      Receiving objects: 100% (231/231), 88.08 KiB | 578.00 KiB/s, done.
      Resolving deltas: 100% (122/122), done.
      pi@raspberrypi:~/MagicMirror/modules $ cd MMM-SystemStats
      pi@raspberrypi:~/MagicMirror/modules/MMM-SystemStats $ npm install
      npm notice created a lockfile as package-lock.json. You should commit this file.
      added 1 package from 1 contributor and audited 1 package in 1.265s
      found 0 vulnerabilities
      pi@raspberrypi:~/MagicMirror/modules/MMM-SystemStats $ cd
      pi@raspberrypi:~/MagicMirror $ npm  run config:check
      > magicmirror@2.8.0 config:check /home/pi/MagicMirror
      > node tests/configs/check_config.js
      Checking file...  /home/pi/MagicMirror/config/config.js
      Your configuration file doesn't contain syntax errors :)
      pi@raspberrypi:~/MagicMirror $ cd modules
      pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/michael5r/mmm-nest-status.git
      Cloning into 'mmm-nest-status'...
      remote: Enumerating objects: 135, done.
      remote: Total 135 (delta 0), reused 0 (delta 0), pack-reused 135
      Receiving objects: 100% (135/135), 65.27 KiB | 718.00 KiB/s, done.
      Resolving deltas: 100% (77/77), done.
      pi@raspberrypi:~/MagicMirror/modules $ cd mmm-nest-status
      pi@raspberrypi:~/MagicMirror/modules/mmm-nest-status $ npm install
      npm WARN deprecated undefined@0.1.0: this package has been deprecated
      npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
      npm WARN modules No description
      npm WARN modules No repository field.
      npm WARN modules No README data
      npm WARN modules No license field.
      removed 1 package in 1.141s
      pi@raspberrypi:~/MagicMirror/modules/mmm-nest-status $ cd
      pi@raspberrypi:~ $ pm2 restart MagicMirror
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0)
      [PM2] [MagicMirror](0) ✓
      │ Name        │ id │ mode │ status │ ↺ │ cpu │ memory   │
      │ MagicMirror │ 0  │ fork │ online │ 2 │ 0%  │ 2.5 MB   │
       Use `pm2 show <id|name>` to get more details about an app
      pi@raspberrypi:~ $ npm  run config:check
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/.npm/_logs/2019-07-13T20_08_21_703Z-debug.log
        sdetweil @dazza120
        @dazza120 mmm-nest-status does not have a package.json file,
        so you should NOT do an npm install in that modules folder
        D 1 Reply Last reply
          dazza120 @sdetweil
          @sdetweil ok interesting any idea why it kills it if you do that as it’s never before very strange thanks I’ll take a look at it
            sdetweil @dazza120
            @dazza120 no idea… all this npm stuff is new to me and I don’t understand all the rules and issues
              dazza120 @sdetweil
              @sdetweil 100% that man it doesn’t need npm install and is working :) thank you
                sdetweil @dazza120
                @dazza120 thanks for the update!..
                  panos
                  Same issue here.
                  Black screen after updating to v2.8. Any suggestions?
                  Log file:
                  pm2 logs MagicMirror
                  [TAILING] Tailing last 15 lines for [MagicMirror] process (change the value with --lines option)
                  /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
                  0|MagicMir | Initializing new module helper …
                  0|MagicMir | Module helper loaded: calendar
                  0|MagicMir | No helper found for module: calendar_monthly.
                  0|MagicMir | Loading module helpers …
                  0|MagicMir | No helper found for module: alert.
                  0|MagicMir | Module helper loaded: updatenotification
                  0|MagicMir | No helper found for module: clock.
                  0|MagicMir | Whoops! There was an uncaught exception…
                  0|MagicMir | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  0|MagicMir | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  0|MagicMir | Launching application.
                  /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
                  0|MagicMir | at Module._compile (internal/modules/cjs/loader.js:711:30)
                  0|MagicMir | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                  0|MagicMir | at Module.load (internal/modules/cjs/loader.js:620:32)
                  0|MagicMir | { Error: Cannot find module ‘del’
                  0|MagicMir | at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                  0|MagicMir | at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                  0|MagicMir | at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                  0|MagicMir | at Module.require (internal/modules/cjs/loader.js:658:17)
                  0|MagicMir | at require (internal/modules/cjs/helpers.js:20:18)
                  0|MagicMir | at Object. (/home/pi/MagicMirror/modules/mmm-moon-phases/node_helper.js:3:11)
                  0|MagicMir | at Object. (/home/pi/MagicMirror/modules/mmm-moon-phases/node_helper.js:39:3)
                  0|MagicMir | at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }
                  0|MagicMir | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                    sdetweil @panos
                    @panos after you did the git clone, you have to run
                    npm install
                    in the MagicMirror folder
                    and then
                    npm install
                    in each module folder that has a package.json file…
                    P 1 Reply Last reply
                      panos @sdetweil
                      @sdetweil still no luck…:(
                      pi@raspberrypi:~/MagicMirror $ npm install
                      magicmirror@2.8.0 install /home/pi/MagicMirror
                      cd vendor && npm install
                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
                      audited 220 packages in 13.958s
                      found 5 vulnerabilities (4 low, 1 high)
                      run npm audit fix to fix them, or npm audit for details
                      magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                      sh installers/postinstall/postinstall.sh && npm run install-fonts
                      MagicMirror installation successful!
                      magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                      cd fonts && npm install
                      audited 1 package in 1.893s
                      audited 3581 packages in 72.743s
                      found 44 high severity vulnerabilities
                      When I manually try to launch MagicMirror I get this:
                      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                      magicmirror@2.8.0 start /home/pi/MagicMirror
                      sh run-start.sh
                      Starting MagicMirror: v2.8.0
                      Loading config …
                      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘del’
                      App threw an error during load
                        ok, one more forceful try
                        from the MagicMirror folder do
                        rm -rf node_modules
                        npm install
                          panos @sdetweil
                          @sdetweil No man…:( still the same
                            panos
                            How to completely remove magicmirror in order to install it from scratch?
                              sdetweil @panos
                              @panos rename the MagicMirror folder to MagicMirror-old
                              then run install again…
                              then u can copy modules, config file, … then when all is good,
                              rm -rf MagicMirror-old
                                panos
                                Finally I get this worked!!
                                thanks dude
                                Edit:
                                After restoring config/custom.css/ and install all modules from the beginning, the problem has occurred again.:(:(
                                  panos
                                  Is there a way to install v2.7 instead?
                                    sdetweil @panos
                                    @panos that generally means a mismatch between node_module levels…
                                    so, in each module with a node_modules folder do
                                    rm -rf node_modules
                                    npm install
                                    first, just disable one module at a time,
                                    update the failing one first
                                    add disabled: true,
                                    in front of the module name
                                      panos @sdetweil
                                      @sdetweil it turns out that MMM-moon-phases module has the problem! I comment out the code and everything works like a charm!! Thanks for your help!!
                                      Mykle1M 1 Reply Last reply
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @panos
                                        @panos
                                        There are other moon phase modules that you can try. Search the 3rd party modules page
