    MMM-WeatherDependentClothes - Be properly dressed
    16 Posts 10 Posters 6.8k Views 10 Watching
    • FrühstückF Offline
      Frühstück @cowboysdude
      @cowboysdude Thanks! I really do and don’t wan’t to miss it. It may sound silly but it takes the burden of choosing e.g. between shorts and pants around 16°C with a quick look off my sholders.
      @mikey20333 I’m sorry you’re experiencing troubles. As mentioned above, I’m rather inactive with MM right now and wouldn’t be much of help. Not sure if the issue is comming from my repositiory beeing a bit of age. Thankfully @lavolp3 offered his troubleshooting guide. Have a peak into it, good luck!
      If after this, the issue isn’t solved you could try uploading your config (please remove any private api keys before). I can’t gurantee finding the bug but it’s a shot if the guide doesn’t help.
      @lavolp3 Thank you for your support
      • T Offline
        themurm523 @mikey20333
        @mikey20333 I think I’m having the same issue. I have a bunch of other modules on my Mirror and generally just copy/paste. For some reason this one gives me an error on boot up. Usually I forget a comma before the next module, but I have it correct as of now, but it’s still not working :(
        FrühstückF 1 Reply Last reply Reply Quote 0
          Frühstück @themurm523
          @themurm523 There was a comma missing after appid in the readme. Thanks to doctor74 for his PR.
          Does this fix your issue?
          @mikey20333 said in MMM-WeatherDependentClothes - Be properly dressed:
          Hello, i have a problem with the module
          Does this also fix your issue mikey20333?
            martha_facka @Frühstück
            @Frühstück
            i have a problem to,
            		module: "MMM-WeatherDependentClothes",
            		position: "top_right", // This can be any of the regions.
            			locationID: "", //Location ID from http://bulk.openweathermap.org/sample/city.list.json.gz
            			appid: "abcde12345abcde12345abcde12345ab", //openweathermap.org API key.
            			preferences: [
            				    icon: "jacket-cold",
            				    conditions: {
            					temp_max: 2.0,
            				// more items here. See .js for default list
            (npm run config:check) the last line is the problem (};)
              sdetweil @martha_facka
              @martha_facka yes you are missing some
              } and ]
              there also should only be one ;
              and it is provided in the sample config
                acdacd2
                hello,
                I installed the module but stay loading on the MM.
                Any advice ?
                marc
