    Help With 2.8 Install?
    11 Posts 4 Posters 4.3k Views 4 Watching
    • P Offline
      potts-mike
      I had MagicMirror 2.7 installed and it was working fine. I hadn’t gotten very far along with it when I upgraded to 2.8 and it black screened on me. I know that there are some threads discussing this but I decided to wipe everything and start over.
      I have a completely fresh and updated Raspbian install and when I run the installer script I get the following errors.
      Installing dependencies ...
      (node:4177) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm WARN engine grunt-markdownlint@2.5.0: wanted: {"node":">=6","npm":">=3"} (current: {"node":"8.11.1","npm":"1.4.21"})
      npm ERR! Error: Method Not Allowed
      npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR!     at /usr/share/npm/lib/cache/add-named.js:120:12
      npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this *entire* log,
      npm ERR! including the npm and node versions, at:
      npm ERR!     <http://github.com/npm/npm/issues>
      npm ERR! System Linux 4.19.57-v7+
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install"
      npm ERR! cwd /root/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      > electron-chromedriver@1.8.0 install /root/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      module.js:549
          throw err;
      Error: Cannot find module '/root/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver/download-chromedriver.js'
          at Function.Module._resolveFilename (module.js:547:15)
          at Function.Module._load (module.js:474:25)
          at Function.Module.runMain (module.js:693:10)
          at startup (bootstrap_node.js:188:16)
          at bootstrap_node.js:609:3
      npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
      npm WARN This failure might be due to the use of legacy binary "node"
      npm WARN For further explanations, please read
      /usr/share/doc/nodejs/README.Debian
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/root/MagicMirror/node_modules/spectron/node_modules/webdriverio/lib/commands'
      npm ERR! error rolling back  spectron@3.8.0 { Error: ENOTEMPTY: directory not empty, rmdir '/root/MagicMirror/node_modules/spectron/node_modules/webdriverio/lib/commands'
      npm ERR! error rolling back   errno: -39,
      npm ERR! error rolling back   code: 'ENOTEMPTY',
      npm ERR! error rolling back   syscall: 'rmdir',
      npm ERR! error rolling back   path: '/root/MagicMirror/node_modules/spectron/node_modules/webdriverio/lib/commands' }
      npm ERR! tar.unpack untar error /root/.npm/postcss-jsx/0.36.2/package.tgz
      npm ERR! tar.unpack untar error /root/.npm/table/5.4.4/package.tgz
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/root/MagicMirror/node_modules/stylelint/node_modules/postcss/lib'
      npm ERR! error rolling back  stylelint@10.1.0 { Error: ENOTEMPTY: directory not empty, rmdir '/root/MagicMirror/node_modules/stylelint/node_modules/postcss/lib'
      npm ERR! error rolling back   path: '/root/MagicMirror/node_modules/stylelint/node_modules/postcss/lib' }
      npm ERR! tar.unpack untar error /root/.npm/escape-string-regexp/1.0.5/package.tgz
      npm ERR! tar.unpack untar error /root/.npm/supports-color/5.5.0/package.tgz
      npm ERR! tar.unpack untar error /root/.npm/postcss-selector-parser/3.1.1/package.tgz
      npm ERR! tar.unpack untar error /root/.npm/autoprefixer/9.6.1/package.tgz
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/root/MagicMirror/node_modules/stylelint/node_modules/chalk/node_modules/ansi-styles'
      npm ERR! error rolling back  chalk@2.4.2 { Error: ENOTEMPTY: directory not empty, rmdir '/root/MagicMirror/node_modules/stylelint/node_modules/chalk/node_modules/ansi-styles'
      npm ERR! error rolling back   path: '/root/MagicMirror/node_modules/stylelint/node_modules/chalk/node_modules/ansi-styles' }
      npm ERR! tar.unpack untar error /root/.npm/remark-parse/6.0.3/package.tgz
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/root/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-stringify/lib/util'
      npm ERR! error rolling back  remark@10.0.1 { Error: ENOTEMPTY: directory not empty, rmdir '/root/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-stringify/lib/util'
      npm ERR! error rolling back   path: '/root/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-stringify/lib/util' }
      npm ERR! tar.unpack untar error /root/.npm/remark-stringify/6.0.4/package.tgz
      npm ERR!
      npm ERR!     /root/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
      Any help with these errors or help installing 2.7 appreciated, Thanks.
        sdetweil
        @potts-mike said in Help With 2.8 Install?:
        npm is WAY downlevel
        wanna try my new installer script?
        it would be better just to start over again…
        bash -c  "$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)"
        I have also made a new script for upgrading
        https://forum.magicmirror.builders/topic/10859/new-upgrade-script-ready-for-testing
        • P Offline
          potts-mike
          @sdetweil said in Help With 2.8 Install?:
          bash -c “$(curl -sL https://www.dropbox.com/s/rlh710ng0zwv3vp/raspberry.sh?dl=0)”
          I saw your other post. What is different between yours and the official one?
          S Mykle1M 2 Replies Last reply Reply Quote 0
            sdetweil @potts-mike
            @potts-mike fixes for npm level, pm2 , non pi installs (mac, etc, and users who are not ‘pi’)
            hope to get this in to the next cycle
            along with the upgrade script
              Mykle1 Project Sponsor Module Developer @potts-mike
              @potts-mike
              I highly recommend @sdetweil’s scripts. :thumbsup:
              • G Offline
                Gomalley @sdetweil
                @sdetweil I tried the new script and it did not autostart on reboot
                  sdetweil @Gomalley
                  @Gomalley which script did u use?
                  Upgrade doesn’t touch the pm2 config at all
                  G 2 Replies Last reply Reply Quote 0
                  • G Offline
                    Gomalley @sdetweil
                    • G Offline
                      Gomalley @sdetweil
                      @sdetweil i did not do
                      npm install
                      before I pasted the code above. Do you think thats my issue
                        sdetweil @Gomalley
                        @Gomalley the installer attempts to get node and npm up to the latest level.
                        And it does the npm install
                        Then it asks about using pm2.
                        Sadly it doesn’t have a log, I didn’t write the original. But I think I will add that. This is install from nothing.
                        Do
                        node -v
                        npm -v
                        Let me know
                        • G Offline
                          Gomalley @sdetweil
                          pi@raspberrypi:~ $ node -v
                          v10.15.2
                          pi@raspberrypi:~ $ npm -v
                          6.10.2
                          pi@raspberrypi:~ $
