    MMM-WeatherDependentClothes - Be properly dressed
    16 Posts 10 Posters 6.8k Views 10 Watching
    • FrühstückF Offline
      Frühstück
      Hey Kai,
      if I remember correctly the module simply checks the values specified in the conditions with the fetched weather data values. So if you specify conditions in imperal units and also request imperial weather data, it should work out just fine. Can’t tell for sure as I’ve no time for checking. You could test it and let us know.
      Best,
      Frühstück
      • lavolp3L Offline
        lavolp3 Module Developer
        Funny idea @Frühstück.
        Have only found it just know from the new comments.
        Do you know my module MMM-WeatherBoy?
        Maybe both of these can profit from each other.
        Will have a closer look at yours soon!
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        FrühstückF 1 Reply Last reply Reply Quote 1
          Frühstück @lavolp3
          Thanks @lavolp3. I’ve uploaded this module and finished my mirror 10 months ago and since then I was rather inactive. Had a quick peek into yours and it’s a nice idea - especially as it is for your kids.
          Yeah, feel free to let me know if you find anything worth chainging in WeatherDependendClothes (except the somewhat unlucky and hard to spell name). ^^
          Good luck and have fun building!
            mikey20333
            Hello, i have a problem with the module, i use the latest magic mirror version. but when i copy the whole text in my module magic mirror have many errors and will not start. i try different things with or without ()]. Maybe it is better to upload my config file to show whats wrong the intallation with icons and the folder was ok. i also try a other position, but nothing works .
            https://github.com/fruestueck/MMM-WeatherDependentClothes
            thanks a lot
            best regards
            mikey
            lavolp3L T 2 Replies Last reply Reply Quote 0
            • cowboysdudeC Offline
              Just making a joke here but do you really need a module to tell you what to wear? Wouldn’t the weather tell you that? LOL Looks good though!
              Mykle1M lavolp3L FrühstückF 3 Replies Last reply Reply Quote 0
                @cowboysdude
                Rolling
                • lavolp3L Offline
                  lavolp3 Module Developer @cowboysdude
                  @cowboysdude I have done something quite similar and my 5-year-old loves it!
                  This guy even changes color in every parth of the clothes randomly
                  • lavolp3L Offline
                    lavolp3 Module Developer @mikey20333
                    @mikey20333 Try out my troubleshooting manual in my signature
                    “How to troubleshoot modules”
                      Frühstück @cowboysdude
                      @cowboysdude Thanks! I really do and don’t wan’t to miss it. It may sound silly but it takes the burden of choosing e.g. between shorts and pants around 16°C with a quick look off my sholders.
                      @mikey20333 I’m sorry you’re experiencing troubles. As mentioned above, I’m rather inactive with MM right now and wouldn’t be much of help. Not sure if the issue is comming from my repositiory beeing a bit of age. Thankfully @lavolp3 offered his troubleshooting guide. Have a peak into it, good luck!
                      If after this, the issue isn’t solved you could try uploading your config (please remove any private api keys before). I can’t gurantee finding the bug but it’s a shot if the guide doesn’t help.
                      @lavolp3 Thank you for your support
                      • T Offline
                        themurm523 @mikey20333
                        @mikey20333 I think I’m having the same issue. I have a bunch of other modules on my Mirror and generally just copy/paste. For some reason this one gives me an error on boot up. Usually I forget a comma before the next module, but I have it correct as of now, but it’s still not working :(
                        FrühstückF 1 Reply Last reply Reply Quote 0
